Question about Fisher Paykel Fisher & Paykel SleepStyle 200 Series CPAP System & Each HC014
Fisher paykel sleepstyle 200 series is displaying e1
Bionaire BT-200 ultrasonic humidifier have stopped misting, though I can hear a hum as though something is still working. I have two of these in the same state.
I have the same model; it has a little disk about the size of a dime at the bottom of the well where the mist comes out. That metal disk gathers white scale on it, Clean that off. The best way I have found is with a Waterpik turned all the way up. The scale keeps the disk from vibrating.
Jan 24, 2017 | Bionaire Humidifiers
Showing Error Code E1
If you wish to get some details; check the site linked here. Pull up older posts.
http://homenol.blogspot.com/
Aug 31, 2016 | Fisher Paykel Fisher & Paykel SleepStyle...
Just bought and plugged in E1 error!! Can't get it to work!!
then return it to place of purchase for replacement or refund .
Oct 11, 2015 | Sunheat TW-1500 Thermal Wave Infrared...
I live in the Caribbean where the voltage is 220/240 so I need to know what size transformer I need to use with a 5.8amp Vicks vaporizer
Hi, you would need one that's around 1400 watts (watts = volts x amps so 240 x 5.8 = 1392)
I hope that helps.
Jan 08, 2015 | Vicks Humidifiers
Honeywell hut-200 humidifier troubleshooting guide
Same thing is happening to me this season - and it's none of the above - it's the darn pump. The HUT220s have been perfect for 2 seasons, but this year, the pumps rattle and growl no matter what I try, and one won't pump water at all. I had to call Kaz/Honeywell for replacement pumps. 1-800-477-0457.
Oh yeah, and he's sending them NO CHARGE!
It took "Bill" a while, but he found some for me. Honeywell inventory system says there are none in stock, so if you call and someone tells you they are out of stock, MAKE THEM CHECK WITH THEIR SUPERVISOR - THEY ARE THERE SOMEWHERE! They probably list them under the new model number for this year "220W" but the whole 200 series uses the same pumps based on all the photos/diagrams you can see online.
I looked all over online for them to see if I could find them sooner than the 3-4 weeks it will take to deliver them, but there are none to be found. If anyone knows a place that delivers to Toronto, Ontario, Canada, let me know!
Jan 09, 2012 | Honeywell Humidifiers
I lost my manuel and there is an e1 mark on it i i was wondering what does it mean
dincy, here is a link to your Owner's Manual that you can download and print for future reference.
https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%201187984.pdf
I hope this helps you and thanks for choosing FixYa.
Aug 05, 2011 | Whirlpool AD25BBR 25 Pint Per Day...
I need to know where the filter goes on a slant/fin GF-200 humidifier. I don't have a manuel.
by what i have found for your model it doesn't have a filter persay. it has pads and they go right under the tank.
Aug 18, 2009 | Humidifiers
I have old 78 series cast iron wet base . seral #780104 model#78--175. Iam looking for a wet pack.Not if that is right, but it's to line the fire box ?? MEGAMAN@ZOOMINTERNET.NET
I just bought a wet pack for my 78 series from a local supplier.
It is a Westwood No S70-45, wet sheet chamber liner. You cut it to fit then fire up the boiler and it sets up. The sheet measures 16'x48'. You can also get it online. Good luck
Mar 20, 2009 | Slant Fin GF-210W 2 Gallon Humidifier
Have solenoid: MOPD 125, WATT 2.3, VOLT 24/60, for Aprilaire 560 Humidifier. With a M15 Universal tester using 150mA for + & K OHMS FOR -, I get 2 ohms on scale which would be approx 200 ohms. Ohms = Volts...
I am guessing you have sent 24 volts to the solenoid directly and the the solenoid did not activate?
If you have not send power directly
If the solenoid does not activate that way more then likely needs a new solenoid.
Mar 05, 2009 | Aprilaire 550 Humidifier
Fisher Paykel Fisher & Paykel SleepStyle 200 Series CPAP System & Each HC014 Logo
659 people viewed this question
Top Fisher Paykel Humidifiers Experts
Barry37
Level 1 Expert
Are you a Fisher Paykel Humidifier Expert? Answer questions, earn points and help others
