Question about Rainbow E series Canister Wet/Dry Vacuum
Rainbow vacuum making a beeping noise
I was using it, and it was smelling a little hot. I turned it off and when I went to turn it back on , it gave me 3 beeps and wouldn't start. Any ideas what the problem could be?
    Habit-Forming:
  • Rainbow Expert
  • 119 Answers
<p>There is a good change that the controller is bad. Contact us and we can see if it is still under warranty.</p>
<p>RainVac </p>
<p><a rel='nofollow' href="www.rainvac.com">www.rainvac.com</a></p>
<p>800-523-0510</p>
Posted on Jun 14, 2013
  • 5 Answers
SOURCE: D3 Rainbow Vacuum separator problem
something loose underneath the separator?
Posted on Jan 18, 2008
SOURCE: Rainbow Vacuum Cleaner starts slow smells hot
We ahve a canister Rainbow E series with powerhead. We took the Handle apart because it was clogged and now can't figure how to put back together. Any help would be great.
Posted on Feb 02, 2008
Agent Don
  • 310 Answers
SOURCE: Rainbow SE makes Squealing Noise when switching it On/Off
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=528929
Rainbow SE makes Squealing Noise when switching it...
Posted by ray_s51 on Apr 20, 2008
My Rainbow SE works and runs strong but when I switch it on and off for approx. 20 to 30 seconds the motor makes a loud squealing noise. Do I need to oil something or what? Nothing smells, it does not make the noise all the time, but it does more often than not. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum.
The Rainbow has 3 fans in the bottom of the motor and if they are weak they will make noise from the motor unit. Watch out… the repair of the Rainbow may exceed the cost of a new motor of which will solve your problem of noise and separator --- compare the cost and the labor and make a decision. The separator is part of the armature, the separator should be able to be removed and that might be one of the things making noise. As normal maintenance the separator should be removed and cleaned after every use and re-installed, then place a newspaper or towel under the motor unit and turn on the Rainbow and spin the moisture out of the motor unit. This should be done every time you use it. If you have further questions please feel free to contact your local vacuum cleaner dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 12, 2008
SOURCE: My Rainbow stopped running
I took my unit apart to clean it. I was careful to put it back the same way. Now it won't start.
Posted on Jul 13, 2008
  • 430 Answers
SOURCE: motor won't start
Most times this will be caused by one of 3 items, the cord, the switch or the carbon brushes in the motor. Inspect the plug area on the cord for strain twist it gently and look to see if the cord appears a bit white where it meets the plug or if the cord appears crushed just before the plug.
Also inspect where the cord meets the body of the vac for the same signs of wear or any locations where it may have been caught in the power head , etc.
If you have test meter, check for resistance change at the plug while twisting and finally try the same twisting with the vac plugged in if necessary but keep your fingers back from the plug in case the cord blows... gently twist and pull slightly to see if the motor continues to run.
Most often when a switch fails it just dies and doesn't become intermitant... so with a meter it will generally test good or bad , nothing else..
Sometimes on a well worn vac when the motor doesn't start the carbon brushes in the motor have worn down. A heavy duty motor such as the Rexair can often be rebuilt if brushes are required.
If you turn the machine on and bump or jolt the side of the body as if to spin it, you can often "trick " the motor into starting. If this happens it is most likely a carbon brush issue , if not time for a new motor.
Rainbow/Rexair machines have a fairly good motor however because of how they run drawing moist air through they often rust as they age. This is a tedius rebuild and best left to a pro shop with parts on hand if requiring brushes. Most shops will simpley scrap a worn motor if rusty and replace it completely.
Before you spend big $ on a repair or replacement....
One last thing....... pull the exhaust cap at the back of the vac. You will seen fine powder dust and residue.Wipe your finger across it. This is what the Rexair releases into your home each time it runs, but you don't smell it because it comes out in the form of humidity...like after a spring rain.
That same humidity is rusting your motor gradually year by year. Although this motor has a long life span, consider that you have been breathing dirty humidity as it runs. If you put orange drink crystals in the water bucket and run the vac, the exhaust air would smell like orange juice,... so what is in the tank comes out in the air, including your dirty water.
