Question about Maytag Atlantis MAV7260B Top Load Washer
Maytag Atlantis washer fills with water and then stops. Why?
I started the machine, added the soap and clothes and after it was full it just stopped. Nothing I do gets it to move on to the wash cycle.
Cyril J
  • 45 Answers
SOURCE: Wash cycle will not start
you may have leaned on lid and damaged the lid switch , so the washer thinks the lid is open all the time unit will fill then stop with lid up.
Posted on May 16, 2008
  • 220 Answers
SOURCE: Maytag Atlantis stopped mid cycle
Bad/worn/broken lid switch look at the back of the lid there is a little lid cam there that hits a switch,if this switch isn't engaging it will do just what you are describing.use a small screw driver to push the button in and see if it starts.
Posted on Sep 03, 2009
  • 100 Answers
SOURCE: maytag wahser not agitating
Either your transmission is bad which might carry a 5 year warranty or your lid switch needs replacement
Posted on Nov 15, 2007
  • 27 Answers
SOURCE: Maytag Atlantis MAV7600AWQ Washer. Delayed fill
ALL WASHERS COME WITH SCREENS AT THE
WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
NEEDED AND GO FROM THERE.
Posted on Mar 07, 2009
SolutionGuy
  • 331 Answers
SOURCE: Washer is over filling.
AV,
Yup! I know what's going on (the tip off was when you said, "The water does stop when I push the timer off"). See? the timer, as I'm sure you know, supplies or "directs" power to each component in the washer... kinda like a conductor does an orchestra. When you push the timer knob to "Off", you shut down the symphony thereby removing power from all of the components. Make sense?
When you set the water level and pull the knob, the level switch tells the timer that the tub is empty and request water. The timer complies and sends power to the water valve. When the water level is "satisfied", the level switch tells the timer to remove power from the valve and start the "agitation" cycle.
Here's what's happening, the level switch isn't talking to the timer. I think the part number is 22002705, but I'm not sure because I don't have the full model number. Call you local appliance retailer and provide them with the full model number to be sure, OK? Since you already have the machine apart, it'll be easy to replace...
Oh yeah, here's a picture of it... see if this one matches the one on you machine. This might confirm the part number.
And another thing, now that you've experienced a washer flood (ain't it fun?), you might want to consider getting yourself one of these. They're super easy to install and it'll provide that extra bit of insurance against this happening to you again.
Don't forget to rate this solution. And thanks for using FixYa!
SG
Posted on May 30, 2009
Maytag atlantis washer water won't stop filling with water even when power is off.
water fill valve have a particle of trash or deposit from water.replace water valve and problem solved.
Jan 31, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis - dead and full of water
with the atlantis i would have to say yes
open the control panal,
pull out the lid switch and unplug it,
give it a shake if there is any rattle
thats your problem
you can order a new switch and plunger from
appliancepartspros.com
looking for part number
AP4008646 about 20.00
Oct 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer full of clothes and water and stopped- how to reset?
According to my experince let the machine stop and complete shut power and try after 10 minutes
Oct 03, 2009 | Maytag PAV2300 Top Load Washer
Sits Pretty Doing Nothing,ARG!
Any codes on the front?. Try here to see if it's any help: Type in MAV6000 only
http://servicematters.com/maytag_library/html/index.html
Danwan
Sep 12, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Sep 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water fill, discharge and noise problems
to reset the water level you have to turn the knob all the way over as far as it will go and then come back to large load.
Feb 18, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis Washer, model MDG6200AWW
I just hooked up my washer and after filling it the motor hummed and smelt like it was starting to burn! Is this a fixable problem?
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Does complete cycle
When would the washer stop?
Is there water in the washer when it stops?
Feb 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Open Questions:
Maytag Atlantis MAV7260B Top Load Washer Logo
114 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
