Question about Fender Rumble 100 Bass Guitar Amplifier
Fender Rumble 100/115 cuts out randomly with low end notes.
I got a rumble 100 that cuts out when hitting low end notes every time, Starts out with some crackling then sound subsides. The amp stays on, red light indicator stays on and red lights at the bottom also stay on when switch is on from the back of amp. If I connect via cd input jack and play something that has low end same thing happens, only time amp performs as normal without any cut out is when I have headphones plugged into it. Any help would be greatly appreciated, thanks in advance.
  • 11 Answers
SOURCE: Fender Rumble 100 210 pop noise then hum after strong low e note
I just fixed my bass amp with a similar problem last week: the problem is related to a loose connection on the PCB board (likely).
A bass amp is a rough place for circuitry: the low rumble and power shake a bass amp more than a guitar amp.
In my case, the power transistors needed to be re-soldered and then the grounding bolts and screws needed to be removed and cleaned because the connection was bad. Remember that when two different metals needed for an electric connection are toughing, there is the likelyhood that corrosion WILL happen.
My bass amp did basically the same thing yours did: sounded good at low volumes, but at higher volumes it would act up.
In short, there is nothing you can do (unless you are a repair person): you need to take it to a local music shop and have a tech fix the intermittant contact problem: someone who knows what they are doing should only take an hour at most.
Hope that helps!
-mike
Posted on Mar 31, 2009
  • 153 Answers
Replace C21 (10uF/50V) and C38 (2.2uF/50V) and it will work great.
Posted on Apr 30, 2009
  • 5603 Answers
SOURCE: My fender rumble 100 used to cut out, now it's
Suspect the input jacks. Wiggle them and see if you get anything. They get yanked sideways because the musicians don't loop their cord thru a handle and they get yanked sideways.
Also you can try spraying sparingly CRC226 into the switches and pots. You can get it at Home Depot in the electrical department.
Posted on Oct 10, 2009
  • 1138 Answers
SOURCE: My Fender Rumble 25 makes a terrible crackling
Here is the schematic:http://www.fender.com/support/amp_schematics/pdfs/Rumble_Bass_Schematic_-B21.pdf Check the tubes to see if one is loose in its socket. Do not attempt to repair this yourself unless you have amplifier repair experience as it is easy to get a bad or life threatening shock without the correct test gear and troubleshooting procedures.I hope this helps.
Posted on Nov 26, 2009
  • 5603 Answers
SOURCE: Hello! I've bought a Fender Rumble
Try plugging another sound source into the unit. The buzz MAY be pickup of magnetic fields in your guitar pickup that clobber your notes from the strings. Bad guitar cables are another possibility. By putting clean music from say a CD player into the unit you can find where the source is. If the CD player generates the same noises, then likely you have a failure of filter caps in the amp or other component failures. Also make sure your guitar can't "hear" the amp as feedback can do strange things.
Posted on Apr 23, 2011
It plays for about 30 minutes and then just stops, as if overheating. After a cooldown period, it starts up again for another short period. Suggestions? Any recommended vents I could cut in...
The small Fender products often have a TDA2050 power chip in them. The chip is on a thin aluminum heatsink and is intended for light use. If you try to sound like a bass guitar amp with this, the chip will go into thermal protection mode. Cutting vents will not help very much, and pushing it to these levels will destroy the speaker eventually. If you need more power, buy a bigger amp. This one would be suitable for a 10 foot by 10 foot room.
May 24, 2011 | Fender Musical Instruments Corporation...
Hello! I've bought a Fender Rumble 75 about 3 months ago and it sounded great really but after some loud playing (About 75% of max volume) it started to buzz at midrange notes, and its gets worse as time...
Apr 23, 2011 | Fender Rumble 75 75watt Bass Guitar Combo...
HI CAN YOU PLEASE TELL ME WHY MY FENDER RUMBLE 100 BASS AMP DISTORTS AT LOW VOLUME? EVEN THOUGH THE SPEAKERS IS NOT BLOWN
A common reason for 'distortion' with all bass amps can be either that the screws holding the speaker unit to the cabinet have worked loose or that there has been a build up of dust particles in the corrugations around the edge of the speaker cone, which rattle especially on the lower notes.
The solution is simple - remove the front grille and check the screws are tight. Use a vacuum cleaner to remove dust from the rim of the speaker cone.
Feb 01, 2011 | Fender Rumble 100 Bass Guitar Amplifier
Hello ! Do You have shematic diagram for bass guitar combo Fender Bass Rumble 100 / 15 ? If You have it, please snd me on my e-mail ? Regards Zlatko
Try this link:http://www.fender.com/support/amplifier_schematics.php If your amp isn't listed contact them and they will send you one.
Oct 21, 2010 | Fender Rumble 100 Bass Guitar Amplifier
What sound does the low mid suppose to give?
When terms like "low-mid" are used, it generally means frequencies between approx. 125Hz to 315Hz.
Apr 25, 2010 | Fender Rumble Series 100/210 100watt 2x10...
My Fender Rumble 25 makes a terrible crackling sound when the volume is turned up over the 4 or 5 mark. I don't think the speaker is blown as the same sound comes via the headphone socket.
Nov 26, 2009 | Fender Rumble 100 Bass Guitar Amplifier
Oct 08, 2009 | Fender Rumble Series 100/210 100watt 2x10...
Not really a problem want to know if I could add a extention speaker to the fender rumble 100 combo it has not ext. speaker out looking to add two 10 inch and if so how?
Hi there. If 10" speakers are 8 or 16 ohm, parallel them. If they are 4 ohm, series them. if "External speaker" output is rated down to 4 ohm. If no external speaker jack, you'll have to tap into existing speaker jack with a "Y". Check the minimum ohm load for the amp.
Thanks
Paul
Jun 03, 2009 | Nomad Factory Fender Rumble 100 Bass Combo...
Hope that helps!
-mike
Feb 22, 2009 | Fender Rumble 100 Bass Guitar Amplifier
Feb 22, 2009 | Fender Rumble Series 100/210 100watt 2x10...
Fender Rumble 100 Bass Guitar Amplifier Logo
194 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Matthew Spark
Matthew Spark
Are you a Fender Music Expert? Answer questions, earn points and help others
