Question about Refrigerators
No door adjuster on my kitchen aid superba o move the door up and down.
    Genius:
  • Refrigerators Master
  • 1,669 Answers
Yes, there is no adjuster so you will (a)just have to be clever and use an old carpenter's trick. To raise the door you simply place washers of different thicknesses over the hole where the bottom pin of the door goes in.
Posted on Jan 04, 2013
  • 42 Answers
SOURCE: Kitchen Aid Superba
To the person who hears a clicking sound you are correct, the compressor is trying to start but is not starting and that causes the overload to trip (click) wait a short time and it all happens again. Either the start relay is bad or the compressor is locked up. Less than 1 year old should be in warranty. If you want to try to check the relay you will need to unplug it from the side of the compressor. Once removed try to shake it and if you hear a rattle noise the relay is bad. To test the compressor you would need a test tool or be very experienced to perform accurate test.
supertechks
Posted on Nov 22, 2007
  • 1073 Answers
SOURCE: Kitchen Aid Superba side by side
check the relay on the compressor
Posted on May 16, 2008
  • 1314 Answers
SOURCE: Kitchen Aid Superba...freezer shuts off..
sounds like your defrost drain is frozen or blocked its in the freezer side under the back panel beneath the evaprator
Posted on Jun 03, 2008
IFIXALL
  • 868 Answers
SOURCE: Kitchen Aid Superba ksrg25fkwh05 10-03
Bottom line Steve, I'd place about 97% of my $$$ on the optics board.Change it ,it comes as 2 parts and is a daily issue and is simple to change out. This is the result of Technology making a step in the wrong direction ...........AGAIN !
Steve, I'm Here to Help !
Please Rate This !!! Thank You !!
Posted on Jun 12, 2008
  • 142 Answers
SOURCE: Kitchen aid -Superba 42,
Make sure the fan motor is running in the freezer.
Posted on Oct 01, 2008
Is the filter behind the kick plate on the Kitchen Aid Superba made in 1998?
Hi, the filter should be on the bottom kick plate and should have a cap of the same color as the kick plate.
Hope this helps
May 23, 2014 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba ksrg25fkwh01 wire harness
Called Kitchen aid and protested, frig was 4 years old at the time. door was almost $1200 to replace. Kitchen aid paid for new door and installation
Sep 19, 2012 | KitchenAid Superba Architect KSCS25INSS...
Problem with water and ice
My kitchen aid superba sie by side stopped making ice. I've changed the water filter and did the trouble shooting options in the book. Everything else is fine. Can you give me any suggestions
Mar 16, 2010 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aide Superba 48 1997, refrigerator door remains ajar,Fix?
They actually make a guard that acts as a height shim. You do need to remove the door to install it though. Try looking at appliance411 they usually have some insight into out of the ordinary parts. Hope this helps. Good luck.
Aug 04, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
Problem with KitchenAid Superba KSRG25FK Side/Side Refrigerator
I found you looking for keep en mind kitchen aid is made by whirlpool good luck :) http://www.appliancepartspros.com/partsearch/model.aspx?model_id=504094
Jun 12, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Kitchen Aid Superba - door needs adjustment
there is two bolts oin the very front of the unit behind the kickplate the oiu can turn clock wise until there is a slight tile toward the back of the unit so that the cams on the doors will have a little bit of gravity to helop them stay shut.
Mar 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid superba door problem
HAVE YOU TRYED ADJUSTING THE TOP HINGE?MIKE
Oct 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Sep 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
