Question about Garden
How to test crankcase pressure on a husqvarna k760
  • 2,239 Answers
You would need to do a vacume test, there are special blanking plates available to seal off the inlet and exhaust, and a plug to fit in the spark plug hole with a conection for the vacume gauge, if you need the part no.s let me know and i will find them.
Posted on Jan 05, 2013
  • 1 more comment
  • jay bun Jan 07, 2013
    thanks please send me the part #'s
  • Andrew White Jan 08, 2013
    The blanking plate for the inlet and exhaust comes as a kit part no. 544103301 you should be able to get a vacume/pressure gauge on the net the Husqvarna one is not made by them it is called mighty vac and is known under that name
  • jay bun Jan 09, 2013
    andrew white thanks for the info ,I ll order this . jay bun
Husqvarna wont idle k760 what do I need to do
Replace the air filters.
All cutoff saws plug air filters to the point they cannot breath. Do not replace just one, replace them ALL !
You might also need to replace the spark plug.
Feb 02, 2017 | Husqvarna Garden
Saw starts, but why does it run few seconds then quit?
Has it enough compression ? because i have the experience it have a questionable closing system for carburetor air filter it is not always fully locked take care to close it replace parts if its not as soon as this problem is there or its to late , on the way it should but when it is not good closed it leaks in much cases and the piston had often grooves by polution from graveldust it can have lost compression by it first to do is control the piston.
In the event that all of this is not the subject the tank airiation and fuelhoses to control.
51MM Cylinder Piston Kit For HUSQVARNA PARTNER K750 K760 REP 506 38 61 71
Feb 11, 2016 | Husqvarna K760 Cut-off Saw,2-cycle...
Why is throttle stuck wide open?
Could be a couple of things. could be a return spring sticking on the carb, or the throttle cable has frayed and sticking on. I've added the breakdown manual for you.
http://www.mediafire.com/download/68zm589mejh8jnq
Dec 20, 2015 | Husqvarna-Target Husqvarna K760 14 Inch...
How to replacethe primer bulb
look only the brand and numbers of the used carburetor WALBRO most of the times or ZAMA the model
FIND PARTS FAST look there
Sep 11, 2015 | Husqvarna K760 Cut-off Saw,2-cycle...
Husqvarna k760 will not prime and/or run properly
Get a carb. rebuild kit ,these models have carb.problems and need rebuilding,shop charges 70.00,get kit for 10.00 and diy.
Dec 11, 2012 | Garden
One question, im looking to buy a husqvarna k760 demo saw, i need to cut metal, such as truck and trailer frames. just need to cut them down to length so i can load and bring to scrap yard. i figure it...
The K760 black cutter blade is called a Cut-n-Break blade. The manufacturer states that it has an improved stable core to increase its performance. I have a friend who recycles scrap metal and uses the Mastercraft 5" dual cutter. It cuts through metal like butter without any kickback.
Hope this helps,
Handie Andie
Mar 26, 2011 | Husqvarna Garden
Gas in the crankcase
need to do compression test to test piston rings and check carb float possible sticking allowing fuel to keep flowing
Apr 08, 2010 | Husqvarna 22 Hp 46" Deck Yard Tractor
Husqvarna 357xp flooding
2 things you might want to look at.
1) Vacuum test your fuel line. This is a common problem with huskys.
2) Check to see if the exhaust port or spark arrestor screen is plugged up. If so pick out a carbon deposits.
Apr 09, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
182 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
