Question about Air Conditioning and Heat for Nissan NX
How to replace lower radiator hose 1993 nissan nx2000
  • Nissan Master
  • 14,338 Answers
Hey Dan,here's a link on how to remove bottom radiator hose.
Posted on Jan 17, 2013
2001 Nissan Frontier REPLACE WATER PUMP - removed Radiator & Hoses Need HELP with REMAINDER
NOTE: When removing water pump assembly, be careful not to get coolant on timing belt unless you intend to replace it. (if it has more than 60.000 miles. it probably SHOULD be replaced, however, you must do it correctly or severe engine damage will occur.)
Drain coolant from drain plugs on both sides of cylinder block and radiator.
Remove radiator hoses (upper and lower) and fan shroud.
Remove drive belts.
Remove water pump pulley.
Remove crankshaft pulley and front (upper and lower) belt cover.
Remove water pump
Oct 01, 2011 | 2001 Nissan Frontier Crew Cab
Thermostat
It should be located where the lower radiator hose connects to the engine, and there you should find the thermostat housing. Be sure when installing the new thermostat that the spring side of the thermostat is installed towards the engine.
After you change the thermostat you might have to remove the upper radiator hose from the radiator to pour coolant back into the block, or the engine might not have any coolant getting into it until after the thermostat has opened up, and by then it would be too late and the engine will over-heat. Also, be sure to bleed the trapped air from the cooling system by using any bleeders in the cooling system.
Jun 20, 2010 | 2000 Nissan Sentra
I need to replace my radiator on a 04 Nissan Titan 5.6 2 WD, and I would like a diagram showing how to do it.
From the 2004 Titan Factory Service Manual, You can get one Promanuals. I hope this helps. It's straight forward procedure.
1. Drain engine coolant from the radiator.
2. Remove air cleaner and air duct assembly.
3. Disconnect A/T fluid cooler hoses.
(Install blind plug to avoid leakage of A/T fluid)
4. Disconnect radiator upper and lower hoses from radiator.
CAUTION:
Do not allow coolant to contact drive belts.
5. Remove the lower radiator shroud.
( Release the tabs, pull lower radiator shroud rearwards and
down to remove.)
6. Remove the radiator shroud upper bolts and remove the radiator
shroud upper.
7. Remove the A/C condenser bolts and brackets.
NOTE:
Lift A/C condenser up and forward to remove from radiator.
8. Remove A/T oil cooler bolts and oil cooler from radiator and
position aside.
9. Lift up and remove the radiator.
CAUTION:
Do not damage or scratch air conditioner condenser and
radiator core when removing.
Oct 10, 2009 | 2004 Nissan Titan
Radiator hose 93 chevrolet cavalier not sure if it is upper or lowerthe one cracked comes out of bottom of radiator so i assume it is the lower
depending on how many miles you have on the car i would look at the lower hose first; the other common problem on a 93 cav would be the lower radiator neck or radiator leak; the lower hose has less pressure on it than the upper so sometimes finding the leak can be tricky. with the engine off and cold squeeze the lower hose by the radiator to see if any fluid comes out. otherwise you would have to pressurize the system to find the leak
Sep 16, 2009 | 1993 Chevrolet Cavalier
Is there a diagram to show the location of the starter for 1992 Nissan NX2000? How could we troubleshoot it?
the starter should be right next the oild pan on the left hand side. and if not then it will be on the lower part of the motor in the front.
Jun 12, 2009 | 1993 Nissan NX
Thermostat in 1993 Nissan 100NX
if you follow the lower radiator hose all the way to the motor you will see a alloy case held in by three 10mm bolts remove them pull of the housing and the thermostat is in there
Jun 29, 2008 | 1993 Nissan NX
Air Conditioning and Heat for Nissan NX Logo
49 people viewed this question
Top Nissan Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Jim Y
Jim Y
Are you a Nissan Vehicle Part and Accessory Expert? Answer questions, earn points and help others
