Tv stays in standby mode - Televison & Video
    New Friend:
  • 8 Answers
The number of blinks indicates the error code. It appears to have been 7 but I am not sure as the video cut off right at the 7th blink. Regardless, 7-10 blinks indicates various issues with the power supply or one of the various boards. Unless electronics is your thing I'm afraid you will not have much choice but to get it repaired professionally. If it is your thing, here are the error code results for 7-10:
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (fly back transformer), or the associative components in the high voltage circuits are defective on the D board.
Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. This could also be a Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the "D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Posted on Jan 04, 2013
2 Suggested Answers
freetek
  • 5568 Answers
SOURCE: TV & Tuner stays in Standby mode
Assuming you have tried changing batteries in your remote and any front panel power switch your set has, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.  What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Oct 29, 2008
What does it mean when your tv states standby and you cannot turn it on or off with the remote control?
How to Fix a Sony Plasma TV With a Standby Problem ...
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
A standby mode problem on your plasma TV can result in the TV being stuck instandby mode, ... You can troubleshoot a standby mode error by performing a power cycle or restoring the TV to its factory settings. ... Turn the television on. ... What Does It Mean When My Rumor Touch Says the Camera Is in Standby Mode?
tv on standby mode cant get it off - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-1676193/standby-mode.html
Dec 27, 2015 | Televison & Video
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
TV won't turn on. Stays in Standby mode
Someone is going to have to go inside and check voltages and other things --no brand or model is indicated here so this is as much as I can suggest.
Dec 20, 2012 | Televison & Video
Logic colour TV stuck in standby mode.
hi! try floating the b+ pin of the lopt and check if you have a normal b+ if it has. the lopt is the culprit.
Aug 11, 2009 | Televison & Video
My hd4208TIII-PDP WONT COME OUT OF STANDBY MODE
You Need a new Power Supply, part # LJ44-00025A
buy it here for $139 http://www.adc-ast.com/
I have my tv working like new.
If you want this time the power supply last, do not turn off, just press tv/video button to switch input source, let the tv in sleep mode.
Credit: User IMJR
Feb 28, 2009 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
SHARP 29" TV switching off to Standby
have you tried changing the batteries just to elimate this problem
change them
sometimes if the batteries are low in electronic devies, they send a wek signal to its receiver (your tv),
your tv gets confused and then switches itself to standby
if you have changed the batteries and this problem still persists
it can only then be th PSU or power supply unit, take it to your local tv repair shop of mastercare somewhere like that, its going to be cheaper to get it repaired than replacing the whole tv
PSU'S generally 20 to 50 pounds depending on model
don't deo it yourself though unless you've got a capacitor discharger (or a nice 25KV will be on its way to your body)
hop this helps mate, let me know how you get on
Nov 10, 2007 | Televison & Video
TV Switches itself back to standby mode continuously
if your remote is ok then this is due to power supply failure in your tv. either it is loose in oscillator ckt in switching section or it has failed. if not tech person call tech to fix it. not a major problem.
Oct 07, 2007 | Televison & Video
Televison & Video Logo
135 people viewed this question
Top Televison & Video Experts
