Question about Black & Decker Saws
Trying to install blade on new Black & Decker cordless saw.
No Spindle lock and no blade installed in the saw yet. How do I get the motor to lock so I can get the bolt out?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 142 Answers
What model is the tool?
Posted on Jan 04, 2013
  • 45112 Answers
SOURCE: circular saw motor turns when tightening saw blade
Insert a tool such as a screwdriver across the blade guard and against a tooth to prevent blade rotation, then tighten the blade nut. Be sure to remove the wedging device before operating the saw
Posted on Dec 29, 2012
  • 42 Answers
SOURCE: I am trying to install
some saws have a button to hold down that will lock the blade in place. if yours doesnt have the button, try putting a screwdriver in one of the cutouts or on the blade tip itslef and lock it in position. your problem may be that the screw on the saw is actually reverse threaded. they usually are reverse threaded.
Posted on Dec 24, 2010
rowdy45176
  • 2176 Answers
SOURCE: I can't tighten the blade on the saw.
are both flanges in place and on correctly?? That would be the first thing that I would look for.
Posted on Dec 30, 2009
airnailer
  • 109 Answers
SOURCE: New a blade guard for a black and decker
toolpartsdirect.com
Posted on Dec 03, 2009
  • 119 Answers
SOURCE: I've borrowed a circular saw
you just have to look for little button close to blade, smash it, hold it while you move the blabe till gets stuck then you're ready to loose the blade! hope this help
Posted on Jul 26, 2011
I have a Black and Decker KS555 circular saw and
It appears that you have adaptors for the blades that are the same thickness as the blades Place the adaptor in the centre and then put on the spindle and tighten up the plates onto the blade.
Sep 05, 2013 | Black & Decker Tools & Hardware - Others
Looking for replacement blades for Black & Decker Zip Saw
Its on ebay http://www.ebay.com/itm/NEW-BLACK-DECKER-ZIP-SAW-11-PIECE-CUTTING-SET-74-691-/260888941452
only 15.00
Apr 02, 2012 | Saws
How to change the blade on a black and decker table saw
unplug tool first. remove the throat plate and raise the blade all the way up. There were 2 wrenches included with this saw when new,, an open end wrench about 3/4" and a box wrench. Hold the spindle with the open end wrench and loosen the hex nut with the other one. It is a standard thread.
Feb 19, 2012 | Black & Decker Saws
I have a black and decker CS1000. How do you tighten or loosen blade. There is no spindle lock that I can find.
If you can't find a spindle lock you can unplug the tool and find a piece of wood and put the blade against it and loosen and also tighten the blade, but most newer saws have a spindle lock located in the gear housing somewhere.
Sep 18, 2011 | Black & Decker CS1012 7-1/4" 12 Amp...
How do i lock the shaft on the motor so i can put the blade in my Black and decker 18V 6-1/2-in Cordless Circular Saw - BDCS1806
Almost all circular saws have a button or lever you push in to lock the motor shaft. You will have to hold that button or lever in while you turn the shaft, there will be one certain spot where it will lock.
May 25, 2011 | Garden
I was given an old grinder a while back (and not told it needed a handle, but luckily found one), but don't know how to get the wheel/blade off to put on another. There is a "key" with it,...
there is usually a spindle lock on the gearcase somewhere that you need to depress while turning the spanner wrench. If this fails what I have done to remove a "stubborn" wheel is use a punch UNPLUG TOOL FIRST and hit against one of the holes counterclockwise to loosen the nut.
May 13, 2011 | Black & Decker Black Decker Decker G750 4...
I am trying to install a blade on a circular 18 vold cordless circular saw and cannot remove the bolt that holds the blade in place. Is there a way to lock it down.
Dec 24, 2010 | Black & Decker Saws
How do you change the blade on a GMC 10 inch cmpund miter saw?
With the saw unplugged, push the spindle lock in on the motor side of the saw (a short black rod) while turning the blade by hand. The spindle lock will seat and hold the blade still so that you can use a wrench to loosen the nut that holds the blade on. Use the spindle lock again for tightening a new blade on the saw.
Sep 10, 2010 | Makita 10" Miter Saw LS1030N
When I try to change the blade on my table saw the shaft moves when I try to loosen the arbor nut. I am blocking the saw blade from moving
If it is like a Dewalt table saw it requires 2 wrenches, one for the hex nut and the other open end for the spindle shaft. If this doesn't help you can go to their website and look at an operators manual for this particular tool.
Dec 09, 2008 | Black & Decker BDTS200 15-Amp Table Saw...
Saws Logo
196 people viewed this question
Top Black & Decker Saws Experts
Craig Butler
Craig Butler
Ruben Bustamante
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
