Question about Whirlpool Dishwashers
Why does my dishwasher not have any power? - Whirlpool Dishwashers
  • Whirlpool Master
  • 3,247 Answers
Assuming the power circuit breaker is ok and you are getting power to the dishwasher itself, there are other factors that could lead to an outcome of dishwasher not appearing to be powering up.
The most likely cause is power supply inside dishwasher is faulty, the controller is faulty or simply the dishwasher display panel is faulty.
More likely the dishwasher has suffered a "thermal" trip. The thermal fuse located in the control panel on the door has blown. You may need to replace it. It is item 6 on this diagram . ( i have already responded to your earlier post)
Posted on Jan 04, 2013
My dishwasher does not power up?
How to Fix a Dishwasher That Won't Start ' Dishwasher Repair
www.partselect.com/Repair/Dishwasher/Will-Not-Start/
When your dishwasher won't start it can be frustrating. ... The selector switch on adishwasher is used to select different options for the individual cycles, such as ...
Dishwasher Will Not Turn On - How To Fix ...
removeandreplace.com/2014/.../dishwasher-will-not-turn-on-how-to-fix/
Oct 6, 2014 - If your dishwasher won't turn on or start, here are a few things to check ... My Frigidaire dishwasher Model # FGID2474QFOA is only a year old ...
Dishwasher has no power - YouTube
? 4:38
https://www.youtube.com/watch?v=pp5P3Cvy9qA
Mar 26, 2010 - Uploaded by ApplianceHelpOnline
If your dishwasher has no power watch this video. For more free videos,parts,service manuals, free expert ...
What to Do When the Dishwasher Won't Start -
Jan 18, 2016 | Frigidaire Dishwashers
What does pf mean when it comes up on my dishwasher model no. fdb2320rec2
POWER FAILURE.. you lost power to the dishwasher either whole house or just dishwasher,,,not sure why we need the dishwasher to tell us that we lost power, but too many can cook the control board,,,did mine. good luck
Mar 18, 2014 | Frigidaire DGBD2432K Dishwasher
Why isnt my dishwasher powering up
assuming the power circuit breaker is ok and you are getting power to the dishwasher itself, there are other factors that could lead to an outcome of dishwasher not appearing to be powering up.
Jan 04, 2013 | Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher froze and i have no power lights on it. I think we need to reset the dishwasher? how do i do it?
I am not an expert in dishwashers but most appliances do a hard power reset by removing the power supply for at least 15 seconds.. You might be able to turn the circuit breaker off for power(ie 15amp)in your power box for your house as your dishwasher is probably hard wired..*NOTE. If it has its own power point-turn that off only***
Aug 26, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
No power
well if your main power that supplies the dishwasher is good then you need to replace the main control unit of the dishwasher
Jan 31, 2010 | Dishwashers
How do I reset an old Bosch dishwasher SHI4302UC ?
Assuming that you can control power to the dishwasher from your kitchen panel switches, hold down the power on switch on the front panel of the dishwasher and recycle power (switch off and on) at the kitchen panel switch.
This will reset the dishwasher.
Sep 26, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
DISHWASHER WONT POWER UP
HI, there are four problem spots that i recommend checking. these are the most common hot spots for a non responsive dishwasher. Check each area thoroughly to address this issue.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Jul 13, 2009 | Dishwashers
My dishwasher will not start: Most common d/w power is 120 volts, check for 120 volts with a volt meter at the main power harness where it enters into the dishwasher, you will have to remove the lower access panels to get to the power box. Dishwashers also have at least one and most newer dishwashers have two door switches that must be checked. You will find then behind the console at the door latch area. Each manufacture has different designs but this is a picture of what some of the newer dishwasher switches look like.
Feb 19, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Westinghhouse 907 dishwasher Sydney Australia
Nov 03, 2007 | Westinghouse 24 in. MDP531 RF...
Dishwashers Logo
85 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
