Question about Sharper Image MC502 System
Wireless headset Will the wireless headset work on a non amplified output from the tv or do you need an external amp
  • 336 Answers
You do not need an amplified signal. The signal is amplified in the head set. You may need to change the audio settings on the TV change from internal speakers to external amp and/or change from variable to fixed audio out.
Posted on Jan 19, 2009
What are connections and connectors for audio output to wireless headset
Hi Richard,
First, you'll need to determine which type of input(s) the wireless headset transmitter has. Most common is the 3.5mm stereo plug designed to slip into the headphone jack of a TV, MP3 player, cell phone, etc. Some transmitters have adapters in the box to allow connecting to the Left and Right channel RCA / phono style jacks found on other components such as CD, DVD, VCR, Stereo receivers / amplifiers, etc.
You'll need to find OUTPUTS of the CD and TV that match the plug on the wireless headset transmitter. If yours doesn't include adapters to go from say the RCA jacks mentioned above - to whatever connector that the transmitter input has - you'll need to go to your local Radio Shack store or similar store to see if they can provide an adapter that will allow you to connect.
Here are a couple plugs / adapters:
Above: A "3.5mm stereo patch cable". Your transmitter may have a cable with an end like this to plug into the TV's headphone jack.
25683604-gy4zxbmnj5ndu14q12lmwneo-2-1.jpg Above: A "3.5mm female stereo jack to RCA stereo male plug" adapter that would allow the top cable to connect to the Left and Right audio output jacks on a typical CD, DVD, etc. device.
These cables / adapters are typically $5 to $10 maximum.
I hope this helps and good luck!
May 07, 2015 | RCA Televison & Video
How can I hook up wireless headsets to direct tv box?
You must have wireless transmitter provision in your TV,to get connected to Headset.
Or you may buy suitable external wireless transmitter and connect it to your TV ,audio output and receive audio,in your head set.
May 03, 2014 | Sony Audio Players & Recorders
Would I need a mixer or amplifier with this product: Pyle-Pro Rack Mount 8 Channel Wireless Microphone System with 8 Lavalier/Headsets (PDWM8900)
The unit has a built in mixer as well as individual outputs. You would need an amplifier/speaker that could receive from teh mixed output jack of this. Use BALANCED TRS cable.
Aug 20, 2011 | Pyle PRO 19 RACK MOUNT PRO DJ MIXER SFX
I do not have a credit card. I have connected my wireless headset to the TVs audio out on the back and it works great. My problem is I can not mute the TV speakers, so the sound is comming from both...
Try just turning the volume down on the TV. The audio power to the red/white output jacks should be the same at any TV volume since it is expecting you to control the volume with an audio receiver or other amplifier.
Good luck.
Please rate me
Mark
May 05, 2011 | Curtis-Mathis Televison & Video
Lg 42LH30 tv trying to connect a Sennheiser w/l RS120 wireless headset and I do not see an audio out connection on the back of the tv I looked up the specs of the tv and the only audio out I see is...
This is an optical digital audio output that uses optical fiber with Toslink optical connectors at both ends, from there it comes the name, since your wireless headset has only analog audio input, you'll need an optical digital audio to analog audio converter, to connect your wireless headset to your TV.
Mar 18, 2011 | LG 42LG30 42 in. LCD HDTV
Wireless headphone hook up
Hello depends on how you hook it up as thee are several ways.
many receivers will output sound through the headphone jacks even when the speakers are left on.(my receivers require that you manually turn speaker A off when using headphones)
it may be possible for you to connect the headphones to a tape output but this will require headphones that have a volume control on them or an external.volume control knob.. You may encounter a problem as I am not sure if a tape output will provide enough signal to drive a pair of headphones. this would not be a problem if you use a pair of WIRELESS headphones as they have their own power source onboard..
A set of wireless headphones could also easily be connected to the output on the back of the TV but assuming you have your receiver plugged in to the TV audio out you may need a couple of Y adapter cables.
Also if your receiver has a pair of PRE OUT jacks those would work to power a set of wireless headphones may also power a wired set but once again not sure on power as I have never needed to try it.
Hope that helps a bit
Jan 09, 2010 | Audio Players & Recorders
Proscan 32lb30Q. I need to hook up wireless
You can buy a digital to analogue converter that connects to your COAX digital output and then connects to you RCA jacks. They run around $75. The only problem I've encountered is the DVD does not work through the COAX output, just TV. I'm looking into it.
Jul 01, 2009 | Proscan 32LB30QD 32 in. LCD TV
Can these be hooked up so you can hear the tv external speakers as well?
I have the headset running through an amplifier so my wife can listen at her volume level and I can adjust the headset volume for myself. The volume dial on the amp is set to zero; but the audio output jacks still provide plenty of volume to the headset. You can get a reasonable amplified for $100 or less
May 27, 2008 | Sony MDR-RF970RK Headphones
No sound from TV to headset
I suspect that your TV audio output is digital and your wireless headset amp is analog..........the two won't work together.
Dec 10, 2007 | Recoton Advent Radio Communications
67 people viewed this question
Top Sharper Image Audio Players & Recorders Experts
woodzowl307
Tom Chichester
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
