Question about Coleman Mobile Modular Home Electric Furnace Eb10 Eb10c
Why does my Colman EB10C electric heater start & run for a few seconds,stop, then restart & run?
I replaced the thermostat with a new digital Honeywell but it did not help. The thermostat works like it should but the heater does not turn on right away sometimes. I can hear clicking sounds coming from inside the furnace before it turns on. Furnace is only 2 years old and installed in 2010 mobile home.
    Problem Solver:
  • 10 Answers
Check your high limit switch find blower motor and unplug white wire let furnace run it should shut off when hot enough if same problem replace high limit switch
Posted on Jan 04, 2013
5 Suggested Answers
  • 9 Answers
SOURCE: 29 year old Coleman Gas
All coleman gas units is incoperated with a secondary inner stat. It resembles a pie with numbers on its outer edge. Usually silver and the numbers span from 50 to 300 on the top and likewise on the bottom. You must not turn it clockwise. Refer to specifications of manufacture to allow proper function.
Posted on Aug 21, 2008
motor1258
  • 6674 Answers
SOURCE: have atwood furnace and coleman mach thermostat
It may be your thermostat, but try this first to see if time delay relay may be sticking. When it won't shut off, turn propane off, and go outside and unscrew the 2 screws that hold your cover on, and lower the cover down. Look straight ahead, attached to the housing of the fan up near top you'll see a square relay (time delay relay) with 4 male spade connectors, and wires attached to each. It's usually held on with 2 Philips screws. Give it a little rap with the handle of a screwdriver or similar a couple of times, and see if fan stops running. While your there as well, pull the wiring connector off the ignition board, and put back on a couple of times, to clean the connections. Now try it again, and let me know what happens.
Posted on Apr 26, 2010
shastalaker7
  • 1515 Answers
SOURCE: coleman mach furnace wont stay running. i turn the thermostat down until i hear it click, then i turn it back up to get the furnace to kick on.works sometimes and sometimes not. blower will always kic
Hi, I don't know if you are still having a problem, but it sound like the flame sensor on the unit is dirty and need to be cleaned. If it has a automatic pilot, it will have a flame sensor. Its made of porcelin with a metal rod coming out the end, laying next to the pilot flame. Just 1 screw holds it in place. Remove it and clean the tip with steel wool or a piece of sanding cloth. If you don't have this set up, I would need more info on the unit, model and serial number. You may also have a faulty thermostat, but I do believe it is a flame sensor.
Shastalaker7
Posted on Dec 01, 2011
SOURCE: Coleman mobile home furnace Model
I had a similier problem, Check your neutral ground? also alot of power companies will come out and do a basic check of the voltages going to the furnace, and can offer advice for free.
Posted on Dec 17, 2011
Thermostat clicks on then off quickly repeatedly when heating but does Not turn on heat. Until I manually turn thermostat to Off on Heat/AC and manually turn Fan Switch to Manual On for 10 seconds. Then...
Hi Daniel
My name is John
Remove the thermostat from the wall. Jump the R & W and see if the heater countinues to run if it does then you have a bad thermostat
Mar 13, 2015 | Heating & Cooling
Electric furnace/air handler short cycles
check that the replaced thermostat is the same temp degree setting of the last one
Dec 16, 2013 | Goodman Heating & Cooling
6 year old colman furnace codes 1 blink ignition failure. Turn heater off at thermostat it cycles and heatsd house restarts a few times. alot of clicking noises and codes again a few cycles later. works...
I had the exact same issue and replaced the control circuit board, igniter, flame sensor, and thermostat just to discover the real problem was a rusted out Roof Jack. (The exhaust pipe that goes through the roof. The inner fresh air pipe was rotted out so the furnace was sucking exhaust gases in which would not support combustion. Have your's checked.
Oct 24, 2013 | Coleman Propane Forced Air Heater...
How to test electric water heater thermostats
1) Copy following links:
http://waterheatertimer.org/How-to-test-water-heater-thermostats.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
2) There is no reliable way to test electric water heater thermostats.
This is because testing requires rotating the temperature selector, which may cause stuck-thermostat to temporarily unstick. So thermostat appears to work normally.
Moreover, thermostat come out of calibration over time, and the temperature selector might be on 125 but tank temperature at 100, and there is no specific way to measure calibration.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
3) I think it easier to replace both upper and lower thermostats to eliminate them as suspects when diagnosing wide-range of electric water heater problems.
Dec 07, 2012 | RELIANCE ELECTRIC WATER HEATER
Fer211as heats but wont dry! heating element comes on but kicks off after gets to temp then element will not come back on unless stopped and restarted?
Runs but will not heat
1.loose wiring--check terminals & wiring
2. Defective thermostat--replace thermostat
3.defective centrifugal switch in motor--replace switch (check linkage to motor)
4. Defective timer--replace timer
5. Open heater element---replace heater element
6. Heat switch set to off----set switch for desired heat
Sep 22, 2011 | Frigidaire FER211A Electric Dryer
2002 dodge ram starts for a few seconds then stops wont idle was running fine before
Fuel pressure would be a good place to start, check that, When you turn the key to the on position, the electric pump should run for a few seconds & build pressure.
Is the engine light on? If so run a scan and pull the codes.
After it dies and you try to restart, is it getting fire to the plugs? Let me know what you find.
Jul 14, 2011 | 1994 Dodge Ram
Water was much hotter this morning, actually steaming when faucet turned to max. I checked thermostat & reset button, seemed to be normal. I shut off power and pushed reset button, waiting for it to...
I would try it again and if water temp is still to high then I would adjust thermostat down to say 120 degrees and see what that does.If problem continues I would replace thermostat. Thank you
Dec 20, 2010 | Reliance & 50gal Electric Water Heater
I HAVE A CARRIER GAS FURNACE APPROXIMATELY 10 YEARS OLD. IT WAS WORKING FINE LAST FALL. I JUST STARTED USING IT AGAIN AND NOW ITS STARTS UP AND THEN STOPS, STARTS UP AND THEN STOPS? IF I PLACE THE HEATER...
you may need to replace the thermostat or the thermostat batteries if applicable. To replace the thermostat follow the instructions on the new thermostat. Make sure to set the thermostat to the gas setting(see instructions) this should cure your problem. Good Luck on the repairs
Dave
Jan 05, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Electric Kenmore Dryer runs short time (seconds) and then stops.
your thermostat/s are not doing their jobs. They are allowing your dryer to overheat and also if your dryer has not been cleaned out on the interior you might want to do that. I've taken out globbs of lint build-up in them.
Mar 25, 2009 | Dryers
Electric space heater contactor won't stay latched
Jumpered the bimetal thermostat and everything worked smoothly. Tried to clean contacts in thermostat with no luck, so ordered a replacement. At least it was cheaper than the contactor.
Dec 07, 2008 | Fahrenheat Ceiling-Mount Industrial Heater...
Coleman Mobile Modular Home Electric Furnace Eb10 Eb10c Logo
135 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
