Question about GE 24 in. GSD6660GSS Built-in Dishwasher
Smart dispense detergent dispenser
I have a Profile dishwasher with a built in gel detergent reservoir. I have used two different brands of detergent and believe te dispenser is now plugged up. How do I clean the dispenser? same problem
ge peofile smart dispenser is clogged, im assuming because two different detergents were added over the course of time.
    Genius:
  • 1,550 Answers
  1. Remove all dishes from your dishwasher. Leave all the racks inside.
  2. Add the cleaner:
    • For dishwashers with a plastic interior, pour 2 cups of white vinegar in a dishwasher-safe container and place it on the bottom rack of the dishwasher.
    • For steel interior dishwashers use a dishwasher cleaner, following the label instructions.
  3. Do not add dishwasher detergent.
  4. Set the drying option to No Heat and then run the dishwasher through a complete washing cycle.
  5. Remove the container that held the vinegar, if used.
  6. Add dishwasher detergent to the dispenser and then run a normal cycle without dishes in the machine.
  7. Wipe the rubber gasket surrounding your dishwasher door, where food debris can build up. Use a damp sponge or cloth with a mild detergent.
Posted on Jan 19, 2009
    Sergeant:
  • 367 Answers
Rinse the dispenser with warm water.
  • Rob Houg
    Rob Houg Jan 19, 2009
    Keep rinsing with warm water, Run dishwasher on hot cycle with nothing in washer. Also they make some items for cleaning dishwasher Jet dri makes a dishwasher cleaner. But your best bet is to rinse item with warm water
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
The smart soap dispenser on my GE profile dishwasher is not dispensing soap. I filled the smart dispenser several months ago and it does not appear that any of the soap was dispensed. how do i resolve?...
We mistakenly switched liquid detergents and mixed enzyme based and bleach based. They gelled in the dispenser. I took the outer door cover off and could not figure out how to take the white plastic despenser off of the main door without breaking it. I disconected the electrical harness and took the main door off the hinges so I could take it outside, turn it upside down and use the garden hose pressure nozzle to blast the gellout of the white plastic dispenser. I use a piece of plastic coat hanger to poke around inside to break up the gell several times. It all came out in marble size pieces.
Aug 17, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
How do I purge congealed gel detergent from the Smart Dispense bulk dispenser? I've scooped out all that I can and added water to dilute the remaining, but it doesn't want to empty during cleaning cycles....
Part of the solution is on the GE website: http://www.geappliances.com/search/fast/infobase/10010832.htm
But first you must remove or mash the gelled detergent into very small pieces so it can pass through the pump and outlet. You must clean out most of the gelled detergent down in the door going towards the pump and the outlet at the base of the door. You can disassemble the door, or I used a length of 3/8" soft plastic tubing pushed down into the detergent cavity repeatedly to break up and pull the chunks up to the fill door where I could remove or mash them. You may also need to this between the first run of the procedure and the second. You may need to do the purge filling the dispenser with water (I used hot - 120F) more than the once in the procedure.
Jun 25, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Soap not disolving
is it liquid or powder? we had this problem with cascade powder.... tried liquid cascade and the same thing happened even though i'd been using cascade for YEARS.... manual said could be detergent was "old" and beyond its shelf-life, or that we used too much or too little (go figure that one out LOL).... not trying to promote a brand here, but we switched to palmolive ECO gel and haven't had a problem since -- no goop left in dispenser!.... hope that helps... -cynthia :)
Apr 17, 2009 | Whirlpool 24 in. ADG7540 Built-in...
GE Profile dishwasher with ''SmartDispense'' technology is clogged
Check the reservoir hose , and unclog it if necessary. You may need to disassemble the reservoir/dispenser to solve the problem.
Use to the diagrams below:
Apr 06, 2009 | Dishwashers
Soap hardens in the dispenser and dishes don't come clean
Either your dishwasher is not getting the water hot enough to dissolve the powder, or you need to switch brands. Try a liquid/gel type of dishwasher detergent.
Try stopping the washer a few minutes after you start a wash cycle. Open the door -- if there is a lot of steam coming out at you, it's not the water temperature. If there is no steam, your dishwasher is not getting hot water and/or the heating coil is not working.
Dec 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
Rinsing detergent from dispenser
Use gel run a few cycles and help clear and then don't overfill w gel soap
Nov 13, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
There are two different types of dishwasher detergent types, bleach based and enzyme based.  The owner's manual states that if the two are ever mixed that the mixture will congeal, clogging the dispenser.
I don't know exactly how to safely remove the detergent that is in there, perhaps a wet/dry vaccuum.  There is likely a service mode for the dishwasher if it has electronic buttons, in the service mode you could activate the pump that dispenses the detergent.  Use caution, the thicker the clog, the harder the pump has to work and it may fail.  Hope this helps.
Nov 08, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
How do I make sure the dispenser is completly empty?
Just use the manual dispense. The smart dispenser is horrible. You will never get it empty AND you will have congealed soap in the dispenser for ever.
Jul 21, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Soap cake not dispensing
it is highly recomended that you use powder detergent only absolutley no blocks or tabs or gels
Oct 17, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
GE 24 in. GSD6660GSS Built-in Dishwasher Logo
215 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
