Question about E-Machines W Computers & Internet
Emachies w3609 3 beep codes - W E-Machines Computers & Internet
  • E-Machines Master
  • 27,725 Answers
Verify that the keyboard is connected properly to the computer by turning off your computer and then disconnecting and reconnecting the keyboard to the computer. Stuck key Ensure that there are no stuck keys on the keyboard. If all keys appear to be ok and you have a standard desktop computer with keyboard, turn the keyboard over and gently hit the back of the keyboard to loosen any dirt or hair that may be stuck in the keyboard. Bad keyboard Try another keyboard on the computer to verify that the keyboard has not gone bad. Bad PS/2 or AT port If all of the above solutions are not able to resolve your issue it is likely that the port on the back of the computer may be bad and the motherboard or I/O board may need to be replaced. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules make sure that your RAM modules and Cmos battery are securely seated on some motherboards Cmos batteries are soldered in Test all power and data leads that attach from motherboard to your hard drive IDE SATA make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40 pin ide it will be the first to fail check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it restart your computer the found new hardware wizard should activate a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function. Hope this helps.
Posted on Jan 04, 2013
How to turn on bluetooth on my emachiness em350
Check the control Panel, It will have Bluetooth Icon or Device Manager will show under networking, Bluetooth device. Check if is enabled. If it is disabled you can enable it from here.
You might also have to check View in Device manager for hidden devices.
Sep 27, 2014 | Computers & Internet
Tip
Computer POST and beep codes The computer power on self test (POST) will test...
The computer power on self test (POST) will test your computer to make sure it can boot properly(test hardware and sys requirements), once it does the computer will then finish the boot process. Normally, if your computer passes the POST test it will beep once or possibly twice. If the computer fails the POST then it will either not beep at all or generate a beep code.
The beep code you receive can indicate what may be wrong with your computer. The beep codes vary depending on your motherboard BIOS manufacturer(AMI, Award, Phoenix). You can find what BIOS you are using by paying attention to the BIOS screen when your computer boots up. It should tell you what brand BIOS.
You can usually find the meaning of your beep code by doing a simple google search i.e "phoenix beep codes". Below, I have provided links to sites which go over beep codes and their respective meaning.
AMI BIOS Beep Codes
Award BIOS Beep Codes
Phoenix BIOS Beep Codes
-G33k
Keywords
computer beep codes, post beep codes, bios beep codes, computer beeps, computer will not start beeps, computer beeping, pc beep codes, award beep codes, phoenix beep codes, Ami beep codes
on Jul 27, 2011 | Computers & Internet
What does the video input cord look like on an emachie model numberSHW-160P6S because i am not getting any video
If you are using VGA, the video cable has a blue, 15 pin D-sub connector at each end; DVI connectors are usually white with a blade connection at the top and 27 pins at the bottom of a D-sub connector.
Sep 11, 2014 | Computers & Internet
When rebooted computer beeps 3 times and will not turn on
Is it a long beep or a short beep? Beep codes are used by the BIOS during the POST to report certain initial system errors.
If you're hearing beep codes after you turn your computer on, it typically means that the system has encountered some kind of problem before it was able to display any kind of error information on the monitor.
Follow the steps below to determine what system problem the beep code is representing.
Difficulty: AverageTime Required: Anywhere from 10 minutes to a few hours depending on the cause of the beep code
Here's How:
  1. Power on the computer or restart it if it's already on.
  2. Listen very carefully to the beep codes that sound when the computer begins to boot.
    Restart your computer if you need to hear the beeping again. You're not likely to make whatever problem you have worse by restarting a few times.
  3. Write down, in whatever way makes sense to you, how the beeps sound.
    Important: Pay close attention to the number of beeps, if the beeps are long or short and if the beeping repeats or not. There is a big difference between a "beep-beep-beep" beep code and a "beep-beep" beep code.
    This is all important information that will help determine what issue the beep codes are representing.
  4. What steps you take to solve a particular beep code will differ depending on the BIOS manufacturer.
    Choose the correct beep code troubleshooting guide below based on your motherboard'sBIOS manufacturer:
    Tip: Not sure what brand of BIOS is on your motherboard? See this How To Determine Your Motherboard BIOS Manufacturer guide for some helpful advice.
Tips:
  1. Still can't figure out what the beep codes mean? Let a community of computer support enthusiasts help out! Post the details of your problem in the PC Support Forum.
Jan 03, 2013 | Dell Precision T5500 Computer Workstation ...
Usb port replacement or restore on loptop
Try www.ebay.com Type: usb port replacement, or www.emachies.com contact customer support and the technical department, or a computer repair store.
May 23, 2012 | eMachines Computers & Internet
When I turn my emachies laptop on it shows the logo then goes to a blank screen I can access setup menu but it won't boot up help it's the64bit version I beleave I've tried everything I know I think the...
Bring up task manager (Ctrl+Alt+Delete)
click applications tab
click new task
type in explorer.exe then click okay
If it boots up go to www.malwarebytes.org and download the free version. Install, update, and run a full scan.
Delete anything it finds.
Sometimes this works, sometimes it doesn't.
Good luck
Oct 05, 2010 | E-Machines eMachines Desktop PC
I have a emachiness t3642 with AMD athalon processor. I tried to upgrade the cooling fan located on top of the processor. when I pulled the aluminum heat sink of, the processor came of too. I put the...
This is normal as the processor just sits on the connectors. Just put it back and reconnect the heat sink properly.
Make sure that you do not bend the nearby power supply capacitors in the process. There is a separate cord (four prongs) to supply power to processor, check if it is securely connected.
You should not have undertaken the task if you were not sure in the first place. Without visual inspection I can only give generic solutions.
The processor must be seated properly with the heatsink and then turned on. If it is turned on without the heatsink it will burn/overheat immediately. If the processor is not seated properly, the pc will not turn on. Just follow the correct seating procedure and try again. Remember not to bend or break any connectors and capacitors nearby.
If it still does not turn on, you may have bent processor contact pins. This means bad news but can be handled. Take a magnifying glass and inspect the processor and seat and check for bent pins. You can use tweezers to adjust if any found. If your pc makes any beeps, let me know or consult the manual for beep codes.
Sep 25, 2010 | eMachines T3642 Refurbished AMD Desktop...
Computers & Internet Logo
42 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
