Question about Vehicle Parts & Accessories
Wiring diagram for Commando GM Universal Passlock II bypass
I have a Commando Universal Passlock II bypass in my 99 blazer. I am installing a new command starter, but dont have the wiring diagram for the bypass. If anyone can locate it, or send me one. I would greatly appreciate it.
Thanx
4 Suggested Answers
SOURCE: Passlock II issues for 99 Tahoe
turn key to start position for 10 minutes and it will reset passlock
Or, once you're tired of being stranded for 10 min every 6 weeks or so, try the following:
Here's the "fix" I did for my 99 tahoe. Took the cover off the steering column, unplugged the sensor from the cylinder *while* the car was running. it's a 3 wire plug red w/ white, orange w/black and yellow. From then on, the car will always start and ignore the sensor. The only negative is the security light stays on. Replacing the BCM only postpones it from happening again if the problem is the resistance in the ignition lock cylinder. Check out the following links. Good luck.
http://car.justanswer.com/for/ce07-bypass-lock-sensor-1998-chevy-tahoe
http://general-motors.pissedconsumer.com/gm-passlock-ii-system-has-major-inherent-design-flaws-20080502119601.html
Posted on Mar 18, 2009
  • 306 Answers
SOURCE: Is there anyway to bypass or disable the passlock
no. the passlock system talks to the ecm and shuts down the fuel injection.. what kind of problem are u having with it?
Posted on Aug 24, 2010
SOURCE: how to install a DEI/BOA 555L GM Passlock 1 &
Hi I am three months that I have problems with my chevrolet trail blazzer LTZ 2002, installing the gas system is drained and the battery with the keys on the framework, since the machine is no longer match and lights a lamp in the dashboard which is the immobilizer! installing this module you can baypassare the original immobilizerHi I am three months that I have problems with my chevrolet trail blazzer LTZ 2002, installing the gas system is drained and the battery with the keys on the framework, since the machine is no longer match and lights a lamp in the dashboard which is the immobilizer! installing this module you can baypassare the original immobilizer
Posted on Oct 23, 2010
How to bypass passlock on 1999 chevy blazer
The most common repair is to replace the ignition lock cylinder due to broken wires inside the steering column. Most common problems related to the Passlock family involve the Passlock sensor. The sensor is part of the ignition lock cylinder on Passlock I and Passlock II systems. ( Where the key goes ), Good-Day!
Aug 27, 2014 | 1999 Chevrolet Blazer
I am needing to bypass the passlock system on a 2001 chevy 2500hd so I can add a alternate key switch. The truck will have 2 places to start it.
go to a gm dealer and buy another key switch and key or go to a place they install remote starters and get a key mod they will need your key to program it
Aug 17, 2013 | Megatronix - PASSLOCK-SL2 - GM Passlock...
What is the passcode for the anti theft system
his vehicle has a the PASSLOCK II key
based engine disabling system.
You can attempt to put the key in the ignition,
turn it on to just before cranking and then leaving
it that way for 10 mins. After that,
some PASSLOCK systems will re learn the code
and allow for starting. But if not, the system
will either need to be seen by GM or, a bypass module
is required to circumvent.
If left unchecked, it will continue to lock down
the fuel injector rail, and you will need to tow
it in to GM for evaluation, and resetting anyway.
Bothersome, but can be fixed.
I suggest the PLJX bypass kit to get around
this issue. www.PASSLOCK2.com
This Passlock Bypass Module is designed to momentarilly
allow the engine to remote start by sending a proper
coded pulse to open the fuel rail passlock injector
cut off circuit.
The output from an alarm/remote starter
would then shut down the pulse, once it has detected
the engine has engaged, and preserve the integrity
of the passlock system.
That is it's designed purpose.
However, in your case, this input wire on the PLJX module,
instead of going to a momentary ground pulse from
an alarm/remote starter,
would go to a constant chassis ground, through
the bypass module, grounding out the PASSLOCK.
The PASSLOCK would then always be bypassed as long
as that wire is chassis grounded.
I can not speak about a damaged passlock system,
like if a thief has destroyed it, because I do not
get into this part of GM'S security application.
But as a happy coincidence to installing
after market remote starters, this does work on bypassing
passlock in most all GM vehicles we've run into,
including your year GM vehicle as well.
Also, this is a self learning, resistor sensing
and adjusting module. Once the VATS wires have been tapped,
you would press the program button to learn,
and it does. The car should then allow start
with any hardware store key.
It would on yours as well.
You might want a car alarm installer to do this
for you, the fair rate being around 50. to 75.
for labor.
Jan 26, 2011 | 1999 Chevrolet Malibu
1996 buick skylark..alarm theft keeps flashin..try to start..it turns but wont stay running..
Need a bit more information, Is the security light on, have you checked for spark and fuel pressure, just in case you did and know it is the passlock system then check this out, hopefully it will ansewer your problem, please rate your mechanics help.
have a great day. Sorry the pictures won't come up, but check out the site
GM Passlock I & II Information
Please study the following information carefully WHEN INSTALLING REMOTE START systems on a 1996 or later GM car or truck.
Introduced in 1996, GM has changed the VATS anti theft system to Pass-Lock system. This is a similar device to the VATS system, in that there is a resistor present during the start cycle. However, in the PASSLOCK system, the resistor has been placed inside the ignition switch, instead of the key. See the GM V.A.T.S page for more information.
To remotely start a car with this feature, you must bypass the PASSLOCK system. There are two methods of doing so.. The first, is to permanently bypass this system. This is the easiest method for accomplishing your task. The second way, is to temporarily bypass the PASSLOCK, by introducing relays into the system, which retain all of the features of the system, while allowing your remotes start module to bypass it automatically during a remote start cycle.
