Question about Little Giant Submersible Fountain Pump
My little giant pump is not pumping - Little Giant Submersible Fountain Pump
  • 156 Answers
SOURCE: sump pump
The big cylindrical thing at the end of the wire hanging is the switch. I believe it is a mercury switch. Try hitting this a little and see if it stops. Sometimes they get stuck. If this doesn't help, then replace that piece. Hope this helps.
Posted on Jul 06, 2009
  • 990 Answers
SOURCE: I want to replace an impeller for a Little Giant submersible pump
This is a plastic impeller on a brass hub. If the impeller is loose it is probally cracked or overheated and melted, ether way you will have to break the impeller off of the hub then you will need to break hub loose from shaft. You can do this by putting pump in a vise and putting a pair of vice grips on hub and giveing them a sharp hit in a counter clockwise direction. you will need to replace the seal and impeller and should check to be sure than you can get these parts before you start.
Posted on Aug 24, 2009
  • 990 Answers
SOURCE: need to add oil to a little giant pond pump
If you have to add oil it is time to replace pump.
Posted on Aug 25, 2009
  • 460 Answers
SOURCE: Active Pump Will not shut off.
shutoff float/switch is stuck.. replace the pump.
Posted on Nov 07, 2009
  • 990 Answers
SOURCE: Fountain pump motor runs but no pressure to push water
You can try to force prime with a garden hose. Put the hose in ether side suction or discharge.
Posted on Jul 07, 2010
How to disassemble Little giant pump model#psm006?
thats why i like the little giant pumps they are put together with phillips screws not glued like them other guys , i do suggest that if you dissasemble pump and water has gotten inside , replace it not just seal it up and go , wont last long as that means the pump shaft seal has leaked , ther e has been a few folks that add dietary mineral oil to the inside , for use in very deep ponds (over 3 feet) they believe that helps keep the water out
Jun 11, 2014 | Little Giant Submersible Fountain Pump
MY LITTLE GIANT PUMP IS BRAND NEW AND THE AUTO FLOAT DOES NOT TURN PUMP ON
Take it out and back, dont waste your time with a defected product. It will only cause you more work later
Sep 07, 2011 | Little Giant Tools-Products - 5 Asp...
My new Little Giant 8-CBA Pump is hooked up underwater and plugged in. Not a sound. Electricity is working. And it's the same pump we have had for the last 7 years.
You say it's new? On some pumps they will secure the float switch when shipping. Be sure you followed directions and removed anything that may interfere with the switch.
Apr 21, 2011 | Little Giant 8 Cba, 4/10 Hp, 45 Gpm...
Nov 07, 2009 | Little Giant Submersible Sump Pump, 1/4 Hp
Little giant pump stopped working
Hi Tom (and Lindsay?),
Ok lets get a little more info,
  1. Plugged in? (Have to ask)
  2. Does it run and not pump?
  3. Does not run?
  4. Tried moving the float switch?
  5. Pull the pump and see if the intakes are clogged
Please comment back with your findings
Mike
Apr 18, 2009 | Franklin ELECTRIC/LITTLE GIANT PUMP 1/4HP...
Little Giant Submersible Fountain Pump Logo
71 people viewed this question
Top Little Giant Garden Experts
J.D. Browning
J.D. Browning
Jim Goldsmith
Jim Goldsmith
Mike Squire
Are you a Little Giant Garden Expert? Answer questions, earn points and help others
