Question about Sharp AL-1530CS All-In-One Laser Printer
I need a schematic or manuel to open right areas or fix.
Need to see a schematic. Where is the opening for the scanner to do a reset?
  • Sharp Expert
  • 257 Answers
Well to do a reset , you don't need to open anywhere but it depends on what reset. To open the scanner glass, just lift the platen cover up and you will see right and left screws , unscrew them and remove the glass and wipe inside.
Posted on Jan 16, 2013
Uniden BC170 programming and reset
Hello Deanna. Go here to find your scanner model#.
RadioPics Database Schematics Manuals Etc
click on the link they give and you'll open up a owners manual in Adobe of your scanner. Mike
Sep 06, 2015 | Uniden Radio Communications
I need the schematic diagram for my police scanner A 950
POLICE scanner!!! I don't think so, Radio Scanner, YES!!!
I refuse to assist anyone involved in scanning the law, sorry, but that's not what these radios are really for.
Good Luck...
Feb 06, 2013 | Uniden Radio Communications
Scanner stuck at 000.0000 keys don't work
You may benefit by performing a reset or initialization of the scanner. The manual describes the procedure at the bottom of page 38.
You may lose previously stored frequencies if you reset or initialize the radio.
RESET
1. Turn off the scanner, then turn
it on again.
2. Insert a pointed object, such
as a straightened paper clip,
into the reset opening on the
side of the scanner. Then
gently press the reset button
inside the opening.
Initialize
it on again.
2. Hold down TUNE/CLEAR.
3. While holding down TUNE/
CLEAR, insert a pointed object
(such as a straightened paper
clip) into the reset opening on
the side of the scanner, then
inside the opening. The
display should turn off.
4. When the display turns on
again, release TUNE/CLEAR.
I hope this helps & good luck!
Feb 04, 2013 | Radio Shack Pro-82 200 Channel...
How to re-set to original programming ?
To RESET your PRO-2096:
- Power the scanner OFF.
- Power the scanner back ON.
- Insert a pointed object (paper clip end, ballpoint tip, etc.) into the RESET opening on the back of the scanner and gently press the button inside.
If the RESET does not clear your problems you may need to INITIALIZE the scanner. Instructions for this procedure are on page 77 of the scanner operating manual. If you need a copy of the manual, you can download and print it, at no cost, here:
http://support.radioshack.com/manuals/ome20-496.pdf
Bill B.
Listening in since the 60's
Jan 25, 2011 | Radio Shack Pro-2096 Base Scanner
I cant reprogram the scanner. It is only in channel 6
To restore normal operation, try RESETTING the scanner:
- Power the scanner OFF, then power it ON again.
- Insert a pointed object, just as the end of a paperclip, into the RESET opening on the side of the scanner, then push the small button inside the opening.
In many cases, the RESET will restore operation. If not, you'll need to perform the more drastic INITIALIZE process. NOTE: INITIALIZE will erase all information that you've programmed into the scanner and restore it to original factory settings. To INITIALIZE the scanner:
- While holding sown the TUNE/CLEAR key, press the RESET button as above. The scanner display should shut off.
- When the display turn on again, release the TUNE/CLEAR key.
Need the manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
www.RadioReference.com
Bill B
May 22, 2010 | Radio Shack Pro-82 Scanner
I have had my pro-95 for 8 years with no problems...now the trunking will not work...please advise
Your scanner may have had a logic "hiccup" for any one of many reasons, and a simple RESET may restore the trunking function.
RESET (will not wipe out frequencies or other programmed data):
- Turn the scanner OFF, and then then ON again.
- Insert a pointed object (paper clip, pen point, etc.) into the RESET opening on the side of the scanner, then gently press and release the RESET button inside the opening.
If the RESET doesn't solve the problem, you may need to INITIALIZ the scanner.
INITIALIZE (this action WILL delete all programmed data)
Welcome To Dual Trunking appears.
- Press 0 then 1 while Welcome to Dual Trunking is displayed. Initializing Please Wait appears for about 2 seconds.
Do not turn off the scanner until the initializing process is complete. When complete M000 will appear on the top line of the display, and Bank 0 Ch 0 will appear on the bottom line.
Hopefully one of these steps will restore the trunking. If not, the scanner may need professional help.
Bill B
Feb 18, 2010 | Radio Shack Pro-95 Handheld Scanner
How do I do a master reset on the pro 83 scanner
To reset the scanner (clear a problem or keyboard lockup):
- Tune the power OFF and then back ON.
- Insert a pointed object (paper clip, ballpoint pen tip, etc) into the RESET opening on the side of the scanner and gently press the button inside.
If the RESET does not clear the problem you can INITIALIZE the scanner, but this procedure will clear/erase all information that you have programmed into the scanner.
- Power the scanner OFF and then ON.
- Press and hold the TUNE/CLEAR button while pressing the reset button as above. The display will momentarily blank.
- When the display resumes, press TUNE/CLEAR again.
BillB
Feb 08, 2010 | Radio Shack Pro-83 Scanner
I have Symbol LS9208 barcode scanner, but I don't have any cables. I need schematics of USB or RS232 cable for this scanner.
You'll never be able to make the appropriate cables - and Motorola (they bought Symbol) no longer publishes schematics for cables. Contact the Motorola helpdesk at 1-800-653-5350
Oct 28, 2009 | Symbol LS9208 Hands Free Barcode Scanner
Need schematic for Regency z30 police scanner
Make sure you lock the memory switrch in back to on this should slove your problem Good Luck
Sep 28, 2009 | Radio Communications
RADIO SHACK SCANNER pro -92/NEED SCHEMATICS >>help
Looking at a site, I noticed there are 3 versions of that scanner. 200-0522, 200-0522A and 200-0522B version. The 0522 has the earlier firmware, and the A version upgraded this.
Possibly they can help at the RS support site.
http://support.radioshack.com/support_tutorials/communications/cfq-2000522.htm
Good luck with this, Mechanic
Jan 09, 2008 | Radio Shack Pro-97 Handheld Scanner
Open Questions:
Sharp AL-1530CS All-In-One Laser Printer Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