Vehicles effected
(1996 and newer): N & J body cars, such as
Pontiac Sunfire and GrandAm Passlock-1
Chevrolet Cavalier Passlock-1
Buick Skylark Passlock-1
Oldsmobile Achieva Passlock-1
1997 or newer
Chevrolet Malibu Passlock-II
Oldsmobile Cutlass Passlock-II
1998 or newer
All trucks , SUVs and Vans Passlock-II
It is important to pay special attention to the fact that there are many different ways of achieving the same goal. There are actually 2 different Passlock-II systems. On the next page, there are tests to establish which type of passlock-II your car has.
Relays shown are standard automotive 5 pin spdt relays, available from IEI.
A multi meter is required to measure the resistance values. Accuracy is important within 5%.
Once the value of the resistor is measured, a resistor of the same value +/-5% must be purchased (Radio Shack2.gif, for example). You can also use a Potentiometer (POT), which can be adjusted to the same value of the resistor in the ignition switch.
pslc1.gif Passlock-I bypass procedure....
1: Remove the top and bottom shrouds from the steering column.
2: Find the 3 wire ribbon cable2.gif, coming from the ignition switch, containing White, Black, Yellow (Sometimes White, Black, Black). These are THIN wires.
3: Locate the Black 6 position connector on the LEFT side of the steering column, right above the ignition switch position. There is a BLACK (Thin) wire in this connector, called "Bulb Test", which shows Ground with ignition in the Off position, OPEN in the "Run" position, and GROUND in the "Crank" position.
4: Turn the ignition switch to the "Run" position. Do not crank the car.
5: Cut the Thin Yellow wire and strip both ends.
6: Without cutting the Black wire, expose some of the copper.
7: Using the ohmmeter, measure from the Yellow wire (the end coming from the ignition switch), to the exposed Black wire and record the value. Measure more than once to assure you have the right value.
8: Acquire the same size resistor and 3 relays, and perform the connections shown in the diagram below.
pslk2.gif PASSLOCK-II bypass procedure
There are 2 types of Passlock-II systems. To determine which system you have, follow these instructions;
1: Locate two wires, which are THIN and are in the main ignition harness.. Orange/Black (or Black) and Yellow.
2: Cut the Yellow wire, and strip back some of the insulation from the Orange/Black (Or Black) wires.
3: Turn the ignition to the "Run" position ( don't crank the starter). Measure and record the value measured from the KEY SIDE of the Yellow wire, to the Black/Orange wire.
4: Turn the key to the "Crank" position and release. Now read the value again.
pslk3.gif5: If the value changed, follow "Method#1". If the value stayed the same, follow "Method#2".
These diagrams are from our friends at ALARMTEK AUTO ALARM
Need additional assistance?
Oct 22, 2009 | 1996 Buick Skylark
My son has a 1999 grand am, just like the oneshown above. the car wont start because the security sys. shuts off the fuel sys. down. the manifold still has good pressure cause we just had thefuel pump...
Need a bit more information, Is the security light on, have you checked for spark and fuel pressure2.gif, just in case you did and know it is the passlock system then check this out, hopefully it will ansewer your problem, please rate your mechanics help.
Introduced in 1996, GM has changed the VATS anti theft system to Pass-Lock system. This is a similar device to the VATS system, in that there is a resistor present2.gif during the start cycle. However, in the PASSLOCK system, the resistor has been placed inside the ignition switch, instead of the key. See the GM V.A.T.S page for more information.
Vehicles effected
Chevrolet2.gif Cavalier Passlock-1
1997 or newer
Chevrolet Malibu2.gif Passlock-II
1998 or newer
Once the value of the resistor is measured, a resistor of the samevalue +/-5% must be purchased (Radio Shack2.gif, for example). You can also use a Potentiometer (POT), which can be adjusted to the same value of the resistor in the ignition switch.
Oct 05, 2009 | 1999 Pontiac Grand Am GT
Why the 1500 silverado does run good but stalls and then after turning the switch of and recrak it does starts ,runs good for a few minutes and stalls againg? note I replace the fuel filter but did not...
If it is your security system you might want this, and please rate your mechanics help, Have a good day.
Vehicles effected
1997 or newer
1998 or newer
Once the value of the resistor is measured, a resistor of the same value +/-5% must be purchased (Radio Shack, for example). You can also use a Potentiometer (POT), which can be adjusted to the same value of the resistor in the ignition switch.
2: Find the 3 wire ribbon cable, coming from the ignition switch, containing White, Black, Yellow (Sometimes White, Black, Black). These are THIN wires.
Oct 02, 2009 | 2000 Chevrolet Silverado
1999 won't start when security light is on.
If you would like to bypass the system I found this, Good luck and please rate your mechanics help.
Vehicles effected
1997 or newer
1998 or newer
Sep 26, 2009 | 1999 Pontiac Grand Am GT
2004 pontiac Grand Am with security passlock starting problems
Unfortunately you are correct, this
vehicle has the PASSLOCK II key
based engine disabling system, and currently it
is engaged. The sensor does not recognize &
retain the passlock reader chip in your ignition
switch any longer.
A bypass is required to circumvent.
If left unchecked, it will lock down the fuel injector
rail (as it has now), and you will need to
tow it in to GM for evaluation, and resetting.
Eventuall, the 10 minute over ride will cease to
work and you will finally be forced to visit
a Pontiac/GM dealer.
But, if you want to just remove this system
from the equation entirelly,
this issue.
cut off circuit.
Coincidence to installing
passlock in most all GM vehicles,
Sep 12, 2009 | 2004 Pontiac Grand Am
Ignition passlock sensor
have a great day.
Vehicles effected
1997 or newer
1998 or newer
Feb 24, 2009 | 1998 Pontiac Sunfire
Jan 24, 2009 | Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
1,154 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
