Question about Asko 24 in. 1895 Built-in Dishwasher
Dishwasher asko 1895 the pump the working the lights are flashing but the machine is not working
When we first installed the machine i forgot to break a hole in the drainege pipe so the machine was trining to pump the water out but could not. i realised the proplem and i had the hole done . now after i started the machine back the lights are flashing , the pump the working but nothing is happening
  • Asko Master
  • 3,247 Answers
The lights flashing is telling that there is a fault in the dishwasher.
I am assuming you have emptied the dishwasher after the drain cycle failed to work due to the pipe block.
You will have to make a fresh start. Empty the dishwasher, turn the power mains switch off and on to reset the dishwasher.
Start a new cycle and see if flashing lights stop flashing. If still same problem you will have to note which light(s) are flashing and send a post on this page. There is a chance the impeller in the drain pump may have sufferred some damage due to drain block depending on how long the motor operated before you found the problem with the drain.
Posted on Jan 04, 2013
Rotu
  • 175 Answers
SOURCE: ASKO Overfill protection tripped
Ok, heres what you have to do. Remove the lower toe kick and then remove the panel behind that to gain entry to the lower portion of the dishwasher wher the guts are. You will also have to pull out the little brackets that hold the toe kick and all the screws will be t-15 or t-20 torx (little star shaped bits) Once you have all the panels out of the way, you will find water in the bottom of the tray there tripping the overflow switch. Remove the water with a wet vac or towel or something and the drain pump will stop running. If you can't or don't want to do all this, then just let the dishwasher sit for a few days or so and eventually the water will just evaporate and everything will work normally. Hope This Helps!
Posted on Nov 24, 2006
  • 59 Answers
SOURCE: Asko dishwasher 1475 indicates high water level
The "High Water Level" in the machine can be triggered not only by the Styrofoam operated switch in the safety tray under the machine's tub, but also by the Overfill Pressure Switch pictured here
My previous post describes the erratic behavior this switch can cause. It seemed almost at random, the "High Water Level" condition would occur in whatever cycle I used.
It is easily located at the end of a small rubber hose visible when the kick panel and service covers are removed. Look just above where the electrical power terminal block is. The switch is held in place by the clip protruding from the top (as shown in the picture above). The sides of the clip need to be pressed towards the center to release the switch. I simply rotated the switch until the clip was turned to the longer side of the rectangular hole it clips in to. It then just fell out.
This pressure switch triggers the drain pump when too much water enters the machine, but it can malfunction and will keep the drain pump running "forever" until you turn off the breaker. Unfortunately, until the problem is rectified, the dishwasher "remembers" what it was doing when you disconnected the power and when you re apply power, the drain pump will again start draining your already empty dishwasher.
I pulled the connectors attached to the spade terminals on the switch back a bit and then forward as far as they would go ensuring all the wires had continuity from the terminal to the opposite end of the wire it was attached to. When I re applied the power, the empty dry dishwasher attempted to start up where it left off in the cycle it was on, but the "High Water Level" conditioned cleared. Pressing and holding the single button opposite the light left on canceled the cycle and the machine went into standby as it should.
I hope this helps someone else. Until I "Googled" the part number printed on the switch, I didn't know what triggered the "overfill" or "High Water Level" condition.
Part number on the part was 8058475. I also found out the small hose attached is part number 8058500. The small hose is not as readily available as the pressure switch, so extra care should be used when handling it.
Posted on Dec 03, 2007
Timon90
  • 126 Answers
Remove the backpanel of the machine, and look if there is water at the bottom of the machine. If so, use a towel or so to dry up the water. This should solve the prob.
Posted on Jan 24, 2008
SOURCE: Asko Dishwasher F2 Error Flashing
i have the same problem (F2) with my 1776. they said it was a overfill sensor. I pulled to first kick plate off but can't get to the 2nd. any suggestions on how to do this? thanks!
Posted on Jul 29, 2008
  • 14 Answers
SOURCE: Water in drain pump for ASKO D5122XXL dishwasher
Yes, Asko dishwashers can leave a small amount of water in the sump after a cycle completes. At the beginning of most cycles the sump is pumped and new water added.
Posted on Jun 19, 2009
My asko D5155 stops washing and flashes F7
LED L1+ L2/Fault code F7, Pumping out fault (machines with
pressure sensor)
Water not evacuated after 120 seconds pumping out. Program
interrupted.
Check: Drain pump, hoses, installation of drain hose, control unit and wiring.
Dado
Oct 06, 2015 | Asko Dishwashers
Asko 1895 shows F2 outlet pump running no water in washer will not shut off have shut off power and restarted stll shows F2 with pump running ?
open the access to the pump and make sure thats its clear and that there are no foreign objects blocking the impellar from spinning. Unit will not start if drain pump is clogged
May 03, 2011 | Asko Dishwashers
ASKO D3251 flashing error message; drain gurgling, power off
You most likely have a leaking bottom spray arm. The water is in the pan under your unit. It requires dealer service. If you are still in your 3-year warranty, good; otherwise be prepared to put out hundreds of dollars. I'm going though this now for a second time on my $1600 D3251. Asko did grant a one-time extension on my warranty since it expired a month ago. In 6 months when it breaks again, I'll buy a Bosch. I also had this same problem on a previous Asko. I can't get more than 3 years out of these units, so this is my last Asko. When it breaks again, I'll go with Bosch. Good Luck.
Mar 17, 2009 | Asko D3251HDSS Stainless Steel Built-in...
Asko d3120 flashing coffee cup
I had to slide the dishwasher forward (undercounter installation)and tip it forward as far as possible. Water leaks onto floor, but then the internal controller seems to reset and the ASKO now works normally again. What kind of idiot would design a control module that does not incorporate a power-off interlock? FAIL FAIL FAIL - Bad, ASKO, Bad. Go to your room.
Nov 18, 2008 | Asko 24 in. D3120 Dishwasher
Asko 1895
First make sure your door switch is making proper contact.If not replace it. If it checks out ok than your main control board is bad.
May 21, 2008 | Asko 24 in. 1895 Built-in Dishwasher
My Asea 1502 Dishwasher gets most of the way through a cycle then stops with lights flashing. It is empty of water. What is the problem?
Further to my problem with my 19 year old ASKO ASEA D1502 Dishwasher .
I found a Use & Care Guide online at the ASKO site:
http://www.asko.com.au/downloads/manuals/
(It is an 8MB PDF, only 20 pages scanned)
The manual says flashing lights in the combo I had indicate heater fault.
Manual has good test procedure and I followed that and it showed that the Heater is OK.
Machine works through full cycle but flashes at the end.
It is an old machine so I suppose I just live with it unless anyone has any suggestions.
Apr 23, 2008 | Dishwashers
Asko 1895
the most important thing is to screw it to the bench,there are four screw points two at the top and two on the side near the top if you look you will see the tags where they go.as far as the hoses go just make sure the drain hose is up high and not laying on the floor.hope this helps.if connecting to hot water it must be below 60 degrees.and you probably wont need a pressure limitin valve fitted to the tap.
Mar 20, 2008 | Asko 24 in. 1895 Built-in Dishwasher
Asko 1895
water in base remove dishwasher and tilt to side and it will restart,but you may have a leak,also check the inlet valve may not be closing fully.hope this helps.
Mar 06, 2008 | Asko 24 in. 1895 Built-in Dishwasher
Asko dishwasher
Most likely the main switch is bad.
Jan 02, 2008 | Asko 24 in. 1895 Built-in Dishwasher
Dishwashers Logo
281 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
