Question about XION Onyx (XON-301P) ATX Case
Power on Problem!!
Ok, Here's my situation: Ive got a top of the line 680 Sli motherboard, 600 watt power supply (also by Xion) and a Xion Onyx case. Unfortunately, i'm finding that parts of the front panel arent working! Both power on buttons aren't working, and I know its not the motherboard, as the manual power on switch on the board turns it on. The reset button works fine, as do the USB ports, but the mic port and the headphone jack don't work eather. How do I fix this? The front panel seems very well secured..so if its a connection there, I have no idea how to get to it.
  • Scott Forand Jun 28, 2007
    The cables are fine. (Kinda hard to mess it up when the cables are detachable from the power supply)
    And if theres more wiring from the front I'm not seeing, then I dont know about it. As far as things go, It looks like I have all my connections in the right spots. As I recall, the only things coming from the front were the USB cables, the colored wires , and the audio cable. I was kinda confused as to where the Power LED cable went..but it seems to work fine. Is it possible I have a bad wire?
  • Scott Forand Jul 06, 2007
    Ok, Just doublechecked my wiring job. Red to red, orange to orange, green to green, blue to blue, and one pin left over beneath them. Everything seems to check out. And if it matters all the labels (like Power SW on both the orange and green wires) are facing outwards.
    The reset button works fine..but its like its not even connected to the power switch.
  • 624 Answers
My two cents worth; I would suggest you actually test the power button with a multi-meter or some other continuity checker. If it truly is bad then if your case is still under warranty you should call before doing any thing else. If you start taking things apart you will wind up voiding the warranty which could get ugly later. With that many things not functioning on the front panel it would seem likely that the front panel board, connector or something else they all have in common is defective. Let us know how it turns out.
Posted on Jul 06, 2007
  • 84 Answers
Did you plug the cables for the front devices and buttons into the motherboard at the right locations? Are the polarities correct on for your cables?
Posted on Jun 27, 2007
  • Brandon Boyce
    Brandon Boyce Jul 06, 2007
    it's possible you have a bad wire but not very likely. You could possible have one of the colored wires from the front off by a pin which would mess up the configuration.
Thanks for your answer i had already done that im expecting it to be my power supply unit not powering everything up like it should when i unhooked my hard drive and cd rom i turned power back on and it...
Hello seaworld,
I believe your right, think your going to need a new power supply. 430 watts is a little low, but should be able to run this board smoothly even with dual video cards. If you do decide on purchasing a new power supply I would go with a 600 watt 20+4 pin, you might think its over kill but power supplies running at peak output over a long period of time shorten their lifespan. Plus its always good to have room to expand.
Good luck
Aug 14, 2011 | DFI LANPARTY UT NF590 SLI-M2R/G...
What power wattage is good for this MB P5N32-SLI SE Delux Motherboard Which power supply
depends on what else you have got plugged in, I would get a minimun of a 400 watt from a good manufacturer, so you will have a good supply of power over the main rails, most cheap 400 watt supply's cant sustain any where near 400 watts
have a google for power supply reviews
Jul 17, 2010 | ASUS P5N32-SLI Deluxe Motherboard
Lost power supply need one. what are amps and volts requirements
just get one like the one that went out. id recommend a 600 watt power supply xion.com has good one
make a list or notes if you must or replace one lead at time and make a note of where it goes before you disconnect it '
the reason im recommending a 600 watt is most power supplies are marginal to begin with in my opinion. so getting a higher rated unit allows you to add accessories you might want to adds
i burned up a chief max 600 watt in a month for some reason replaced it with a 425 till i got a new one and bought a 600 watt xion.com power supply the original was 425 watt. i guess i got what i paid for the chief max was only 28 dolara from 3btech.net (a good site to bookmark
May 16, 2009 | Western Digital External USB 2.0 80 GB...
Whining sound with xion 800 watt power supply.
There is a fan insine the power supply, and also a fan on the CPU. Occasionally there is also a fan on the chassis of the computer itself.
Turn on the computer, take the case off, and listen to identify the source of the noise. If it's inside the PSU, return it and get a new one.
Feb 20, 2009 | XION PSU XION|XON-800R14N 800W RT
Power Hiccups and Cycles
Faulty electrolytics in the power supply. Buy a new one or get it serviced.
Sep 27, 2008 | XION PowerReal 600 (XON600F14T201)...
ATI Radeon HD 3870 problem
Hate to dash your hopes, the chipset (northBridge) is Nvidia and the PCI express slots are also controlled by the Nvidia chips, the 2 pci-express are nvidia-sli supported.
manual
Page XI (11 of 140) Also page 18 (38 of 140)
and finally
Apr 15, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Issue with a In Shin Power Supply
ok, the part # is not the model # . I need the MODEL # of the board to help U .
Dec 30, 2007 | Computers & Internet
New build computer wont turn on (ASUS A8N32-SLI Deluxe Socket 939)
The ATX power supply needs to have pin16(PS_On#) to be connected to COM for it to work. When you press the power switch on the front panel of the computer, you are essentially making this connection. Check that the cable from the power supply to the motherboard is making good connection. You can verify operation of the power supply by shorting Pin16 to pin17 on the powersupply output, with a paper clip. Pin16 is usually a green wire and 17 is black. Hope this helps. -Vish
May 04, 2007 | ASUS A8N32-SLI Deluxe Motherboard
XION Onyx (XON-301P) ATX Case Logo
263 people viewed this question
Top XION Computers & Internet Experts
Daniel
Daniel
JonSnell Electronic
JonSnell Electronic
NOEL
NOEL
Are you a XION Computer and Internet Expert? Answer questions, earn points and help others
