Question about Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls
Electrolux washer leaking from bottom
Water is leaking from where washer meets base
2 Suggested Answers
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Frigidaire Electrolux Frost Free Freezer
    Sounds like you need to check if the unit went into a defrost cycle and made any ice build up inside the cabinet "slushy" and the water leveling itself and running down plastic liner parts to a place where it can escape underneath.
    Posted on Aug 01, 2012
    E13 error code on my electrolux washer what does it mean
    You didn't specify model of your washing machine.
    For Electrolux that usually means water leaks (Maximum overall water fill time exceeded (sum of all water fills between one drain phase and the next to avoid exceeding the maximum volume).
    Could be:
    Drain tube improperly positioned; Water pressure too low;
    Water fill solenoid valve faulty; Water circuit on pressure switch is
    leaking/clogged; Pressure switch faulty.
    Dado
    Mar 03, 2017 | Electrolux Washing Machines
    EIFLW55HIWO Electrolux Washer why would water still be in the soap dispenser after washing a load of clothes
    I appreciate your post, friend!
    Based off the information you have provided you still have water inside of the dispenser of your Electrolux washer. This is a normal operation of your washer. This is due to the siphoning action of your dispenser and washer. You may need to empty the dispenser every once in a while due to the water left inside of it. I hope this information is helpful. -Matt
    Feb 25, 2015 | Electrolux Washing Machines
    Electrolux washer e 13
    Water leak in tub or leak in air bell is what the code means if you do not see water leaking and you can not find a air leak in the hose or air bell test the pressure switch if it test fine then replace the control board
    Feb 12, 2014 | Electrolux Washing Machines
    Electrolux front load washer leaks from soap drawer
    This is a common problem with front loaders. Probably poor design.
    Jun 23, 2017 | Electrolux AWF 1435 Front Load Washer
    Water leaking from reservoir
    I had the same problem. All of a sudden my kitchen top counter got filled with water. The water was leaking from the Nespresso C190 water resevoir at the bottom. Exactly where the reservoir meets the coffee machine base. I had by chance an "O" rubber ring left from a faucet which I inserted at the base of the water rervoir right on the small **** which when it sits on the C190 base lets a valve open in order the water to flow through. The "O" ring was 2 to 3 mm in diameter and about 1 mm thick, You might experiment with different ones until you solve your problem.
    Jul 02, 2011 | Nespresso C190 Espresso Machine
    Dishlex global 500 dishwasher says ''of '' . It will not stop making weird noises. I Have had to turn it off at the wall.
    Hi there.this is (over fill error).It has over filled & flooded water down into the base.It has tripped a flood switch in the base wich turns the drain pump on even though the washer is off.You can simply try tipping the washer to get the water out or you will need to disassemble the front kick panel at the bottom front to mop out the water.The switch will reset after you do this.Or wait a couple of days and the water will evaporate enough that the pumping will have stopped & the washer should work again.The booklet for your washer has water hight level settings in it.Sometimes someone leans against the washer and presses the buttons wich changes the water level to high & thats why this has probably happened in the first place.It may need setting to a lower level.
    Jun 04, 2010 | Electrolux Dishwashers
    Fridgidaire FDB1250REC dishwasher comes on, fills some water in bottom then cycle stops but can hear motor turning on and off, water will drain when I try to start cycle again.
    This seems to be the "anti flood" device at the base of the washer is triggered due to water at the base of the washer. This safety device consists of a polystireene float and a micro switch that detects water leaks/spills and automatically puts the washer in pump out mode. You need to find the leak (hose or clamp)dry the base and rectifythe leak it before the washer works.
    Mar 22, 2010 | Frigidaire 24 in. PLD2850 Built-in...
    Water leaking from base
    There should be an access cover at the bottom of the machine, Take it off and check your pump, the hose going from the tub to the pump, and the drain hose.
    Nov 07, 2009 | Electrolux EW1000i Front Load Washer
    Leak underneith washing machine
    Tip washer to inspect belts & hoses on bottom. Check hose connections & plastic pump housing for crack.
    Nov 04, 2009 | Westinghouse WWS833ES Super Capacity Top...
    Faucet leaks at base of spray handle when water is turned on. How can I fix this leak?
    most of the the pullout sprayers need a rubber washer were it meets the hose chek for cracks and replace.
    Oct 31, 2009 | Price Pfister 532-7PCC Marielle Pull-Out...
    Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls Logo
    750 people viewed this question
    Top Electrolux Washing Machines Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
