Question about Technics Audio Players & Recorders
Turntable spins too fast
Sl-3350 spins too fast
5 Suggested Answers
djproaudio
  • 515 Answers
SOURCE: technics SL-L92 directdrive automatic turntable (needle fixed in lid)
Not sure what could have happened here. Maybe a wire came loose - doubtful, but possible. You will have to open her up to see if there is anything unusual inside. Or, you'll need to take it to a service center for a diagnosis.
- Davis
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
www.1200s.com
Posted on Jul 23, 2008
dvdcdlaser
  • 1285 Answers
SOURCE: turntable spins too fast at both speeds
this is belt driven turntable....have you tried adjusting it via the pitch control or even getting another belt for that turntable....
Posted on Jul 06, 2009
  • 32 Answers
SOURCE: I HAVE A TECHNICS TURNTABLE SL-QD35 THAT IS DIRECT
i got my turntables repaired by these guys www.technmics1210repair.co.uk
i did they made my setup work like new so im going to spread the word.
give them a shot
Posted on Apr 18, 2010
SOURCE: panasonic automatic turntable model sl-hm42
I'm having a similar issue - except my panasonic sl-hm42 platter is moving too slow on 33 1/3 settings (don't have any 45's to try). It's a DC model, so I would think there would be some kind of pitch control settings or screws somewhere on it but I can't seem to find them.
Does anyone know if it's possible to adjust the pitch on this model turntable? Thank you!
Posted on Nov 23, 2011
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
Technics Sl-1210 MkII spins backwards
As the turntable was hit hard then an internal inspection should be done to look for signs of phyical damage. It could be anything from broken parts to bad soldering or a crack on the PC board. I rather suspect it should be obvious what got damaged when you look inside.
Feb 28, 2013 | Technics SL-1210 Turntable
Need a needle for a TECHNIC SL-3350
It's 'TechnicS' and 'stylus'. Wouldn't a web search have been faster?
"TECHNIC SL-3350 stylus"
But even 'technic" and 'needle' would have worked.
http://www.lptunes.com/Technics-SL-3350-turntable-stylus-replacement-p/tstsl3350.htm
Sep 01, 2011 | Technics Audio Players & Recorders
The platter on my 15 year old SL-BD22 turntable does not move when I move the tonearm into postion to play a record. Do I need a new motor? If so, where can I find the original equipment, what will it...
Not certain you will need a new motor - yet- !
First since the arm movement turns on the turntable some kind of switch must come into play. These break or move out of poistion, so check that first. The access I suspect will be through the base of the turntable.
As most of these types of turntables use a 12 volt motor, you can attach a 9 volt battery to it's terminals and that should make it spin. If it's dead sluggish or doesnn't spin fast or at all, it's dead. If it does spin then there's something up with the power supply section to it.
Jan 23, 2011 | Technics SL-BD22 Turntable
I have just bought a pre-owned Technics SL BD-22 turntable and the speed is variable - when I adjust the pitch adjustment wheel it seems to get worse. On listening to familiar music it seems to be running...
Have a look at the bottom of the turntable. This type of turntable often have speed adjusters. They might be covered by a sticky label or something. If you can't see that go inside by removing the bottom and look inside for them. There should be two, one for each speed.
Sep 21, 2010 | Technics SL-BD22 Turntable
I HAVE A TECHNICS TURNTABLE SL-QD35 THAT IS DIRECT DRIVE AUTOMATIC THAT IS SPINNING TO FAST.
give them a shot
Apr 03, 2010 | Technics SL-1200MK2 Turntable
My platter spins fast out of control
At a guess from the minimal informaton given, i would say the drive motor has gone. I would suggest taking it to your nearest dealer or service center for a full overhaul, appart from that, visit e-bay.
Oct 24, 2009 | Technics SL-1200MK2 Turntable
Counter clock spinning
pitch slider can cause an unstable motor (clean with can of air and switch cleaner) if it spins counter clockwise it will be the brake. there is a little screw in a hole under the platter to ajust the brake speed.
Jul 14, 2009 | Technics SL-1200 Turntable
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
