Question about Bernina Sewing Machines
Bernina 1360 sewing machine moving needle
I cannot find a way to moved the needle left or right on my sewing machinee
SOURCE: Needle won't move on Bernina 930
If the machines motor is running but the needle isn't going up and down then the baste stitch finger is gummed up and needs to be serviced.  This is a simple fix and it happens all the time on those machines.  Take it to your local Bernina dealer for a standard service.  Also if you really need it in a pinch try pushing up on the needle bar that sometimes will fix the problem but it will still need serviced.
Posted on Oct 22, 2007
RickE1
  • 202 Answers
SOURCE: My machine Bernina 830 does not run.
Rose, most likely your machine is gummed up and needs oiling. A product called Tri-Flow is best. It can be purchased at most any hardware store. Or just use normal sewing machine oil. Open the top and put a fair amount of oil down behind the knobs and let it soak in. As it soaks just wiggle the knobs or turn them little by little back and forth until they free up. Don't force anything as something will break.
Good luck
Posted on Nov 29, 2008
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
SOURCE: singer stylist sewing machine 534 is not stitching
Feed dog drive gear(2) are plastic and are probably stripped. Always replace them in pairs. While you are at it replace both hook drive gears as well. It will run as good as new.
Posted on Mar 28, 2009
  • 22 Answers
SOURCE: emy bernina 930 electronic has power but the
The problem with your machine is the basting unit is seized, this unit is located on the needlebar asm. You can take it into a dealer to fix or if you would like to fix itself I too can help you with it. If you take it to a dealer that estimate price to fix it is around $100.00
Posted on May 03, 2010
Needle position problems
Please tell us the make & model machine.
Aug 14, 2017 | Sewing Machines
I can't get the needle to move laterally. Trying to put the zipper presser foot in
Even though you push the needle positioning button, the needle does not move right or left?
Bring it in for service.
Feb 05, 2016 | Bernina Artista 180
My needle is not movin up or down..switched to zig zag and it moved left and right but no up and down..Im lost without it..whats wrong and how do i fix it? Bernina 1090 s
Have you oiled your Bernina recently/regularly? Consult your owner's manual under the Maintenance section. Sounds like the old oil may have dried and is prohibiting the needle bar from moving. Use good quality (ie Bernina) oil, not 3-in-1, WD-40, cooking oil, or the sewing machine oil from your grandmother's sewing basket). To help free it up, direct heated air from a handheld hairdryer into the interior mechanism of the machine, concentrating on the needle bar area.
Aug 19, 2015 | Bernina Sewing Machines
Bernina 930 change needle position
Look at the knob which creates the zig-zag stitch (1-4) at the top right of your 930. In the center of that is a silver knob that rotates right and left. That silver switch moves the needle position right and left.
Mar 22, 2015 | Bernina Sewing Machines
How do I change the needle position on my Bernina 1630?
Not sure, but if this is the one with the track ball, try pushing in on it to activate needle position.
Nov 18, 2014 | Sewing Machines
Needle won't move with move on but move free with motor off
You are describing a Bernina computer machine? With the machine on, the needle cannot be moved laterally because the energized step motor is holding the needle center position, With the machine in the off condition, the needle can be moved which is a normal condition. Your concern did not describe a problem but rather a condition that is totally normal. Please be more specific. SewTechnical Home ">
Sep 11, 2013 | Bernina Sewing Machines
Bernina 1630
I have a Bernina Virtuosa so not the same machine - but this may help. There is an icon on the front of the machine - it is a needlepoint pointing at a dot in an oval - there are arrow buttons on either side. These move the needle left or right of center and it shows on LED screen. I checked mine just now and if you turn machine off and on it resets to center automatically. Hope this helps - Happy Sewing!!
Dec 15, 2008 | Bernina Virtuosa 160
Sewing Machines Logo
59 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
