Question about Motorola Mobility MING A1200
Motorola a1200 i have a a1200 and trying to get it to work with at@t wireless internet. i have called them and they say they dont have information on the phone because it is a locked phone. can you help. thanks brooke warren
0 characters
1 Points
Unable to send MMS
I have a Motorola A1200 n it is unlocked. My internet is working but I still can not recieve or send picture mail
Apr 16, 2009 | Motorola Mobility A1200
I have cellular one and own an unlocked a1200
You need to set mms and internet settings for your phone . Which phone company do you use? (eg.Vodaphone.
Mar 07, 2008 | Motorola Mobility A1200
Motorola A1200 "Ming"
Try your settings again. Profile Name = MMS Homepage URL = Proxy - Check this box IP address = (fill this in) Port = 8080 Linger Time = 90 DNS - Uncheck this box DNS 1 = blank because unchecked above DNS 2 = blank because unchecked above Bearer = GPRS Advanced Settings - Check this box APN = wap.cingular Login ID = WAP@CINGULARGPRS.COM Password = CINGULAR1 Save the Advanced Settings Save again Profile Restart Phone Go back to Mesages, MMS settings, MMS Profile and select it, the under options Activate Try to send a pic text / MMS message It could be a password issue if you set up a wireless window on the cingular/att website, not your account password, but the one for the wireless window...rather than CINGULAR1 it could be that password or could be the last 4 digits of your wireless number. If that still doesn't work - contact tech support at 888-892-9760 and make sure it is tech and not a regular agent and have them go through your password and other settings from their end and to make sure everything is enabled
Jun 24, 2007 | Motorola Mobility MING A1200
I cant tap on the Master reset option
1234 is the universal unlock code, then reset code to what u prefer, HONESTLY DOES WORK.
Jan 20, 2009 | Motorola Mobility A1200
Phone is locked i dont know the lock code
Call 1-800 MOTOBLU and they can unlock it for you.
Most default codes for Motorolas are "0000 or 1234"
Oct 22, 2008 | Motorola Mobility A1200
Motorola a1200
I have seen a thread a while ago, I guess it was in have a look there.
You need to have the IP etc. from your internet provider to insert them in the configuration.
May 24, 2008 | Motorola Mobility A1200
Motorola Ming A1200
The easiest solution for this problem is to use a wireless bluetooth connection instead of the usb connection. I have had the same phone for at least a year and a half and have never gotten the usb connection to work. Use a buetooth adapter for your computer and set up the connection with the wireless settings and it will work, it might take a little longer, but it will definately work.
Jan 25, 2008 | Motorola Mobility MING A1200
I bought a motorola a1200 ...
Ask ur subscriber he 'll send u the settings for MMS & Internet.
Jan 15, 2008 | Motorola Mobility A1200
Forget unlock code for motorola a1200
Call 1-800 MOTOBLU and they can unlock it for you. Most default codes for Motorolas are "0000 or 1234" try this if not then try the Motorola number.
Oct 24, 2007 | Motorola Mobility A1200
Ming a1200 won't receive calls
I have been facing the same problem on motorola rokr e6, exactly the same problem i guess fido changed something in there chips frequency, i wil be made crazy if that happened
Aug 02, 2007 | Motorola Mobility MING A1200
Motorola Mobility MING A1200 Logo
27 people viewed this question
Top Motorola Mobility PDAs Experts
David Payne
David Payne
Abby Carter
Are you a Motorola Mobility PDA Expert? Answer questions, earn points and help others
