Question about LG DLE2101 Electric Dryer
Dryer beeps while drying
When drying close, the dryer begins to beep constantly with a high-low, high-low beeping sound. The child lock is engaged during the drying as well. It works fine, but I am worried that there is an underlying issue. Not sure why this is happening or if there is a manual that explains what the beep sequences mean.
    Problem Solver:
  • 8 Answers
Most likely you have an excess of lint hampering air flow from the dryer. Vacuum out lint filter area, gently remove aluminum exhaust duct behind dryer and make sure it is clear and debris free. Also check exhaust duct port on back of dryer and that the vent going out of your house is clean and not stuck closed or clogged.
Posted on Jan 04, 2013
  • 92 Answers
SOURCE: LG DLE2532W Electric Dryer doesn't allow adjustment of drying options
it may be possible the contol is bad can you change the settings at all
Posted on Feb 10, 2008
SOURCE: Child lock setting
I had the same problem...called LG and they said just reset the dryer by unplugging the dryer....I couldn't reach the plug so they told me to trip the breaker switch and that would also reset it....problem solved
Posted on Apr 08, 2008
  • 489 Answers
SOURCE: Dryer doesnt do anything besides a loud noise
What kind of loud noise??  A loud electrical noise??  A loud squealing noise??
It's possible that there is a foreign matter inside the filter chamber jamming up the blower fan.  Pull the filter screen out and look down the filter chamber area and see if there is a sock jamming the fan from turning.  If you can pull it out, that should resolve your problem.  If not, you may need to call a qualified LG technician to resolve this issue.
Posted on May 02, 2008
  • 57 Answers
SOURCE: LGE59777S Not drying
There is a little sensor that tells the dryer when to heat and when not to heat. that sensor is bad. If you take the back of the dryer off you will see it. It is about the size of a half dollar and has 2 wires that plug into it. While you have it apart make sure that the dryer vent on the back of the dryer is not plugged with lint. Major cause for fires in dryers.
Posted on Jan 04, 2009
SOURCE: How do you turn off the child lock feature if CL is showing?
To unlock, press and hold DRY LEVEL for 3 seconds. The indicator light turns "off".
Posted on Aug 31, 2009
Hi my condenser hotpoint Aquarius dryer TCL770 keeps beeping when drying ?? All filters clean ?? Do I need to look at the back by pump maybe .? Thanks
I also have the same dryer with a constant beeping while trying! Did as suggestion 4 and then took the back off, cleaned the heater matrix and thermostats, checked the rear draining pipes...so far so good!
Sep 15, 2014 | Hotpoint Dryers
How to turn off the child lock on a dryer
This information is from the manual:
Child Lock can be used to prevent your children from changing options on control panel while the dryer is running. When child lock is enabled, all the buttons will be locked and Child Lock glows. To enable Child Lock, Press and Hold OPTION for 3 seconds, A single beep tone is heard and Child Lock is displayed on the status window. To disable child Lock, press and hold OPTION for 3 seconds again.
May 27, 2014 | LG DLE2514 Electric Dryer
What does beeping mean during dry cycle?
My dryer did the same thing, it was so distrubing noise in the middle of drying cycles, so I turned off the sound switch it went away, now it doesn’t peep any more.
Oct 28, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
My child lock on my Frigidaire is constantly beeping... The door is not locked but it is beeping...
Hello Shelley, thank you for your inquiry!
I understand your Frigidaire is constantly beeping while they door is unlock, however do you have a range or microwave Frigidaire appliance? The serial tag for a range, which lists your model number, is typically located in the storage drawer, on the right side and the serial tag for a microwave is in the lower left corner as you open the door. With this information I can better address the issue at hand. Thank you!
Oct 22, 2013 | Frigidaire Over-the-Range Microwave
Child lock is stuck on and athe dryer will not turn on. How do yoiu turn off the child lock?
HI!!
Child Lock can be used to prevent your children from undesirable use on control panel while the dryer is running. When Child Lock is enabled, all the button will be locked and Child Lock glows. To lock Child Lock, Press and hold Rack Dry for 3 seconds, A single beep tone is heard and CL is displayed on the status window. To unlock Child Lock, press and hold Rack Dry for 3 seconds again.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Jan 03, 2011 | LG DLG5988 Gas Dryer
Kenmore dryer beeps constantly
End of Cycle Signal
The End of Cycle Signal produces an audible sound when the
drying cycle is finished. Promptly removing clothes at the end of
the cycle reduces wrinkling.
@ H_GH
@ LOW
@ OFF
END of CYCLE S_GNAL
Press END of CYCLE SIGNAL to adjust the sound level or turn off
the signal.
NOTE: When WRINKLE GUARD _ is selected and the End of
Cycle Signal is on, a tone sounds every 5 minutes until the
clothes are removed, or WRINKLE GUARD _ ends.
Sep 15, 2009 | Dryers
Beeping with no boot up
Beep codes mean something has gone wrong with the computer. Beep codes most likely happen for: Memory, Processor, Motherboard.
Try reseating the memory in the computer.
Jul 11, 2008 | AOpen XC Cube EZ65 Barebone
My dryer keeps beeping after 30seconds of turning it on. I have pressed the 'LOCK' key to unlock & even then it still does the beeping thing! Could this be the motherboard packing up?
I had the same problem. My wife was about to take an axe to the darn thing. The frustrating thing was that it was beeping 3 times and the status lights were flashing. The manual only described 4 beeps (Dryer ran too long) or 6 beeps (Push button does not function). It finally dawned on me that it was beeping two sets of three beeps (i.e 6 beeps). The corrective action was to press buttons lightly and release. I pressed on every button first lightly then heavily with no success. I pounded on the instrument panel; still no luck. Finally I pressed the Options button and the Select button simultaneously for a second and heard a click. After that, no more beeping. According to the manual this activates a "LOCK' feature if you hold them down long enough. But in my case, the lock light flashed but didn't engage and after the beeping stopped, I left well enough alone.
Hope this helps.
Jun 22, 2008 | Dryers
Beeping in my Neptune Dryer
This is a mystery to me. Try typing into google "beeping sound on Neptune dryer". There may be a solution on there from Neptune or someone who has had a similar problem.
Jun 14, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Beeping
it could be the door switch had Samsung has had trouble with the tolerances on the doors.. the door switch will also keep the light on and the temperature will be unstable. you can test it by covering the door switch with some blue masking tape to hold it in and see if the beeping will stop...the other problems with the display sound like a faulty control board.. let me know if the beep stops..I would call samsung if it is still under warranty...
Aug 30, 2007 | Samsung RS2534 Side by Side Refrigerator
LG DLE2101 Electric Dryer Logo
295 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
