Question about Epson Stylus Photo R2400 InkJet Printer
Hi my name David and I to have the 2400, my paper wont feed throu and when it does it goes throu none stop,with out printing I need help please.
I had the same problem with my R2400, it was the feeder mechanism and was fairly easy to sort (for me anyway). If you look in the paper feeder area there is a grey roundish wheel in the bottom right hand corner (looking from above and the front). It often gets dust and fluff etc in and around it and therefore fails to feed the paper through correctly. Try cleaning it with a rough-ish cloth (like a dry flannel etc) - this worked for me.
Alternatively what can also work (as I discovered myself prior to solving the problem) was having a stack of paper in the machine. I.e having multiple sheets in the paper feeder also seemed to solve the problem.
I still get the issue occasionally but it is far less prevelant.
HTH :)
Posted on Jan 07, 2013
SOURCE: epson cx3900 printer
cartouch
Posted on Nov 21, 2007
boomx2baby
  • 29 Answers
SOURCE: paper jam
i would Isolate the printer to know if the printer is getting
the error stand alone. Disconnect printer from pc and turn the printer off. take out any remaining paper. Check for small pieces of paper and look for obstruction inside the printer and the paper feeding area. Then try and do a stand alone nozzle check by holding the paper button down and turning the printer on keeping finger on the paper button for arounf 5 sec. now if that still doesnt feed the paper there could be something worng with the machine. hopefully your still under warranty.
Posted on Jun 14, 2008
  • 6 Answers
SOURCE: Paper feeding problem
Try looking inside the printer and make sure there is nothing foreign in the paper path. I once threw away a printer that wouldn't feed. The next time it happened on my new printer, I was admonished to check the paper path. Lo and behold there was something down in there that prevented the paper from loading properly. You might have to remove the printer case (cover) to inspect thoroughly. Now I use a printer cover when not in use to keep dust or anything else from getting in there. I've spent too much time and money from printer problems and a cover is cheap insurance.
Posted on Aug 08, 2008
jacklee366
  • 541 Answers
SOURCE: steady red light feed paper button
your printer needs to be reset put this in google scc download it and that should work
Posted on Nov 23, 2008
aicaxz
  • 511 Answers
SOURCE: epson c90 paper feed problem
Is the message general error? The problem is tchip. When turn on chip is recognized by printer, but when start to print, printer "read" some information from the chip. Here is the error. Some pin at the chip for redaing the existence of chip, other pin for reading the information. Check connector between chip and carriage.
Posted on May 30, 2009
How to replace paper feeding kit on DCP 7020
Most likely all you need is to clean the rubber feed rollers. Use alcohol.
Oct 24, 2014 | Brother Industries, Ltd DCP-7020 Laser...
Samsung 1710 stops before printing
to fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
Oct 29, 2007 | Samsung ML 1710 Laser Printer
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Dec 16, 2009 | Konica Minolta magicolor 2400 Laser...
My printer will not print card paper for xmas
Hi - I too am having an issue with my R1800 loading XMAS CARD STOCK paper.....I tried cleaning the rollers as per the EPSON web site. Although, I used alcohol in stead of water. I made sure I got the little roller way down under the paper and it seems better...although not 100%. Hope this helps!
Dec 02, 2009 | Epson Stylus Photo R1800 InkJet Printer
LOve my printer.BUT...the light goes to error as paper jam
Start the Konica Minolta Status application and check the error, you should get more info there.
Apr 02, 2009 | Konica Minolta magicolor 2400 Laser...
Steady red light feed paper button
Nov 23, 2008 | Epson Stylus Photo 1290 InkJet Printer
False Paper Jam Error
Make sure the paper tray guides are set against the paper more likely to be the back guide not pushing the paper to the front of the tray. If you have the guides set correctly then place one sheet of paper in the tray and blot some methylated spirits on the leading edge along the page width and close the tray and try printing something.
You will have a jam repeat process 3 or 4 times then open tray and remove paper. Where you soaked the spirits into the paper there should be a grubby mark where the feed roller has rubbed and cleaned. Wipe the tray dry and put fresh paper in then hopefully you will now be able to print. If you cannot then the likely thing is that the paper feed pickup spindle is broken and will need replacing.
Hope this helps you and please rate me
Thanks J
Dec 14, 2007 | HP LaserJet 2420 Printer
HP 2420 Tray 2 Open or Empty
Needs feed roller replaced, you can see it when you remove cassette and look up, they wear and tray one uses a diiferent feed roller hence it still works. Cleaning the roller (rag with a little metho) sometimes helps but it should be replaced otherwise it will return.
Nov 08, 2007 | HP LaserJet 2420 Printer
Epson Stylus Photo R2400 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
