Have TV Card but when try to connect to outside atanna with amp get a spark. turn off amp & no spark when connect. Is it save to connect with amp off & then turn amp on. Have no signal without amp.
  • Anonymous Jan 24, 2009
    Just for trying disconnect all ground wires. Solved the problem. Thanks It was a ground problem StarTrec thanks you
Plug the aerial directly into the TV card. I assume you mean by amp you mean an amplified aerial. The spark would suggest an electrical short maybe an earthing problem.
Posted on Jan 19, 2009
I want to know where the atanna hook up is to my tv its pretty tight to wall so i cant see it im going to haVE TO FEEL FOR IT
without knowing which tv it is, im guessing it is the coax male connector in the middle of the tv. you can feel around for it.
Oct 03, 2017 | Televison & Video
My tv does not have direct Atanna connector. How do i get tv broast?
you may use a channel converter to your TV, you can connect it to AV input just like using DVD player and you can watch TV programs by using it.
Oct 02, 2014 | Fujitsu Plasmavision 42" TV
TVS scooty pep plus not starting, changed with new new battery & new spark plug - no spark coming (I have tested the spark plug connected outside touching scooty metal body & start-kicking)
Possibly a bad ignition coil. Check the connections at the ignition coil,make sure they are clean and tight, If so,..then most likely either A: the ignition coil is bad,or B: the pickup on the stator rotor is bad or the rotor could be rusted on the raised portion where the pickup get its signal.
Aug 29, 2012 | 2010 TVS Scooty Pep
I have a no connection error on the printer. There is no computer connection. Refer to device documentation to troubleshoot. I am trying to save photos from camera to computer.
You camera came with either a USB cable and/or a memory card.
If you have the camera software installed, when you plug the USB cable into the camera & computer and turn on the camera, your software will open up and help you save the photos to your computer. If you have a memory card, you can remove it from the camera and insert it into the slot in the computer. Some printers also have slots and should be able to transfer the pics from those slots.
But--either way, the devices have to be on and installed properly
Mar 08, 2011 | Computers & Internet
How do I transfer recorded programs from my 622 DVR to my home computer?
http://www.dishnetwork.com/downloads/user-guides/receivers/622_UserGuide.pdf
User guide. above.
You would have to connect up, using a PC & DVR software and some form of TV/Video recording Card, or USB device. Then connect up via AV, Composite, Yellow, Video. White & Red Audio. and "Capture" either live video & Audio, so basically whatever was viewed on the screen, would be "Recorded" on the PC, via the TV/Video interface device, if using a laptop, then a USB "Dongle" & software would be the best. In a Desktop, a PCI-I card would be Best, Then using the Software that comes with the devices, you "Record" with that and "Play" with the Dish DVR, and save, the Streamed Video & Audio to the PC. Now, If you have Component Out, on the Dish, then this is the one to use, If you choose this way, remember the Device you are going to use Must have a Component INPUT as well, as A Stereo Audio Input, so ensure the device you get has that feature.
Mar 30, 2010 | DISH Network ViP622 DVR DTV Receiver /...
When I turn boot up my gt5220 the monitor briefly flashes and then goes into power saving mode- desktop stays on, fans running and all, until turned off by holding power button down or unplugging it.... my...
first try to connect another power source if it does work that is good then try the other options 1- rams 2- vga card 3- cpu 4- of course there is always the motherboard option....
i had the same problem several times mostly it is the power supply ( the power source ) sometimes gives a weak voltage or amps....
Dec 02, 2009 | Gateway GT5220 PC Desktop
My nokia 9300 is dead, i received a phone call and while i was talking i got the low battery message and then it went off, i tried to turn it on again, it is dead, the nokia logo appears for few seconds...
1. let the battery fully discharged without connecting to power supply,
2. remove memory card
3. remove battery
4. remove sim card
5. insert the sim card
6. do not insert the memory card
7. reset the battery
8. connect to power for charging for 24 hours
9. switch on and it will work
inamul@hudaz.com
+91 94350 62943
Jul 13, 2009 | Nokia Cell Phones
THE VGA PORT DOESNT SEEM TO BE ACKNOWLEDGING THE COMPUTER OR VICE VERSA. ACTUALLY, IT DOES RECOGNIZE IT BUT THERE ARE NO DRIVERS FOR IT , ANYONE KNOW WHERE TO GET THEM
You need to give more information about your set-up for help. What type of computer are you using and what operating system.What type of graphics card. All of these systems have to be compatible with the television input for you to get operation. I found this in the appendix of the owners manual on PROSCAN website. www.oncorpus.com. The customer service telephone for PROSCAN is 1-888-977-6722 The PC Screen continually appears and disappears.
Check the connection between the TV and the computer and see if the connector is locked.
􀁺 A “There is no signal “message appears.
This happens if the signal from the video card is exceeded for the maximum resolution or frequency of the TV. Try to set the
maximum resolution or frequency for the TV.
See if power save mode of the PC functions properly.(This is deactivated when any key is pressed or the mouse is moved)
􀁺 The screen looks like there is water flowing on it.
Check the connector connected to the TV.
􀁺 The screen is unclear and blurry.
Change the frequency and phase adjustment. Change the Resolution and frequency to the standard limit.
􀁺 Unstable and flickering screen.
The resolution and frequency of the PC's Graphics Card should be set within the TV's range. Check the TV menu’s current
mode and standard mode and set it up again.
􀁺 Some modes in standard mode are not working.
Check the compatibility of the video card.
If it is not working for compatible hardware, try to upgrade the driver of the graphics card
May 09, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Zone 2 problem for AVR 3808
It doesnt down convert to zone 2 via hdmi.... must use analog audio or something else.
Jul 14, 2008 | Denon AVR 3808Ci Receiver
D52w20 cable question
You were trying to use the wrong type splitter. You need to call your cable service to find what type would work with your TV. The spark you saw was the difference in ground potential between your TV set and cable network system. The cable company MIGHT recommend a good commercial diplexer, but they usually get real touchy about useing outside devices on their systems. It would be best to have them do the installs
Apr 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Computers & Internet Logo
David Payne
David Payne
