Question about D-Link Computers & Internet
Ok trying to get my laptopto go online two things #1 it keeps saying unable to find a certificate to log onto Barbershop thats is the name and that the local area connection has a cable unplugged there is no cable help
  • 7,627 Answers
Plug the cable in.
Posted on Jan 06, 2013
cyrylthewolf
  • 143 Answers
SOURCE: Router says connected but I can't access the internet
Ok... I see two people here with what appears to be the same issue, however "Guest" seems to have a more specific problem. I want to clear that up first.
To "Guest":
You are confusing your ETHERNET (Wired) connection with the Wireless connection. If it says that "a cable is unplugged" then it is refering to your ETHERNET connection. (Also known as "Local Area Connection" by default.) If you are not going to be connecting your laptop to the router by way of an ethernet cable, then you can actually disable that ethernet port by right-clicking it in the "Network Connections" window and selecting "Disable". (This is how it is done in Windows XP. Windows Vista is a little trickier for some reason.)
If you are showing a strong signal after that, it means that your Wireless adapter is still working correctly. Make a new attempt at connecting to the wireless router by finding the name of your router in the list of available wireless connections and clicking Connect.
If your router's SSID (name) does not show up in that list, then it may be secured as per the default settings. The newer models of the WRT54G router have a button on the front that you can press to temporarily disable wireless security so that you can log onto the router and make your settings. Look on the front of your router for the "CISCO" logo near the front-left. It is illuminated by an orange glow. This is to enable SES or "Secure Easy Setup".
Pressing this button will turn it white and it will probably blink, too. While this light is white, you should be able to find the router on the list. But it will be called something different. It should have random numbers and letters as the router's ID and should show a fairly strong signal.
This is a temporary connection. This gives you enough time to log on to the router and change it's settings before the open connection times out.
To make all of this as easy as possible, I would make sure to do two things:
1.) Use the RESET button on the router to set it back to factory defaults.
2.) Make sure you unplug your cable modem and plug it back in before reconnecting it to your router.
3.) Make sure that you leave all default settings for all network adapters in Windows.
4.) If you have connected your laptop to other wireless networks called "linksys" in the past, it may have the settings of those previous routers in the history that Windows keeps for all wireless connections. You can find that list and CLEAR IT by right-clicking the little icon in the lower-right corner of your Windows task bar and selecting "Open Available Wireless Networks" and finding the list on the left side of the next screen.
I can't advise on much beyond that until I know the results of this procedure. But it sounds like both of you are having the same issue. Here's a tip:
For now, ignore ANYTHING that says, "Local Area Connection". That has NOTHING to do with wireless. That is the WIRED connection. (Ethernet.)
I'll watch here.
Cyryl
Posted on Nov 04, 2007
  • 4 Answers
SOURCE: connecting to network
[QUOTE]The exact error message should be:
"Windows was unable to find a certificate to log you
on to the network [SSID]"
Google shows 37 hits with this exact phrase.
This is caused by setting the encryption to WPA-RADIUS instead of
WPA-PSK on the client radio. Both the router and the client are
trying to find a RADIUS server with which to authenticate your system.
Switch the encryption to WPA-PSK (pre-shared key) on both ends and it
will work.[/quote]
Posted on Jan 16, 2008
sandeep239
  • 59 Answers
SOURCE: validating identity
it is just that the network key which is stored in the computer is not working so the 1st thing u need to do is verify the network key for that go to 192.168.0.1 from internet explorer enter the user id & password of ur dlink ( default id: admin password : admin) the go to wireless check the WEP or security key which is present their. reenter that key the computer & try to connect.
If it didn't work then go to control panel >> system >> hardware>> device manager
look for the network adepter & unintall the wireless network card
restart the computer
once restart it will automatically reintall the wireless card driver
then go to control panel>>Network Connection
right click on wireless network connection
select view wireless network connect
select ur network name & connect it will ask for the key provide the key & once u do that it will get connected & work fine
if in case u have the same problem replay back & i help u out with it & also provide all the details like which windows & network card etc
Posted on May 25, 2008
  • 35 Answers
SOURCE: Netgear DG834G with xbox360
Connect to the Router,
Under the Security tab, select Services, then add, give it the name XBOX TCP/UDP, set start port as 3074 and end port as 3074, set type as TCP/UDP, click apply/ok. Do this again, giving it the name XBOX UDP, start port 88, end port 88, type UDP, then apply settings.
