Question about Viper 4103XV 4-Button 1-way Remote Start System with Keyless Entry
Battery is draining - Viper 4103XV 4-Button 1-way Remote Start System with Keyless Entry
    Genius:
  • 1,669 Answers
You probably have a short circuit or a button contact that is constantly pushed in and using electricity. Try using some CRC or WD40 spray on the buttons and exercise them to smooth out their return to normal action.
Posted on Jan 04, 2013
Anti theft light is flashing and draining my battery
What make , model an year vehicle ! What theft light ? on the instrument cluster , on top of dash pad etc.... Normally these don't pull enough currant to drain the battery .
Oct 23, 2016 | Cars & Trucks
1998 Ford Taurus battery light on battery drains overnight
have battery and alternator tested most auto stores offer this service for free -if good the following showes how to look for a parasite drain
How to Test and Find Parasitic Battery Drain Key Off How to Find Parasitic Battery Drain
Oct 01, 2016 | Ford Cars & Trucks
Something is draining the battery on our 2002 bmw z3.the battery and alternator checks out good,what is draining the battery??
HELP 2000 Z3 Battery Drain - Bimmerfest - BMW Forums
www.bimmerfest.com > ... > Z Series > E36/7 Z3 (1996-2002)
Feb 18, 2007 - 7 posts - ‎6 authors
HELP 2000 Z3 Battery Drain E36/7 Z3 (1996-2002) ... Something is draining the battery. ... Posts: 55. Mein Auto: 2000 BMW Z3 2.8 Roadster. z3 1.9 battery drain (fuse 31)
Apr 9, 2013
Intermittent car battery drain problem NEED HELP
Jan 29, 2013
Mysterious Battery Drain
Feb 23, 2008
Battery drain....after 2 days sitting dead...
Mar 28, 2006
More results from www.bimmerfest.com
Jan 18, 2016 | 2002 BMW Z3
The five lighhts across the top drain battery
S10 Battery Drain - Discussion on Topix
www.topix.com > Chevrolet S-10
Apr 4, 2008 - Having problems with battery drain on my 2001 S10 4.3 V6. .... killing thebattery because the lights and everything will drain out and then ... I have a 2000 s10 4.3 have to unhook battery ever time I shut it off put in a new starter 5 months ago ...Comments made yesterday: 41,571 • Total comments across all ...
Parasitic Battery Drains - Diagnostic News
www.diagnosticnews.com/parasitic-battery-drains/
Jun 24, 2014 - Testing for parasitic battery drains has changed a lot since my dad ...Most test lights would require more than 500 mA to flowing through .... Connect the switch into series between the negative battery cable and post as shown in figure 5. ...Now, connect your ammeter with its in-line fuse across each side of ...
Battery - 9 - Care Of The Battery On The Car
Dec 16, 2015 | Cars & Trucks
Electrical battery drain OR "parasitic drain"
Seen this "mystery drain" many times. Check spark at the battery to see how big the drain is. For this simple test, blow away any (explosive) battery charging fumes. Leave one terminal on and gently touch the other to its post in fairly dark surroundings. Then try it again with the wires taken off the alternator. Your spark is now probably much less. Usually bad diodes leaking electricity backwards through the alternator cause this drain. Replace the alternator or the diode pack inside it. Some mechanics recommend actually measuring the drain.... hahaha. OK whatever.
Dec 27, 2013 | 2008 Subaru Outback
My 98 lumina has a constant power draw from somewhere. I just replace the battery and had the alt tested (it was good). I have to jump the dang thing every morning but if I drive it enough during the day...
The alternator may charge fine but could drain the battery through a bad diode,have you checked the alt for a bad diode?Disconnect the battery positive cable.Put a regular 12v test light between the battery positive post and the positive battery cable.If the test light is bright you do have a drain,if dim it is OK.A dim light may mean the drain is internal in the battery.If you do have a bright light remove a fuse ,one at a time from the fuse box until the light goes dim.Once dim you have identified the bad circuit.If removing all fuses do not dim the light,disconnect the alt charging wire at the alt,if that dims the light,then you do have a bad diode.DO NOT create a drain(bright light) when checking for the drain by turning on the key or opening a door/trunk etc.
Also,do an overnight battery check by disconnecting the battery overnight,if things are fine the next morning after the battery was disconnected then it is a drain in the vehicle,if the battery is dead even after being disconnected overnight,,then the battery is bad.
Jun 15, 2017 | Cars & Trucks
My kia keeps dying! 2000 kia sephia. something is draining the battery new battery and alternator what can it be?
WHEN TURN OFF CAR CHECK TO SEE IF RADIO TURN OFF.CHECK TO SEE IF INTERIOR LIGHTS OFF.MAKE SURE HEADLIGHTS TURN OFF.IF ALL LOOK GOOD.YOUR POWER DOOR LOCK FAULTY DRAIN POWER.FAULTY BLOWER MOTOR RELAY DRAIN BATTERY.FAULTY STARTER RELAY OR SOLENOID DRAIN BATTERY.FAULT IN THE PCM WILL DRAIN BATTERY.MANY MANY THINGS WILL DRAIN BATTERY.
Nov 08, 2010 | Kia Sephia Cars & Trucks
Viper 4103XV 4-Button 1-way Remote Start System with Keyless Entry Logo
57 people viewed this question
Top Viper Computers & Internet Experts
David Payne
David Payne
Are you a Viper Computer and Internet Expert? Answer questions, earn points and help others
