Question about Whirlpool GU2400XTP Built-in Dishwasher
Why isnt my dishwasher powering up - Whirlpool GU2400XTP Built-in Dishwasher
  • Whirlpool Master
  • 3,247 Answers
Assuming the power circuit breaker is ok and you are getting power to the dishwasher itself, there are other factors that could lead to an outcome of dishwasher not appearing to be powering up.
The most likely cause is power supply inside dishwasher is faulty, the controller is faulty or simply the dishwasher display panel is faulty.
More likely the dishwasher has suffered a "thermal" trip. The thermal fuse located in the control panel on the door has blown. You may need to replace it. It is item 6 on this diagram
Posted on Jan 04, 2013
Kenmore dishwasher panel isnt responding
>> Unplug dishwasher power cable from wall mount also from dishwasher (if applicable).
>> After 10 minutes - plug the power cable from dishwasher to wall mount
>> Turn on the dishwasher
>> Try to operate the panel.
Mar 29, 2014 | Kenmore Dishwashers
The light keeps flashing an going beep beep dishwasher isnt doing it's job not washing
On my dishwasher if I hold down the start button for a few seconds it resets the cycle could you do that with yours as mine is a different make?
Feb 02, 2013 | Dishwashers
My zanussi dishwasher isnt bringing in water and there are no blockages that i can find and my water pipe isnt blocked what else could this be
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Aug 25, 2011 | Zanussi Dishwashers
It isnt draining water. checked waist pipe and it isnt blocked Looks like the problem is in the machine. regards Brian
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 08, 2010 | Dishwashers
Dishwasher isnt pumping the water out
Check the drain pipeline of your dishwasher if it is working or clogged. There's a good possibility that it is clogged. So, check these areas well. Send in your
e-mail so we can assist you further.
Oct 14, 2009 | Tricity Bendix 18 in. DH090 Free-standing...
Dishwasher has power but isnt working
What dishwasher model are you working with? Did you physically check the power cord with a voltmeter to see if it was getting 120vac? It might be a bad timer switch.
please rate my answer.
Oct 12, 2009 | Dishwashers
I have an FDF780 dishwasher that wont spray water
Sounds like wash pump is weak or siezed.
Sep 28, 2009 | Dishwashers
Water in the bottom of dishwasher and no power. I checked the circuit.
check breaker and if power isnt it then let me know
Apr 14, 2009 | Dishwashers
No power to dishwasher
Start by checking for loose or melted wires under the dishwasher underneath in the "junction box". if the wires arent melted and the plice is ok. then you may need to look for the thermal fuse by the control board. make sure your breaker isnt tripped. go and turn it all the way off then back on.
Nov 28, 2008 | Dishwashers
Dish washer not filling with water
there can be several reasons: as a start, split the door and check for broken wires in the wiring loom where it passes round the bottom of the door. also check the circulating pump is not burnt out.
May 06, 2007 | Bosch SHU5307UC Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
124 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
