My Honeywell thermostat 32002418-001 reads "TH-return
2 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: Operations manual; Honeywell thermostat; Focuspro
You may download from following site:
http://yourhome.honeywell.com/home/Applications/SmartSearchResults.aspx?searchkey=thermostatfor heating
Posted on Dec 07, 2010
Honeywell has made a huge number of thermostats over the years. Directions for each are specific to each model. Your model number will begin with the letters, T, TH, RTH, C, or CT and is on the back of the thermostat.
Once you have the model number, you can obtain the owner & programming information by supplying it on the Honeywell webpage, here.
If you are having trouble, either contact Honeywell directly - or repost here.
May 16, 2013 | Heating & Cooling
How can I unlock this th
Remove the thermostat from its base and replace the batteries. To remove the thermostat, grasp it at the edges and pull toward you. The batteries are on the back of the thermostat housing.
Read more: How do I Unlock the Digital Display on a Honeywell RTH8500 Thermostat? ' eHow.com http://www.ehow.com/how_7267447_do-display-honeywell-rth8500-thermostat_.html#ixzz17KTxLwBU
Dec 05, 2010 | Honeywell Heating & Cooling
My old thermostat has only yellow and red wires...no green and white like my new Honeywell thermostat installation instructions mention. Is this a problem?
The green wire is used to turn on the blower if you want constant air circulation. For heat only, the red and yellow wire will work as long as they are connected to R and W terminals on heating unit (or TH and TW on some models).
Nov 20, 2010 | Honeywell Programmable Thermostat Heater
How do you et th thermostat on a honeywell model HZ 709
Go to myhome.honeywell.com and search for a manual for your model number thermostat on the right hand side of the page.
Oct 14, 2009 | Honeywell Programmable Thermostat Heater
How do I get my honeywell system up and going?
for now, put switches on thermostat to hear and press the up arrow button to the desired temp. All your programed temps will take more explaining and it would be best you secure a owners instruction book from home depot. oif anything, buy thr same thermostat and either keep it or return it . I'd keep it regardless, read the pmphlet,program you heat and a/c before returning for refund. Don't destroy packaging and give them back everything. You will also need two AAbatteries. Good luck.
Jun 11, 2009 | Honeywell Programmable Thermostat Heater
Th8000 does not match another thermometer inside home
Is the thermostat mounted near a lamp or other heat source?
Is the wall warm from ducts in the wall or a refrigerator on the other side?
The thermostats are usually pretty accurate. Most times I find some other influence on the thermostat causes the problem.
The Honeywell 8000 series also has a feature accessed through the installer setup menu, that will allow the temp display to be changed + or - 8 or 9 degrees.
Check the manual or Honeywell's website for a .pdf if you need it.
Hope this helps.
Matt
Jan 11, 2009 | Honeywell Electronic Programmable...
The Honeywell Programmable Heat Pump Thermostat CT3611R is not adjusting the temperature to a cool setting. Cool air is coming out of the vents however the temperature on the thermostat remains the same...
if your problem has existed since the begining of installment it could be a return/ thermostat placement problem. if the return is to close to any supply vents it will run like that and your thhermostat will read like that
Apr 24, 2008 | Heating & Cooling
Honeywell TH8000 5 wire
7wires? wtf with that! how many things you got runnin there. you need to give way more info to get a decent reply.
Feb 04, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
238 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
