I have a GE Select top load 19 cycle, 5 speed washer that is leaking grease from under the agitator. The model # is WW1E0025S. Is this something I could repair myself? I'm thinking the upper transmission seal may be gone. The upper agitator has 2 slots and the lower agitator has a pin hole. Are there special tools to remove the agitator or is there another method that can be used? Thank you
SOURCE: GE Top load washer.
Hello rschneeweis
Welcome,
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins
agitation cycle. If the machine is turned off the water stops leaking
even with the tub full of water.
Let me know if you found it and how you do.
Huuum
Please remember to leave a rating
SOURCE: Remove the agitator
The agitator is actually pressed on without mechanical fasteners . Grab the bottom of the agitator firmly on each side. Pull up with a quick, hard **** (careful not to hit your face). If this does not work, wrap a belt under the agitator. Grab the belt firmly and pull up with a quick, hard ****.
SOURCE: GE Profile WPRE6100G Top Load Washer. The hub nut loosens
You do not have a "high torque" motor (which would have required motor replacement along with these other parts).
Install a new hub washer WH2X1199, split ring WH2X1195, and hub nut WH2X1193. Inspect the hub on the inner basket for wear. If it is worn, the entire SS inner basket (WH45X10060) will also have to be replaced to prevent continued problems. If possible, tighten hub nut with torque wrench to 110 ft-lbs. I hope you did not purchase from Sears. (Sears sold machines are sold with NO FACTORY WARRANTY of any kind. For those, GE will tell you to call Sears.) If not from Sears, you may be able to get some assistance from GE customer relations if you need the inner basket. Your machine was manufactured in Nov. 06, so most likely was purchased over one year ago.
Note: If you look at the board on the top portion of the motor, you should see a LED light flashing on the right front side. It should flash about 1 second on, 1 second off (unless motor running, then .5 on, .5 off) Other flashes indicate various problems. To reset code if necessary, unplug motor for at least 15 seconds, then plug in, wait 3-5 seconds, then open and close lid 5 times within next 10 seconds.
If this does not rate a Fix-Ya for you, please don't bother rating, as I don't like to see my score drop after giving this much free advise.
Thanks.
SOURCE: GE washer won't agitate
I had this same problem with our GE top load washer. I just needed to pull harder. (Note: The agitator is held in place by about a dozen L-shaped clips in a ring around the agitator's base that will release more as you pull harder on the agitator.) Everything from the base below the large fins on up comes out together. Grab the shaft above the fins and pull slowly and hard. I had to take the entire tub out, lay it on the porch, put my feet inside of it, and pull the agitator assembly out. I wasn't able to pull it out while it was still in the washer. BE CAREFUL! DON'T **** IT OUT; that might injure your back; just pull out slowly and as hard as you can without hurting yourself. I was able to get it out successfully, but I am currently stuck at removing the bell below the agitator. Good luck!
SOURCE: GE WBSR3140DW Top Load Washer Repair manual
Check your local Appliance Parts Stores, they usually have racks of repair manuals.
If you get grease-like marks on your clothes after a laundry cycle, and they wash out in the next load, don't despair. It's a sure bet they're caused by detergent and fabric softener that have congealed on the underside of the agitator or along the top edge of the washer basket.
To eliminate the problem, first clean any crud from the gap along the top of the washer basket. Then remove the agitator and clean the gunk off the underside. Since the agitator removal procedure varies by manufacturer, go toallplianceguru.com and search for your make and model. After youve cleaned the agitator, reinstall it and fill the tub with hot water. Next, dump in 8 oz. of washing machine cleaner (Washer Magic is one brand; buy fromamazon.com or applianceparts stores) and run it for a full cycle without any clothes. That should eliminate the problem. If not, repeat the procedure.
Happy Holidays
