Question about Honeywell Programmable Thermostat Heater
Honeywell rht111/rth221 display does not light up
I am hooking up this new thermostat in place of an old honeywell. It has two wires, white and red. I connect those two per the instructions. I get nothing on the display, it doesn't light up. I have working batteries, still no display. Will the display light up before I connect it to the mounting plate?
  • Will Steuber Jan 04, 2013
    Does anyone have a suggestion? The display doesn't light up at all. So, I can't tell if it should display something with just batteries in or if it requires a correct hookup. In either case, I get nothing on the display so I'm thinking something is wrong with the unit.
  • 71 Answers
SOURCE: Help - I am trying to install a honeywell RLV4300A
You will have to have schematics from the old wiring diagram. Then you will have to confirm its consistency with actual old wiring before you can be sure that the wires run to the proper places on the old heater and a/c system. This sounds like a gas furnace and is simpler than a heatpump. Once you know what distinguishes the wires with the same color, you should label them and then you may call them a different color if they were wired with wrong wire colors. You may be in luck if you go to the furnace control box an look at the terminals.. They are usually labeled with a R for Red and W for white and Bl for Blue and B or Black. If you have other colors on these then it sounds that it was wired with wire spare wire by someone who knew what they were doing but neglected to leave a path for someone else follow.
You may be able to use a continuity tester of circuit tester to id these wires that are in question...
ie, once indintified, you can match with the requirements of the new stat.
Posted on Jan 13, 2009
  • 24 Answers
SOURCE: Honeywell RTH 230B Thermostat Wiring
put the jumper back in RC and RH and that should do it.
Posted on Apr 15, 2009
  • 252 Answers
SOURCE: my honeywell ct87K thermostat will not turn the heater on
On your thermostat - R is the power in terminal. Y is the cooling out. W is the heating out. (G is fan out). It does not matter which wire goes to R, the other should go to W - if no heat with a call, the thermostat is bad.
Posted on Apr 17, 2009
  • 82 Answers
SOURCE: Wiring new RTH2310 DIY Honeywell
is the j2 jumper on the backside of the display set for hg instead of he - g is gas/oil e is electric - if correct take thermostat wires off screws and turn power back on - see if burner fires up with no thermostat wires connected - old wires could be touching somewhere when put on new thermostat
Posted on Sep 21, 2009
milten1
  • 1304 Answers
SOURCE: i am installing honywell thermostat rth111/rth221
rh goes on red, this is what will provide power to the heat
rc is red if you want to power the ac unit
Posted on Oct 21, 2009
Wires don't match the new thermostat posts. The wires from the furnace are Red,Blue black and white The posts in new thermostat are B O G Y not used R and Rc Can't figure which to put
The wire colors are for the following functions ......red - 24 volts white - heat yellow - AC green/blue - blower (fan) red is connected to the R with a jumper between R and Rc What type of furnace/heat do you have ???? Electric. oil, gas .Forced hot air, baseboard, steam, heat pump, or ?????? Different systems use different connections and need a specific thermostat for that application !!!
Dec 13, 2014 | Heating & Cooling
Bought new thermostat model ct87k but old Honeywell model I have was hook up by black and white wire not red and white , so how do I hook up.
The two wire Honeywell T87 and CT87 is nothing but a switch in a control circuit. Wire color is not important at all. What is important is the TERMINAL DESIGNATION those wires are hooked to. Soooo....take the wire off of the sub base of the old stat terminal marked 'R' and attach it to the new sub base terminal marked 'R' and so on. Wire COLOR means nothing at all in your case.
Oct 04, 2014 | Honeywell CT87K1004 Round Heat Only...
Installed the Honeywell RTH2300/RTH221 but the old thermostat was removed by someone else. Since the original wires were not labeled, I simply attached them to the new thermostat by following the letters...
This appears to be a thermostat installation that was made without regard to wire code. The Honeywell material I have suggests it may be necessary to check connections at the furnace end and work back to the thermostat. There may be compatibility problems between the number of wires in the old installation and terminal connections in the new thermostat. Honeywell may be able to help at 1-800-468-1502.
Oct 29, 2013 | Heating & Cooling
I am installing honywell thermostat rth111/rth221 old thermostat has two wires that are yellow and need to know where to hook up
First things first. What type of system? Heat only, boiler or furnace? Central cooling.
Do NOT take wires off the old thermostat yet, or mark the color wire, to the terminal letter. Most times W,Y,G,R, terminals and maybe even a C terminal.
Your new thermostat should have the same letters. Sometimes they mix up color wire with terminal letters...... example (yellow wire to w terminal)
Also turn off power to equipment it is controlling. It is not high volts but you can short out the transformer. Hook uo wire color to same letter terminal on old stat, to new stat. Thats it.
Nov 12, 2011 | Honeywell Programmable Thermostat Heater
Hi! We have a really old williamson thermostat (not sure about the model but it says t87fi89i 2 8047 [dont know if it's i or 1 either]). We want to replace it with a honeywell t87n east-to-see thermostat....
On most applications for heating the red and white wires are used,however I would check what wires are connected to terminals on old thermostat. These connectons should be labled with initial of wire color,such as R,W,G,Y or Rc. If your green wire is hooked to R or whatever just hook new thermostat up like the old one and you should be ok. Hope this helps. Thanks.
Nov 12, 2010 | Honeywell Electronic Programmable...
RTH221 honeywell thermostat install, hooked up blue wire from old thermo that hooked to C to o/b connection on new thermostat no work did I screw something up as old thermo will not work as well now. was...
maybe a blown fuse if it has one... if not then you blew the transformer...
Check on the circuit board in the furnace or air handler for a fuse...
if there isn't one... then you will need to replace the 24v transformer... they blow very easily...
heatman101
Aug 05, 2010 | Honeywell Heating & Cooling
I am trying to replace my honeywell T834C2499 with a programmable RTH221. I have hooked the wires as follows: G to G, W to W, Y to Y and R to Rh - leaving the jumper between Rh & rc. My problem is that...
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
May 31, 2010 | Honeywell Programmable Thermostat Heater
I tried to insatll my new honeywell programmable. the old t-stat had a white and red wire connected allread. there were 3 other wires unused, G,W,R. I hook up the original R,W wires to the new t-stat and...
The red and white wires go to the R and W terminals on the thermostat. Disconnect what you have now and hook the red wire to the R terminal and the white wire to the W terminal on the new thermostat and see what happens.
Jan 09, 2010 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
202 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