Now go to Firewall under the Configuration tab, under incoming click add, now select the service XBOX UDP/TCP from the drop down menu. select forward to specific IP address or similar and type in your Xbox's IP address e.g. 192.168.1.5, click log never, then apply ok. Do the same for XBOX UDP and your again click apply. That's it! you've successfully opened the necessary ports on your Router and told your Router that any incoming info on those ports should be sent to your Xbox.
Posted on Mar 19, 2009
SOURCE: Cant find certificate for wireless
To fix, you go into the properties page of your wireless connection, go to "Wireless Networks" tab and then to Properties of the chosen wireless network you are trying to connect to. Then go to "authentification" tab and untick the box saying "Enable IEEE802.1x to the availiable network" and that should solve your problem
Posted on Jun 16, 2009
What can i do log onto facebook and titter? it keeps saying unable to log onto.....
Reboot phone & then try, if that doesn't work (cures most nokia smart phone probs) then reset the account in (email & accounts)
nobody tells you this but you should power off your smart phone at least once a week to clear the memory & reboot it, it is just a little computer & gets clogged up now & then, with batterys lasting so long no 1 turns them off anymore & so much is running in the back ground that it just cant handle it anymore rebooting it sorts all that out.
Apr 04, 2015 | Nokia N9
Bt yahoo email
Are you using Firefox, by chance? update ANY browser that shows this message. The certificates should be updated automatically. To update, go to Help>About [browser name]... and you will likely see a 'Check for updates' option.
Dec 16, 2013 | HP Pavilion Computers & Internet
Can't Connect Laptops Wirelessly to Linksys WRT54G2
1.Log into router (192.168.0.1) user name "admin
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the Desktop/laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
Jun 28, 2010 | Linksys Wireless-G WRT54GS Router...
When I attempt to log onto my network I receive this message. ''Windows was unable to find a certificate to log you onto the network (network name)'' This is followed by ''Validating Identity'' which when...
This is caused by setting the encryption to WPA-RADIUS instead of WPA-PSK on the client radio. Both the router and the client are
trying to find a RADIUS server with which to authenticate your system.Switch the encryption to WPA-PSK (pre-shared key) on both ends and it will work.
Oct 11, 2009 | Toshiba Satellite 2400-S251 Notebook
Windows Live messenger Error : 80048820
The problem occurs is caused by the incorrect Microsoft Internet Explorer SSL settings. The error happens occasionally, and not all system may affected by this WLM problem. To solve the problem, following steps in the guide below:
1. In Internet Explorer, clear the Check for Server certificate revocation (requires restart) check box. To do this, follow these steps:
  1. Start Internet Explorer.
  2. Click on the Tools menu, then click Internet Options in the pull down menu.
  3. Click on the Advanced tab.
  4. Under “Security” section tree, clear the Check for server certificate revocation (requires restart) check box.
  5. Click OK button.
  6. Exit Internet Explorer.
  7. Sign in to Windows Live Messenger again.
Jan 27, 2009 | Microsoft Windows Live Messanger
My laptop internet connection will only log onto to certain web pages says there is a problem with certificates.. I have Norton 360 & Windows Vista with only 1 firewall active...
ok, norton, throw that junk away, get spybot s&d and avg free virus protection, the two of them are a billion times better than any of the trash that norton has ever come up with. other than that, i have no idea..norton does **** though
Nov 25, 2008 | Computers & Internet
Wireless network connection windows was unable to find a certificate to log you onto network
xp : go to start --> control panel ---> on the top leff click on "switch to classic view" then open network and internet connections right click on the wireless conn. then from the upper tabs go to "Authentication"  your setting should be as following :
Enable IEEE 802.1x ....... (cheked) EAP Type : Smart Card or certificate Authenticate as computer ...... (checked) Authenticate as gues ..............(unchecked)
then click on "properties"
choose "use a certificate on this computer" and check "use simple caertificate ......" and check "Validate server certtificate" click ok till u close all the boxes
:D hope that would work :D
Oct 17, 2008 | Computers & Internet
I have installed Belkin_N_wireless a8969d onto my pc. I have a work laptop that has a wireless router? already in it. however, when it tries to locate the belkin n it brings up an error message saying '...
when you say it has a router in it, you mean a receiver and you are trying to connect to the other pc without the means of an external router (network).
You need to set up the connection using windows wireless network wizard as you seem to be trying to connect 'adhoc', which is one pc to another.
It's too long a process to type here so use the wizard
also you need to check that both are on the same workgroup setting, this is found by right clicking my computer and then properties and computer name, as if they are'nt they cannot see each other.
Aug 31, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
My computer say unable to find a certificate to log onto your network linksys.
Hi there!
I'll try and help you out.
1. What's the model number of that Linksys device?
May 04, 2008 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
