Question about Sony BDV-E780W
Sony blu ray bdv-e780w disc tray won't open
4 Suggested Answers
  • 74 Answers
SOURCE: Upgrading dvd to blu-ray - how can I use my existing surround sound speakers?
Unfortunately because your existing system does not have the option of connecting an external source, such as another DVD player, the only option you have is to reuse your existing speakers and purchase another amplifier. Trying to patch another DVD into your existing unit would require a bit of technical expertise which would be more trouble than it is worth. The all-in one concept is convenient but very limiting in terms of expansion.
Posted on Oct 11, 2008
ssemul
  • 202 Answers
SOURCE: Sony BDV-E300 doesn't open Tray
See the below side of the set there is a hole use hair pin to eject your disc.Do not too much force on it other wise you will broken any part.
Posted on Oct 30, 2010
welcomejee
  • 10594 Answers
SOURCE: Hello, I bought Sony BDV-E570 region
I'm afraid, there is no way to change region code of any Sony DVD or BluRay Player.
I'm sorry for that but this is fact.
Thanks.
Posted on Apr 01, 2011
Stuck in demo mode / demo lock
Put the unit in dvd mode. then press and hold the stop and eject buttons. The display should read "demo off". Then the tray should operate normally.
May 28, 2013 | Sony BDV-E280 Home Theater System - 3.1 3D...
The dvd tray on my Sony BDV-E780W won't stay closed. Whenever I turn it on the tray opens and wont close from the remote or device.
Have you checked to see if it is off track? Sometimes when these machines get bumpbed, dropped, or fall they can jump track. You have to take the cover off and inspect to see if it is off track when it closes and opens. It should go all the way back on the track when it closes. Be careful not to shock yourself. If it is on when you do it and your hand touches the metal parts inside you can get seriously burned or shocked.
Dec 01, 2012 | Televison & Video
DVD/CD disc opener won't workGetting
Usually the tray has to be opened and inspected and if lucky it can be realigned--if not parts may be hard to find as they usually do not sell individual parts for the mechanism.
Nov 05, 2012 | Televison & Video
Sony GDP s301 won't play any discs
see the cause and remedies:
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Finally the OPU, optical pickup unit contain too the lasser beam, NOT are reading the TOC of disk,+Syscon can be defective. You must go to the repair shop TV for fix it. this a complex equipment.
see tje block diagram.
God bless you
Jul 15, 2012 | Sony BDP-S300 Blu-Ray Disc Player
Tray won't close fully then pops open again what needs to be done.
Hello
Its loading mechanism has the fault. It must be replaced. Check its loading belt, before replacing the loader mechanism.
Picture of the loader mechanism is given here.
http://www.dataentryjobs.us/67948.html2_28_2012_4_54_10_am.jpg
Feb 27, 2012 | Sony DVP-NC600 Multi-disc DVD Player
Sony rdr-hx720 tray won't open and says traylocked?
The disc tray does not open and you cannot remove the disc after you press Z (open/close). ,Turn off the recorder. Once the clock appears in the front panel display, disconnect the mains lead. (If the recorder does not turn off or if the clock does not appear in the front panel display, disconnect the mains lead anyway.) Connect the mains lead again while pressing down A on the recorder, and release the button when the disc tray opens. Then, keep [/1 on the recorder pressed for about ten seconds until "WELCOME" appears in the front panel display
Oct 08, 2011 | Televison & Video
Error E26 it won't the player
E26 means the tray can not open. There could be a cd stuck inside
May 12, 2011 | Sony DVP-NC615 Multi-disc DVD Player
How to unblock region code block of sony bdv-e770w?
It's already Region Free when purchased.
  • A+B+C Multi Zone Region Code Free Blu Ray Player DVD Region 123456 PAL/NTSC
  • PAL or MULTI-SYSTEM TV is required to watch PAL DVDs. If your TV was purchased in North America (NTSC) you will also need a Video Scaler Full HD 1080p.
    May 07, 2011 | Sony BDV-E770W 3D Blu-ray Theater System...
    SONY BDV-FS350 INSTRUCTION MANUAL
    I found some support for a SONY BDV-360FS on their european site.
    This is the closest model # I could find.
    Is this the unit you are looking for support on?
    Not the BDP-S300 or BDP-S350 blu-ray players, but a player with a builtin amplifier and speakers, is that right?
    Oct 06, 2009 | Sony BDP-S300 Blu-Ray Disc Player
    Sony BDV-E780W Logo
    Top Sony Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
