Question about Breville BKC600XL Coffee Maker
Lid jams The lid catches and stops when opening. Doing it with more force 3 or 4 times and it finaly will open. Did it the first time a few months ago for about a week then cleared up. Now it has started agin. Any idea wha t is causing this?
    New Friend:
No idea what causes it, but you can open it without forcing it. As you lift the handle on the upper half, also push the lower half down and it should open easily. Mine does the same thing occasionally
Posted on Feb 19, 2013
Rear door will not open on my ford focus ghia t reg
Hi chance are the mechanism inside door jamming. Short of forcing off the inner panel in order to clean lubricate etc I find the best way to get this open is to get someone to keep activating your central locking open and shut while you simply keep trying the door handle at the same time and this can some times just catch the latch in just the right position to get the door open ( you dont need to forcefully be pulling on the handle as the latch will either simply click over on the fine spring latch mechanism or not force is not going to help).
Once and if you manage to get door open take off the inner door card panel and oil lubricate mechanism. rather than then shut door simply use a screw driver on latch to test and worth then working back and forth. If still jamming replace latch.
Dec 01, 2013 | Cars & Trucks
My 6.5 wf s6607TC will spin for a few times then would stop and keeps beeping. Ii tired opening and closing the lid but it didnt stop. Then i left it beeping, it would stop on its own but then it wont...
When it spin for a few times then stops the beeping is telling you to redistribute the washing(clothes) in different positions as it is out of balance Opening and closing the lid without doing this is a waste of time as you haven't fixed the problem.
Mar 09, 2013 | Washing Machines
Kenmore 110.25852400 lid switch is sticking, inconsistently engaging. Is it possible to hotwire the switch connections to make it agitate?
You can bypass the lid switch and the only danger is if a small child or person opens the lid during high speed spin and actually try to reach in a grab something. How often does that happen. That is the only function of that switch, for safety at the time of the cycle.
Apr 26, 2012 | Washing Machines
Soap dispenser does not open every time
the spring that tensions the lid is broken or otherwise not working. I would look at the hinge side of the dispenser and see if spring is still intact. When you release the lid, it should snap open without much difficulty so if it doesn't do that, then I would suspect the spring.
May 12, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
I cannot open the door on my Hotpoint Aquarius wt740 after it finished a wash. Door handle is floppy and door light is off.
it sounds like you have a broken door handle Disconnect power before doing anthing remove lid , what you will need to do is usining a screw driver or somthing simular look down to where the catch is (you may need a tourch) and look carefully you should be able to to the door catch mechanisim from inside you will need to mimic the action of the door handel but using a screw driver it a bit fiddley but can be done there is no grate force needed and it the catch will only need to move a bout 3-8 mm to open
Jan 17, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Crazy Electrical Problem in 2005 PT Cruiser
Either wire harness problems or you got a so called lemon
One of the first books of Ralph Nader about auto industry.
Had a Hyundai like that 27 years ago. Until I took it totally apart and re-assembled it myself. 2 years ago bought a Piaggio 45 cc motorbike, same story. Took that apart one night and put it together as should be.
Apr 15, 2009 | 2003 Chrysler PT Cruiser
Triangle button sticking
Try a little rubbing alchahol on a Q-tip. do not drip in to controller, just rub around the button and press the button a few times. might have to do it a few times, let it dry before doing it again. It will break down what ever is sticky.
Jan 28, 2009 | Sony Dual Shock 3 Controller for...
25 yr+ old Sears opener runs past lower limit
Update: I remembered that I had a problem with the door reversing too much a while back. It was chattering in the tracks and I could not fix it with lubrication and changing spring tension. So I dialed up the down reversing force. This contributed to the jam-up I had when the lower limit was ignored. If I had a lighter force, it may have at least reversed.
After futzing with it I left it alone for several hours. The motor would hum every few minutes. I was considering cutting power to it overnight. I pressed the remote one more time and the motor ran normally to a limit and stopped. I tested it a few times then reconnected the chain and door. Seems fine now. I suspect an intermitten logic board problem. I'll try lightening up the down force and using it for a while.
Jan 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Carriage Jam
I FIXED MINE YES... open your thing.. and look,... do you notice..
theirs like a small black.. corner shaped thing, that stopped the carriage..
pop that thing like add force to push it back...
boo ya. :) and their you go...
this problem annoyed me for a month. and i went through numerous hp printers too.
but, just...... really open your eyes and try to find out whatsup..
:) woot woot woot imma print stuff now.
Nov 01, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Breville BKC600XL Coffee Maker Logo
152 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
