Question about Goodman Heating & Cooling
Plate that covers the evaporator coil on a goodman a/c
4 Suggested Answers
wise_jf
  • 66 Answers
SOURCE: Want to clean evaporator coils on Goodman A/C.
There is an access panels on some package units. If you cant find the access panel then remove the top. I use a garden house. Make sure to kill the power to the unit before servicing.
Posted on Jun 27, 2010
Testimonial: "Very Helpful!! Thanks!!"
  • 230 Answers
SOURCE: How do I clean the
Remove the cover in front of the coil, If the line set runs thru this cover try to slide it out of the way, some units have a triangle shaped sheet metal covering the end of the coil, if so remove.
The dirty side of the coil will be, on the air filter side of the coil, if the coil is very dirty use a vacuum with a with a brush and vacuum off the worst of the debris, some fins are soft so pay attention to them along the process. Using something like 409 and a pump up sprayer or squirt bottle spray the coil, start at the bottom and work your way up, this is so the water will drain into the drain pan.
When using the 409 and water watch that the water is not dripping into the furnace if so use a towel and or something to prevent the drips from getting into the furnace, take your time and be thorough.
Please buy a quality air filter, and prevent having to clean the coil again.
Posted on Jul 12, 2011
What it means 450 PSI on ADP evaporated coil
THIS WOULD BE THE TEST PRESSURE AT FACTORY. UNDER NO CONDITIONS SHOULD NOT EXCEED THIS PRESSURE!
Jul 10, 2014 | Goodman Manufacturing Goodman CAPF3642C6...
What is the correct size for evaporator coils piston ?
.078 is Shipped with Coil
Note: For a properly matched system and piston sizing information, refer to Goodman piston kit chart of the corresponding Goodman
outdoor
unit.
Oct 26, 2012 | Goodman Manufacturing Goodman CAPF3642C6...
How do I access the evaporator coil for my AC unit
Hello, usually it is not a easy task. You must cut into the plenum where the evaporator coil is located and then cover the hole back up with sheet metal. Also, be very carfull when you cut into the plenum so you dont puncture the evaporator coil.
Aug 06, 2011 | Goodman Heating & Cooling
How do I clean the evaporator coil on my Goodman air conditioner? The model number is H36-F.
Jul 11, 2011 | Goodman CLQ36AR49 Air Conditioner
Can I use the same evaporator coil for R410a as r22 when converting over?
no 410 runs at a higher pressure and needs different copper and connections. check goodman dealers, there is a coil drop in replacement.
Aug 12, 2010 | Goodman CLJ30AR32 Air Conditioner
Want to clean evaporator coils on Goodman A/C. It's a roof unit. the Heater, A/C evaporator and condesenor, both fans, are all in this unit. No way to get to the A/C evaporator to clean the coils. How do I...
Jun 27, 2010 | Goodman CLQ36AR49 Air Conditioner
Unit freezes up when nearing 8-12 degree superheat
check to see if your evaporator coil needs cleaning
Apr 29, 2009 | Goodman CLJ30AR32 Air Conditioner
Heating & Cooling Logo
24 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
