Question about Everest Refrigeration Refrigerators
E1 error on everest aircon
1.5 everest split type aircon
  • 400 Answers
SOURCE: WATER LEAKING FROM MY SPLIT TYPE LG AIRCON
1. Do not set the aircon too low temperature in overcast weather, this will cause ice ups and water dripping. Optimal comfort zone temperature is 24c.
2. You need to open the grill cover on the front of the aircon which unclips either end left and right with a finger pressure. You will find two filters which can slide out and should be cleaned. First tap them together to remove dust, then you can wash them with mild soap and cold water.
3. There is the third possibility that an insect has made a nest in the drainpipe. You should look on the outside of the building and locate a plastic drainpipe. You can either blow into this pipe with your mouth or get a blower. This will unblock any restriction in the drainpipe.
Goodluck and ratemeplease.
Posted on Mar 19, 2009
  • 3600 Answers
SOURCE: my split type aircon wont work properly, water
try cleaning the port for the drain plug, when the air is damp outside it will condence a large amount of water. Aslo make sure unit is level so it will drain properly.
Posted on Jul 19, 2009
  • 51 Answers
SOURCE: yonan ac split mini 1.5 ton error codes E1
CHECK ROLLOUT SWITCH AND CHECK FOR A POSSIBLE
GROUND FAULT..OR FUSE..
Posted on Apr 13, 2010
SOURCE: my split-type aircon is contantly
there isa circuit problem in ur ac
Posted on Nov 09, 2010
  • 57 Answers
SOURCE: how to install split type aircon?
Plan the location of your outdoor and indoor unit. Make openings for the pipes and wiring's that should be accessible for repairs or maintenance. Never place the condenser near the walls, and follow the allowable clearance from the walls. Same thing follows for the indoor unit make allowance from the ceiling and it should be tilted to drain the water from the drain pan. Make the piping and wiring connection following the suppliers recommendations. Drain pipe should be lower than the wiring installation. Do not use seal tape for threaded connection, only apply refrigerant oil and tighten all nuts. Leak test or vacuum the lines from the valve fittings outside the condenser to the evaporator( in and out of the evaporator ). If vacuum or pressure stays unchanged for an hour, there is no leakage. If you applied vacuum, just fully open the service valves. If you pressure test the line with Nitrogen, release Nitrogen gas by loosening a little the bigger pipe nut from the condenser until no pressure comes out.Then open the small service valve from the condenser a little until pure freon comes out of the loosen big nut and then tighten it. Full open all service valves and unit is now available for operation with power supply.
Posted on Sep 03, 2011
The indoor of carrier split type aircon is having a heating function, if they have , how can I set in the remote control
The Split system control is not working and you need to check thermostat wirings and the control on the splitter
Jan 12, 2015 | Carrier Heating & Cooling
Which is better, a split type aircon or the regular one for home use?
It all depends on your requirement, However people prefer Split type as it less noisy, Can be installed at any place in the room. Easy to operate. Easy to maintain. Does not interfere with the layout in room. Wall mounted/floor resting.
May 14, 2011 | Heating & Cooling
Need remote for a v-lec split type air conditioner
Why not try the dealer selling V - lec aircon? They are
in the best position to know where to get the replacements or clone remote controller for your unit.
Better still try surfing the internet, V-lec Aircon may have
a web site to service their clients. May this info, help you.
Jan 06, 2010 | Heating & Cooling
What are the instructions re water drainage, I cannot find the manual
Basically the drain pan should tilt towards the drain itself. This so that water would not leak inside. It goes for split type and window type aircon.
I hope this helps
Jul 02, 2009 | Heating & Cooling
My carrier split type non-inverter aircon always blinking
It indicates afault within the unit. Give Carrier a call and get it serviced.
Mat
Jul 01, 2009 | Carrier 36KCARMS Air Conditioner
I have a sanyo aircon split system and i need to know the icons
the icons are snowflake = cool, raindrop = de humidification, fan blade = fan, sun = heat. hope this helps.
Jun 11, 2009 | Sanyo Split System Air Conditioner
Mar 19, 2009 | LG LSC121PMA Split System Air Conditioner
Refrigerators Logo
376 people viewed this question
Top Everest Refrigeration Refrigerators Experts
mike cooper
Vernon Taylor
ray gallant
Are you an Everest Refrigeration Refrigerator Expert? Answer questions, earn points and help others
