Question about Eclipse T180 MP3 Player
My Eclipse T180 wont turn on. I've had it plugged in bothe on my Pc for 24 hrs , no dice and to a wall jack, still no dice
3 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: i just bought the eclipse cld and it won't turn on after charging for hours
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Posted on Oct 01, 2012
SOURCE: my eclipse 180rd wont turn on
it quit in the middle of a song and now i can't get it to turn back on
Posted on Oct 03, 2012
Gravley zero turn kawasaki 24 hp engine wont start
It seems to be getting spark, check is it or isn't it?
Jun 20, 2017 | Cars & Trucks
Poor contact with ear bud jack. Can this be fixed?
You can try to clean the headphone jack with rubbing alcohol. Use a q-tip. Just moisten q-tip as you don't want lots of liquid running into your device though the alcohol will dry quickly.
If it is a loose connection, you may have to open your device and need soldering skills to fix it. Try cleaning the jack first.
Feb 22, 2016 | Eclipse T180 4gb 1.8" Touch Screen Video...
My 1995 mitsu eclipse is sputtering and has trouble staying on when I turn it on for the first time in more than 5 hrs. It also stalls and throws me an oil light. I've changed the spark plugs (which...
Coil battery circuit may be loose or corroded causing the recurring code/light . Which code number are you getting ? Have you cleaned the throttle body and IAC as that can cause idle issues .
Apr 10, 2017 | Cars & Trucks
I just bought the eclipse cld and it won't turn on after charging for hours
Sep 30, 2012 | Eclipse Audio Players & Recorders
My Microsoft Xbox 360 Pro's power brick wont turn
You can try to Reset the AC adapter by following steps below.
1. Unplug the xbox 360 AC adapter at both ends (from the back of the system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
If this doesn't work it's probably fried from the power surge.
Jul 31, 2012 | Microsoft Xbox 360 Console
Why wont my Gateway NV53A36u turn on ?
if your charger is ok then it will be a problem with the dc jack (where your charger plugs in to) or your actual motherboard.
Jul 29, 2012 | Acer Gateway NV53A36u
Wii wont turn on
Try this:
1. Unplug the Wii AC adapter at both ends (from the back of the
Wii system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.Reset the AC adapter by following steps below.
Jun 27, 2012 | Nintendo Wii Console
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
I have the canon mx870. I cannot get a dial tone. We've tested the the telephone jack and the wires with our telephone and theose work fine. How do I get a dial tone?
Check to make sure you've got the phone cord plugged into the correct port on the printer. There will be one with a picture of a telephone and another with a picture of a wall jack. Use the wall jack port and you should get a dialtone.
May 06, 2011 | Canon PIXMA MX870 Wireless Office...
Phone won't charge or turn on
it seems you have not charged your cell for initial 24 hrs and used the mobile as per the policy of every mobile company. Anyway, switch off your mobile and keep it on charging for next 24 hrs. In case it doesnot works after that also, go for replacement with the vendor.
Jun 15, 2009 | Sanyo Katana Eclipse X Cell Phone
Eclipse T180 MP3 Player Logo
308 people viewed this question
Top Eclipse Audio Players & Recorders Experts
henrysmooth
Level 1 Expert
Joseph Hoffmann
juanmireles1
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
