Question about Hydro Systems 72" X 42" Acrylic Whirlpool Tub Bathtub
On/Off switch...Hydro Systems Whirlpool Tub
On/Off switch for Hydro Systems whirlpool tub suddenly just does not work. Do spa tubs usually have separate circuit breakers? Nothing else in house is tripped.
If in fact it is switch that is broken, I have no clue as to how to try to repair, and cannot find list of authorized local repair services for Hydro Systems.
thanks
    Genius:
  • 1,550 Answers
You can get switch from whirlpool website .
For repairing you need to buy service manual .
Posted on Jan 19, 2009
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
How to clean a whirlpool bath tub
There are three main things to tackle when cleaning a hot tub or whirlpool bath. Those things are:
1. Bacteria
2. Grease
3. Grime and dirt
To address all three of these issues you'll likely need separate products. There are liquid versions of the degreaser and cleaner, and there are tablet versions for sanitizing.
Simply fill up the whirlpool bath with warm water, put the cleaning liquid in the cleaning outlet (or if you don't have this, just pour it into the bath). Put the tablet in the bath and then just run it.
This should do the job.
Pure Spa Whirlpool Bath Spa and Hot Tub Cleaning Kit
Nov 17, 2015 | Jacuzzi Whirlpool Cetra Whirpool Drop-In...
How do you install a new on/off switch in a royal whirlpool bath?
The switch is located on the back of the pump. If you have access to the pump and you can see the tube coming out of the black box on top of the pump you might have a chance of changing it without pulling the tub, If you do not have access to the pump, one will have to be made or pull the tub for repairs. If the pump can be removed this might also make the repair go easier. The switch is available at most pool or spa stores. If you are uncertain about doing this repair call a Jacuzzi certified repair technician to do the job.
Jul 06, 2014 | Whirlpool ROYAL BRB826 Corner Tub, Jacuzzi...
Off on switch on response
need to test motor may be overheating or burnt up pump
Apr 02, 2010 | Whirlpool 2 Person Corner Air Tub By...
We have Builders #6032 and it has small hairline cracks in tub bottom. Its starting to leak into our basement. What do we do to fix it?
alot of times if you call the tub builder they have service guys who will come and fix your tub. most tubs have a 3-8 year warrenty against defects so you could get the fix for free. if not you can always try and get fiberglass resin and mix a batch up and seal the cracks yourself
Aug 01, 2009 | Hydro Systems DUO6648GWP Designer Series...
Whirlpool tub, jets come on and won't shut off. No water in tub.
Is it a jetted tub, or a air bath tub with holes or jets in the floor? If it has holes or jets in the floor, the control box is bad and needs replaced. If it is a jetted tub, there may be a water level sensor, if so the sensor may be bad causing the tub to turn on.
Jun 13, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Whirlpool not working
If it stopped working suddenly check the GFCI to see if it tripped. If you think it may be a sediment problem go to a pool and spa store, they have cleaners that can help. In most cases salts won't cause it to stop working.
May 28, 2009 | Brasstech ''P'' Trap Kit - 3013
Power switch for whirlpool tub
the easiest thing (maybe) is to install an air switch kit on the side of your tub. Here is a link to the part. Basically you install an air button on the side of the tub, install the air tubing from the nipple on the underside of the air button to the nipple on the box that plugs into an outlet under the tub. The pump plugs into that same box and the air tubing from the air button pushing onto the nipple on the box. When you push the button on the tub it will turn the pump on/off. Air Switch Kit
Jan 17, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Difference tubs and air baths
whirlpool tub has jets that circulate the water, where an air bath uses bubbles that rise gently from the bottom of the tub. Whirlpools are typically used for therapy, air baths are used for a much gentler experience. Air baths can be used with aromatherapy/essential oils. Both offer a spa-like experience.
Aug 27, 2008 | Whirlpool Pearl Ballade True Bathtub with...
Hydro Systems 72" X 42" Acrylic Whirlpool Tub Bathtub Logo
295 people viewed this question
Top Hydro Systems Home Experts
john h
Tom Chichester
Are you a Hydro Systems Home Expert? Answer questions, earn points and help others
