Question about GE Profile Over the RanMicrowave. Spacemaker XL 1800 1.8 cu. ft
GE spacemaker xl microwave oven will not heat
How to troubleshoot, turntable rotates, light works, sounds like working, but slightly louder than normal
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
My guess is the magnetron is bad. It is rarely the transformer
Posted on Sep 23, 2014
MicrowaveSvc
  • 9047 Answers
SOURCE: ge spacemaker xl microwave oven turntable
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
If yours is a GE, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If yours is a GE, there should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Aug 02, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: GE Spacemaker XL1800 does not heat
Possible bad heating element, You should remove the cover of the unit and look at the heating element with the power off. Until you get your problem resolved I would recommend not to even turn it on due to the fact that you are unsure what is going on and you smelt some burnt smell. Just for safety until you fine the problem
Posted on Feb 21, 2009
djicenova
  • 319 Answers
SOURCE: Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Posted on Mar 21, 2009
SOURCE: I have a working GE Spacemaker xl 1800, but need
Hello ,
My husdand broke our plate. Did you find one yet at a resonable price? If so email me at cshalitis@comcast.net and let me know how much you paid for it.If not you can call GE at 1-866-540-2797 and they will transfer you to the parts department and then you can order a new one. I just called ther but the parts department was closed. So call there M-F 8am-9pm.Good luck!
Posted on Mar 29, 2009
ginko
  • 19396 Answers
SOURCE: GE Spacemaker Microwave not heating
If it is working but not heating, then test the high voltagecapacitor,the rectifier diode.or the magnetron. If all this are fine,test the control board.If turntable is not running check also the doorswitch.
The diodeandcapacitors can be tested. The capacitor must be allowed discharge beforetesting, or you risk to get electrocuted, evenif power is off.Capacitorscan get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Posted on Apr 27, 2009
Ge profile spacemaker 1800 xl microwave no heat
The magnetron tube may have died. Not worth repairing unless under warranty.
Feb 03, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
Mar 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE spacemaker JVM1542 that is not heating the food, the noise level is louder, light works, plate rotates.
sounds like its not producing any high voltage for the mag tube, check your h.v diode, then your h.v. capacitor for being open
Oct 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 does not heat. All other functions appear to be working normally, the light comes on and the turntable functions. When turned on, it makes a humming noise slightly louder than normal,...
Feb 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave, Model J VM1650AB5 Not heating food
If you sure that lauder sound comes from turntable motor than it needs to be replace.
Nov 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker xl microwave oven turntable
Aug 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Over the RanMicrowave. Spacemaker XL 1800 1.8 cu. ft Logo
299 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
