Question about PANDIGITAL PANSCN Office Equipment & Supplies
ERROR LIGHT STAYS ON MY HANDHELD SCANNER
When I turn it on the red light stays flashing with code 903. I can not get the green light to stay on to scan.
jackboy
  • 2985 Answers
SOURCE: scanner not responding to preview scan
Try this as a last ditch effort. Remove the software. Reboot the computer and come off line. Disable the Anti Virus program. Now install the soft ware. Then try. If the red light still flashes then assume it is new scanner time.
Posted on Aug 02, 2007
  • 110 Answers
SOURCE: Red light comes when powered
Please try the following to resolve your issue:
1. Unplug the USB cable and the AC adapter from the back of the scanner.
2. Toggle the Transportation lock (located on the bottom of the scanner) back and forth 5 times, ensuring that the lock is all the way in the unlock position.
3. Reconnect the USB cable and the AC adapter cable, and then try to scan.
Posted on Aug 22, 2008
  • 4 Answers
SOURCE: getting error code Code[ffff:0024]while scanning
I believe the scanner light needs to be replaced.
Posted on Nov 20, 2008
SOURCE: flashing red light & noise
I've just discovered that this means the "transportation lock" is on: at the back of the scanner, put the plastic switch into the 'unlock' position. See this Epson support page for more details.
Posted on Jan 07, 2009
SOURCE: Red light stays on and will not print
there is a second piece of paper stuck in the machine.
open the back flap, look at the diagram, and pull out a piece of hardware
behind this hardware, all crumpled up, not visible, is a jammed piece of paper.
Posted on Jan 13, 2009
Hello! I have a M51 Invacare Pronto that is not working. When I turn it on, the service light flashes eight times, one red battery light flashes as well, but nothing happens when I move the joystick.
If it flashes 7 green and one red for the 8 total then it's a joystick error. If it's 8 green and one red then it is a control/brain error code. Measure voltage on batteries when turn chair on. Both batteries need to stay above 11.5 volts each.
Jan 21, 2018 | Invacare Health & Beauty
Bravia KDL52z5100. Why is red light blinking 14 times?
Tell the readers of your posting exactly what is the problem with the tv. Audiio? Picture? Backlighting? Etc.
Dec 29, 2015 | Sony Televison & Video
I lost the remote code
Hello
Remote codes for Zenith are follows. You have to find out one amoung them which will wakeup your TV.
002 008 115 215 405 407 507 601 701 713 903 916
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK.
Dec 23, 2010 | Zenith B27A11Z 27" TV
I have a universal philips remote control without codes i need the codes
Some times universal remote controls have an option to find codes automatically.
if not try these 3 digit codes one at a time.
002 008 115 215 405 407 601 701 713 903 916
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
3. Enter the 3 digit code from the code tables. Note:
Dec 14, 2009 | Zenith C27A24T 27" TV
Red light by flash permanently on
friend, Pls., check whether a an application named BAR CODE reader is installed and if is turned ON,then Ur IR will always in search of a bar code if fone camera shutter is slide open
Jun 07, 2009 | Nokia N82 Handheld
C43 stylus does'nt print while red and green lights stay on
If the light are flashing, it mean waste ink full. You must clean waste ink pad, and reset the counter. You can use SSC, find at indoreset.blogspot.com. But,.. you said the light are on. try to resinstall driver. after printer recognised by comp, check status monitor. Green light on is power on, and red on mean chip error/ink out error/cartridge error.
May 29, 2009 | Epson Stylus C43SX InkJet Printer
Scanner not responding to preview scan
Jul 26, 2007 | Epson Expression 1640XL Flatbed Scanner
67 people viewed this question
Top PANDIGITAL Office Equipment & Supplies Experts
Mike
LP
Are you a PANDIGITAL Office Equipment and Supply Expert? Answer questions, earn points and help others
