Question about Hayward H-series Electronic Gas Pool Heater H400
Clean heat exchanger
H400 heat exchanger heavily sooted
  • 372 Answers
It needs to be removed and power washed. This is not always a DIY project, unless you have a strong back and are mechanically inclined. The heavy sooting indicates that the heater is not getting enough gas. Remember bunsen burners? Same deal, we want a blue flame (non sooting), not an orange flame. The culprit is usually an undersized gas line to the heater, or a smaller gas meter than the heater requires.
Posted on Jan 05, 2013
What is causing heat exchanger gasket failure
check gas pressure sounds like heater is sooted up and overheating get proper gas pressure then clean out soot on heat ezchange and you should be ok
Sep 24, 2014 | Pool & Spa
Heat exchanger cleaning
If it is out, then you got the hardest part already done. Now, just put a High Pressure Nozzle on your garden hose & rinse thoroughly. Do not, repeat, do NOT use a brush. As soot is very flammable and explosive!!! Just like when you stoke a match against the striker strip and the match ignites then settles to a flame on the wooden stick... that is what the exchanger can do as well - poof! No more eyelashes, eyebrows, & if you have a mustache or Beard... Uh uh.
Jan 16, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
My jandy xl 250 pool heater runs great for 5-6 minutes with a blue flame then it turns orange and runs hot ive replaced all 5 burners wire brushed and power-washed the heat exchanger. I tore it all apart...
bad mixture is correct. heater is under firing, lack of oxygen, hence the immense amount of soot or carbon build up underneath heat exchanger. Is heater inside a shed? if so u need 2 vent openings to provide combustion and ventilation air. vent blockage can also cause sooting and over heat conditions. your repair guy lacks alot of knowledge. burners and heat exchangers can be cleaned. i can give you a list of reasons of possible problems that im sure were never mentioned or checked
Aug 11, 2013 | Pool & Spa
How to clean teledyne laars heat exchanger
take off top take off all baffles remove burn rack then rinse out with hose and wire brush to remove soot the best is if you can remove it so you can get to the bottom thats whats sooted up
Jan 17, 2013 | Teledyne Laars HEAT EXCHANGER ASSEMBLY,...
Pool boiler sooting up
check gas pressure it will soot it up
Dec 21, 2011 | Jandy Pool & Spa
Can a gas heater after years of good use - start emitting carbon dioxide? What about black ashes or soot?
yes yes yes. if you are having black soot build up in the burner compartment you have a problem.the air/fuel mixture has changed. you need to stop using and get the heat exchanger cleaned. this can be done with a long bottle brush coat hanger or such. remove the burners and away you go clean clean clean what a mess.anyway once cleaned reassamble burners and check all gas fittings for leakage with soapy water. after main burner comes on make sure the flames are straight up and not floating around and a nice blue in color some orange is ok but no yellow. normaly a plugged heat exchanger does not mean a bad heat exchanger. watch the flame before the fan comes on and after.the flame should not change. if it start to waver you may have a nother problem and you should not use and call a heating company
Jan 27, 2011 | Dayton Gas Furnace Heater
Opened pool. Rheem heater has the service light blinking
rollout switch is open, and sns is a sensor failure. replace rollout switch, clean out vents, inspect heat exchanger. water sensor senses too cold or too hot water
May 28, 2010 | Rheem 266K to 399K BTU Swimming Pool...
Hi-E2 350 heater trips thermal switch on exhaust collector after 10-15 minutes of run time. Went through the manual tested all gas and air pressures with digital differential manometer, adjusted to within...
Check the condition of the heat exchanger. If it is heavily sooted from prior to adjusting gas pressure it will not vent properly. Check for downdrafting or blockage in the flue pipe if the heat exchanger is not sooted.
If the heat exchanger is sooted a good steam cleaning or even a trip to a car wash should remove enough soot for it to return to operating normally.
Dec 15, 2009 | Jandy Laars Hi - E2 350,000 Btu Heater
Hayward H400 heater won't light and service light comes on. Also gives a code on screen "AO". I can't find in the owner's manual what that means. It is the electronic ignition model.
This is a code for what is called a prover switch. What it is a circut for the air pressures. Depending on model you can have one or two of these. Their will always be one for the exaust perssure and this will often be the culpret. If the sensor is good a sooted exchanger, rat nests on the exchanger or in the exaust can cause this. If you have a second switch it will be for burner air pressure and you will look for the same problems only inside the burner cabnet. Good luck, I'm sorry I can't be more help. But at least you know to look to the vent system.
Sep 27, 2009 | Hayward H-series Electronic Gas Pool...
Hayward H400 runs for 2 minutes and turn off, flames out chimney
Soot on your heat exchanger would explain this. Or leaves or rat nests would do the same thing. You can clean these yourself or get a repairman to do this for you. Just be sure if you have soot on the exchanger use a stiff bristel brush but not a wire brush. The soot as you free it up will be pouder and can explode in a fashion. Be careful and good luck.
Apr 24, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H-series Electronic Gas Pool Heater H400 Logo
182 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