Most Rexair owners buy thinking they are helping to reduce allergins.. yet what is on that exhaust plug proves otherwise. If your home is essentially carpet free and you are vigilant maintaining and rinsing the bucket, you might consider rebuilding this vac.. Otherwise consider a good High end European vac like a SEBO,MIELE, Nilfisk etc for better filtration and reliability
Posted on Oct 10, 2009
My rainbow vacuum e series won't turn on.
it could be the switch . or brushes
Feb 01, 2015 | Rainbow Vacuums
Oreck vacuum cleaner stop and burn smell
sounds like hair or string or something like that is wrapped around the beater bar(the long brush under the head that brushes the carpet) keeping it from turning. The belt that drives the bar is getting hot because the beater bar is stuck.
Aug 12, 2014 | Oreck Vacuums
Why rainbow vac wont turn on
There are numerous reasons. If there was no smoke or burning smell, first try a different outlet. Then you can try wiggling the cord and check cord for damage, if you can get it to start and it turns off again cord is loose or damaged. Try the switch, sometimes switch wears out, if it is not making a click sound or is very loose it may be the switch. The most common reason for an E series to not start after working just fine is a broken actuator on the water basin or missing from the bottom of the vacuum. There is a raised part on the water basin that depresses a little black plastic actuator on the bottom of the vacuum. This is a safety switch to make sure the water basin is there so the vacuum will turn on. You can try pressing in on that and trying to start your vacuum, if it starts you will need to check and see if the part is broken off of your basin or if the little black actuator is missing. You can see pictures here.
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
May 10, 2014 | Rainbow E series Canister Wet/Dry Vacuum
My e series rainbow smells very badly... my teenager often leaves the water in for days and that nasty smell has saturated the sweeper itself. How do I get the smell out
You should always put a new hepa filter in any E and E2 series Rainbow vacuum, when it taken to a new home, or every two Years, or so, or if your Doughter makes it get funky smelling. :-) It will smell like the home that it was in, or how ever it smells, until you do.
You can also use fragrances, and deodorizer air freshener in your vacuum, which not only eliminates odors, it add fresh aromas to your air that you breath, in your home, also.
Replace the hepa filter first thing.
The water separator is the thing that spins in the center of the motor where your water basin attaches to it. It looks like a cone shaped fan looking thing. It should be cleaned after every use.
Use your Rainbow separator cleaning brush, or a tooth brush, if you do not have the Rainbow one. They are just like tooth brushes.
Never store your Rainbow canister on your water basin, with or without water in it. It can and will ruin your vacuum in dew time.
You can get manuals either here,
http://www.rainbowsystem.com/ or here,
http://www.rainvac.com
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Jan 05, 2010 | Rainbow E series Canister Wet/Dry Vacuum
The beater bar won't spin
Even though the belt is intact it can still be stretched and if it is it won't turn the brush roll when it's on the carpet. Here is a link to the belt you need and to a manual you can view:
Rainbow Replacement Belts and Manual
Nov 27, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Won't turn on
If there was a smell like something plastic burning it may be that something just actually burned. It does not have to smoke like a chimney (sometimes it does though - depends what is burning)... If there were no strange noises and it did not seem to run any different than usually - most likely the motor is still fine. I would inspect the cord really carefully but to do any more than that you would have to open the unit and inspect everything else.
If you chose to do so – open the Rainbow and hook up the motor directly to a power supply (hold on to the unit as it will move while starting) – if it runs then problem is in wiring. Test the cord with a tester or bulb, then the switch (or 2 switches if this is e-series Rainbow). Make sure all wires are intact. There is not much to test so you will get it done and find the problem quick.
This is messing with electricity and subjecting you fingers to potential hazard by exposing working motor so do it at your own risk and be very careful and if anything goes wrong do not blame me :-)
Aug 31, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Go Ahead. Use Us.
Apr 20, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow e series
It could if the separator is binding, or dragging, when it turns, causing the motor to over heat, that maybe what you are smelling. If it is, then replace the separator.
Dec 29, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
337 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
Robert McClure
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
