Question about Microwave Ovens
Ge microwave door switch repair - Microwave Ovens
5 Suggested Answers
SolutionGuy
  • 331 Answers
SOURCE: GE Microwave JE1640 works only when holding the switch
VK, most likely the switch body has become loose and it's out of adjustment. Unfortunately, to gain access to it, you'll have to remove the MW from the cabinet, set it on a suitable work area and disassemble it. Before doing anything like this, please read the following link carefully and ask yourself if you're up to it... http://www.gallawa.com/microtech/safety.html Remove the trim then remove the screws holding the MW. Pull the MW out and rotate slightly to see where it's plugged in and unplug it. Then pull it all the way out. Remove all the aluminum trim from the MW and all the screws holding the cabinet. To remove the cabinet, stand behind the MW and grasp both sides... pull back and up at the same time. Set aside. NOW!!! DISCHARGE THE CAPACITOR AS PER THE INSTRUCTIONS IN THE LINK ABOVE!!! OK, up by the control panel, you'll see the latch/lock assy. (it has 3 brown switches mounted to it). It's held in place by 2 screws, the lower screw is the one you'll be working on. Adjust this by opening and closing the door and watch the action on how it works and make your adjustments as needed. Now, you'll need to test it before reinstalling. Plug it in, BUT DON'T TOUCH ANY WIRING! Now give it a try. If you need to make another adjustment, DISCHARGE THE CAPACITOR AGAIN BEFORE DOING SO!!! Do this every time you plug and unplug! Continue adjusting 'til you get it. Now, there's a chance that one of those switches is about to go bad and the mounting bracket is fine. In this case, those switches are generic... not GE specific. Remove the wiring from the switches and make notes on their respective locations. Remove the switches from the bracket (starting from the top) and label them 1, 2 and 3. Take these to your local appliance parts store and ask for generic replacements, they are cheap... about 5 bucks each. Then replace them in the same order you removed them. And re-test. This will get you fixed, but please be careful working on Microwave ovens. They are dangerous!
Posted on Sep 27, 2007
SOURCE: Repairing Microwave
check high volatage circuit, and magnetron, and wiring and control unit or circuit...
Posted on Oct 05, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Have a GE Profile Microwave Oven Model JE1540. the
See these files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
Posted on Jan 17, 2011
tunde007
  • 2382 Answers
SOURCE: On our GE Model JE1640
Hi, in most cases it's not actually cooking, but instead the fan, turtable and light may be on. Yet it does need attention.
What this usually means is that you have a shorted door switch or a bad door switch mount.
It's easy to tell if it's actually cooking, just place a cup of water inside and see if it heats.
If so, that could mean a stuck relay on the control board.
Posted on Feb 06, 2011
Fan and light on my GE Adora microwave oven will not go off.
It may be a door switch / door switch mount issue or a shorted relay on the controller.
I regularly repair these microwave controllers and details are here.
If you have other questions, it's best to follow up with me directly.
(FixYa does not notify us directly when follow-ups are posted, so we have to log in to the site to see them.)
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 08, 2017 | GE Microwave Ovens
How do you know if the panel is bad on a GE profile microwave JE2160SF 03? I have no power what so ever. Is it easy to replace?
Before you attempt any repair to your microwave, if you have no power, it may be the door switch(es) defective. Try to open and close the door a bit harder to shake the switch internal contacts a little, you may have to do this action a few times. If this proves effective then change your door switch(es). You have to remember that the door switch(es) internal contacts get weaken with time and tend to fail first.
Mar 21, 2017 | GE Microwave Ovens
GE microwave (Model JE2160SF03) trips breaker when door opened
Remove the control panel, take pictures of the door switch wiring while they are still connected to the door switches, then remove the door switch assembly. Have someone at the appliance store check each switch and repair the ones that are defective.
I purchased a switch for $7, reinstalled the door switch assembly and the microwave is working fine now.
Jul 02, 2012 | GE Microwave Ovens
It turns but it doesnt get yhe food hot
Hello estela281 :
Your microwave problem could be happen because of a bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
That could happen because of slamming the door and not closing it gently .
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
Please rate !
Jun 08, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
It's working normally EXCEPT it will not heat food or pop popcorn, etc.
Hello :
It's could be a bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
PLEASE RATE !
My GE spacesaver Microwave oven is not warming anything up. All other functions are working normally.
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
Check also the turntable . It could be out of it's right place .
WARNING :
1:Don't slam your microwave door because this may cause the fuse to blow and this is the reason of bad door switch problem .
2: A microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
Jun 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker 1400 acts like everything works but does not heat.
Hello :
WARNING :
good luck
Apr 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL 1400 Microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 27, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave comes on when door is opened
The most likely problem is a defective door switch or door switch mount. I have handy information files on safety, disassembly and door switches that will help you or a friend check and repair this problem. If that's not it, then you may have a sticking relay or other problem on the control board. We repair these nationwide for $32.50 total in most cases. You can also find information on this service through the link above. The attachment may be close to yours. Let me know if I can help further!
Jan 20, 2007 | GE JE1640 Microwave Oven
Microwave Ovens Logo
81 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
