Question about Philips Dvp3880k All Region Multi Region Code Free Zone Free Hi-def
Change region of Philips DVP3880K/79
How do I change the region code of Philips DVP3880K/79? Other instruction of internet failed to work (remote doesn't have number keys on it).
jaffa012001
  • 376 Answers
SOURCE: changing region
1) Go to Setup page
2) Preference page
3) Press 138931
4) Press up/down key to select region code
Posted on Aug 12, 2008
SOURCE: Region Unlock code for Philips HTS 3152
Thanks dude,
Not sure which trick worked, but i did ur classic 7,3,4,4,6,6,0 trick, got no message from the player. So i did pressed 0000 after that. Still no message appeared. But when i pressed start....it worked!!!!!!
Thanks a ton!!!!!!!!!!!!!!!!!!!!!!!!!!!!! God Bless...
Posted on Dec 08, 2008
SOURCE: Change regions
Try the following - it worked for me with my DCP850/37...
To fix, follow the instructions below. 1. Turn your machine on. 2 Press Setup on the remote. 3. Press Preference. 4. Type on remote 9653. The use arrow keys to select Region "0". 5. Then click OK and the machine should now recognise multiple region zone DVDs.
Posted on Jan 07, 2009
  • 189 Answers
SOURCE: How can I change my PHILIPS DVP5992/37's Region
HI!
I think you'll find this very useful!
To multi-region your machine:
press Setup
select the Preference Tab
Press 1,3,8,9,3,1
Press up/down key to select "0"
and press menu to exit.
Good luck to you and enjoy!
Posted on Jul 26, 2009
  • 6 Answers
SOURCE: Philips Magnavox REM-350 Universal Remote ENTER/SELECT Key Proble
See if fresh batteries help.
Posted on Oct 18, 2009
How to unlock regional code of philips HTB3510 3d blueray player?
Check current region code
Open the Philips HOME Screen
Type on your remote: 8520
This will display all of the current settings for your player.
Example: Region_Code: DVD(2) BD(B)Change region code
Turn on player with no disk inserted
Press "Open/Close" on the remote control until the tray is open
Press 8689310 - 0 means all region
Press 8689311 - 1 means region 1,
Press 8689312 - 2 means region 2,
Press 8689313 - 3 means region 3,
Press 8689314 - 4 means region 4,
Press 8689315 - 5 means region 5,
Press 8689316 - 6 means region 6.
Now the front Buttons might not work!
Go to SETUP and click on RESET FACTORY SETTINGS
Wait until the player restarts and now you can play all DVD regions
Oct 08, 2014 | Philips HTB3510 5.1 3D Home Theater System...
Crack code
here u go rate me Fix ya
1/press setup
2/go to the prefernces page.
3/type 9 6 5 3
4/select region
solved 100% by Fix_You
Aug 18, 2008 | Philips DCP855/37 Portable DVD Player
Philips dvp 2850/79
It is not possible to unlock region codes. Most DVD (blue ray players) allow you to change the region code you can play, once. You can't even switch back to the original code it was set when you bought it.
If you really want to play disks, the only way to get around this, to rip the disc on a computer, and burn it on the computer, region free. For that you need special program m's, but in some countries you can get these programs for free.
Or buy several players, each set to a different region.
Sep 16, 2014 | Televison & Video
How do I change region code on dvd player?
I'm almost positive you can't change the region code, because it is in the firmware of the DVD player.
Jul 21, 2014 | Philips Audio Players & Recorders
PHILIPS DVP3880K/79
I had the same problem with my hts5562 then i realised i can use my dvd copy program to back up my region 1 dvd`s, the back ups are region free and playable. I hope this is helpful
Jan 25, 2013 | Philips Televison & Video
Can I change my Philips DVP3950 to region-free?
Before you begin please ensure you have connected your DVD player to your TV and both have the power turned on. Once you have connected your TV please follow the instructions below using the remote control.
Select SETUP then press OK (via the DVD remote control)
Using the arrow down button highlight PREFERENCE
Press NEXT, PREVIOUS, NEXT, PREVIOUS (the >l, l<, >l, l< buttons in the bottom of the remote control ).
Your current region should show on the TV screen
Using the arrow down button select region code 0
Press OK
Press the 'HOME' button
You have now completed this process. Enjoy! (from multi-region.net) Also works for DVP3800. The remote control has no numbers on model DVP3950
Dec 23, 2012 | Philips dvp-3960 region code free dvd...
I need a Philips DVP3100/79 region unlock code
-Open disc tray
-Press "Setup" (on the remote)
-Highlight "Preferences" (bottom of setup screen)
-Enter "138931" on the remote
-The current region code will now be shown
- Use up arrow button on remote to select 0 to make it multi-region
-Press "OK" on remote to confirm change
-Press "Setup" once more to return
Oct 21, 2010 | Philips Televison & Video
Wrong region
Change your region to multi-region so it can play discs from any region but please check the instruction manual to ensure that changing the region does not void the manufacturers warranty.
Turn the DVD player on, and press "open" on the remote control or on the machine itself.
Press this code into the remote: 789
Press OK, then press 0. A "0" should appear in the lower left side of the screen. For Phillips, zero is the code number for multi-region. In place of the zero, you can also press the number of the specific region you want to play.
Play the disc to check if it works.
Jul 30, 2010 | Philips Televison & Video
Changing of region code
I have the same system and I changed the region code to muti by pressing STOP 7344660 after opening the tray as per instruction I read in the net.. It worked.. on the TV screen it displayed region as 0
Aug 05, 2009 | Philips LX3600D System
Philip PET 702/98 Poratable
On remote push "Setup", use arrows to find out page "Preferences", enter 9653 and change region code to 0.
Mar 31, 2008 | Philips PET702 Portable DVD Player
Philips Dvp3880k All Region Multi Region Code Free Zone Free Hi-def Logo
20 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
