Question about Frigidaire Electric Dryer
Model aeob6400fso code 68 runs a few minutes shut off
  • Frigidaire Master
  • 8,220 Answers
Stuck button
Posted on Jan 04, 2013
Truck start up run great couple minutes then shut off let set few minutes then crank up run great 30 second shuts down like you cut key off let set few minutes crank right back run fine then dose same
Sounds like it is running out of fuel. Maybe a bad fuel pump, or clogged filter. If it is carbureted, a stuck float valve or clogged float valve might be the problem.
Telling us year, make and model would allow us to help you more.
May 31, 2015 | Cars & Trucks
What do i do when my frigidaire dryer shows error code 68
Good Morning Friend,
I understand that your Frigidaire dryer, model# LEQ2152ES0, is showing a 68 error code. The E68 error code means that there is a possible button that is stuck. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power is restored start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Electrolux Dryers
Frigidaire affinity error code 68
what is the name and model of these dryer.rate these for clean solution
thanks
Jan 16, 2013 | Dryers
Compressor will cut on run a few minutes and shut off hot air
The compressor is probably going out on overload. There may be a small refrigerant leak thus making the compressor run hotter than usual. If there is not enough refrigerant in the system, the compressor will not get the refrigerant back to it to keep it cool. This is a safety feature built into the compressor to keep it from overheating and locking up. You may want to take it to your local appliance store and have it looked at. Most of the time it usually is cheaper to buy a new unit than to pay for just the labor to have them fixed.
Jun 07, 2010 | Samsung AW1203B Air Conditioner
Refridgerator not cooling
That fan at the top has to remain on during cooling or you get the temps. you describe. To check this you need a voltage meter. Got to get to the fan and have to check if there is voltage 120v when it shuts off. If there is still voltage present when it shuts off then change the fan, if no volts when it shuts off then change the timer. need complete model cause this one may have an adapative timer.. i fixed one with the same problem last year.
Mar 28, 2010 | Refrigerators
Heaters runs for a few minutes then shuts off.
was working fine refilled it and now it will run 5sec. and kick the breaker on it.It's an old 80's model 35,000 B.T.U. I cleand the photo eye with a cloth no change. Any solution's
Jan 29, 2010 | Reddy Heater-30-55,000 BTU Variable
ERROR CODE 68 WILL NOT CANCEL. IF YOU PRESS CANCEL AND THEN START IT RUNS FOR ABOUT A MINUTE AND STOPS
code 68 [aeq7000es series]relates to "stuck buttons, or control panel issues. Try to see if your dryer will give you the code for which button is stuck and try to wiggle it to free it up if stuck. If all buttons check out good then you most likely have a bad control panel ,and its time to find your best deal on one
Sep 29, 2009 | Frigidaire AEQ7000ES Dryer
Error Code E68 stuck button?
expensive it is....if you have them side by side I think you can do it and save lots
Aug 15, 2009 | Frigidaire AEQ7000ES Dryer
Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
May 17, 2008 | Dryers
Frigidaire  Electric Dryer Logo
48 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
