Tv is on ANT want to put it on CBL but is not allowing me to
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Provide more details please. What is the problem you faces with this remote control?
Posted on Jan 04, 2013
I'm trying to hook up my DVD player to my TV but my TV doesn't have a yellow jack only red and black
If your TV doesn't have a Video IN jack (Yellow) then you would have to attach your dvd by antenna (Coaxial) cable. What does the DVD have on the back ? EG: Video Out is Yellow, Red is Right Audio, White is Left Audio. If your DVD has Ant in & Ant Out you can use a coaxial cable from Ant out to your tv's antenna In socket and put your antenna cable (from your wall socket) to Ant in on the dvd. Turn on the dvd and put your tv on a blank station and tune your tv till you see the dvd screen . lock it in and that becomes your DVD channel to watch your dvd's.
Hope this is some help.
Sep 07, 2015 | RCA Televison & Video
How do i install my television proscan 3274
You must put an ant or cbl in to connector on bacb select menue and scan to pick up channels.
Feb 20, 2015 | Proscan Televison & Video
37hlv66 only allows Ant, not Cable
hi on your tv select dtv go to first time installation
Jan 25, 2014 | Toshiba 37HLV66 37 in. LCD HDTV/DVD Combo
I'm using a Time Warner remote as a universal for my TV but when I go to change channels, it just lights up the CBL button and doesn't change the channel. Can I program it to my TV or will it
Hi, you need to de-activate the "programming channel control lock" option. You can see instructions in the manual for the remote. They are as follows:
  1. On the remote control, press CBL once; It will blink once, Press and hold SETUP until the CBL key blinks twice.
  2. Enter 9 7 3. The CBL key will blink twice.
  3. Press CH- once. The CBL key will blink four times.
    Now the remote control will provide TV and VCR channel-control capabilities while in the TV mode.
for any other information with programming this remote:
Download the 1056B01 operating manual with codes for free.
Nov 30, 2012 | Televison & Video
I have a Denon AVR 888, I want to use the reciever for my audio coming from my TV, I have plugged in a HDMI into the in port and connected it to my TV, I do not get any audio from the reciever
HI,
If you want to get the audio of tv program through the AVR then your tv should have a HDMI out port. Because you have connected the cable directly to tv. You didnt mentioned anything about your tv (make and model number). So its not possible to give you a final answer.
Check on thing isthere ia nsy RCA audio output in your tv. All tvs will have RCA audio out put. Wich you can connct to the TV /CBL in put of your AVR using a RCA cable. Then select the TV/CBL Using the SOURCE SELECTOR on the frond of the AVR.
Another Way is if there is optical out put on your tv then you can connect the optical out to the AVR's OPTICAL IN 1 or 2 Using an optical cable. Then you have to got to the input assignment menu of
the AVR and then you have to assign the optical 1 or optical 2 to wich you have made the connection. Here i have added the link to the user manual of the AVR. Check the page number 22. Which shows the menu tree. To assign the optical input for TV/CBL you have to go to the Input set-up there you will find the ASSIGN on the under CD,AUX etc menu.
This setup required if you use OPTICAL input of the AVR. Check the page number 14 for the connection diagram.
IF you are going to use RCA cable the simply connect one end of the rca to TV's AUDIO OUT and other end to the TV/CBL input of the AVR. And then select TV/CBL.
Here i have added the picture of RCA cable that you nee for making such connection between TV and AVR.
USER MANUAL
Ajin
Apr 26, 2012 | Audio Players & Recorders
I have a Mitsubishi VS-50705. It's a 50inch rear projection TV. The TV only allows me to switch between the ANT A and ANT B inputs, none of the others. When I plug in cable to either ANT A or ANT B nothing...
Hi con,
Welcome to FixYa.
My name is John.
I will be assisting you with your issue.
Go to SET-UP in the MENU.
Then do a CHANNEL SCAN or AUTO PROGRAM SCAN.
You should be good to go..
Thanks for choosing FixYa.
John
Jan 06, 2011 | Mitsubishi VS-50705 50" Rear Projection...
How do i use the ant. passthrough on tv2 in dual mode w/ dish dvr625
ANT. passthrough for an ant. connected to your 625 receiver will only work on tv 1. The only way to do this is to RF modulate your tv 2 coax to an RCA and hook the RcA cable to your tv2. then use another ant. to connect coax allowing you to pick up dish programing on an input and then going to the channels to enjoy local over the air programming.
Nov 26, 2009 | DISH Network DVR-625 DTV Receiver /...
I need remote control code number for motorola dvr 6416 III
If this is a remote by UEI or Atlas (usually the black remote that the cable company supplys with the box) the code is 1376.
To set the code, you will need to do the following:
Unlock the Cbl button:
Press CBL once. it will blink once.
Press and hold SETUP until CBL blinks twice. Release setup
Press 982
CBL will blink 4 times, indicating it is unlocked
Program the code in:
Press 1376
CBL will blink twice if the code is accepted.
Re-lock the CBL button:
Press 982
CBL will blink 2 times, indicating it is locked again
If it is not a UEI or Atlas remote, let me know the remote make and model
Dec 01, 2008 | Arris DCT6200 DTV Receiver
GE universal tv remote control
Most remotes use the same code sets. Here's what Radio Shack says for your brand:
0236,0463
let me know.
Nov 29, 2007 | GE JASRM24912 Remote Control
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
