Question about Motorola Mobility PEBL U6 Cellular Phone
Will not ring or vibrate.
My phone will not ring or vibrate but it will play ringtones from the sounds menu in multimedia. Please help.
  • Anonymous Apr 03, 2008
    Mine does not ring or vibrate, either, but i've tried changing it to Loud style and changing the ring tone and volume, but when a call is coming in, it still does not ring. HELP!
Go to settings... personalize....ring type... pick loud ...scroll down to edit then go in and change from silent to the ringer setting you choose
Posted on Aug 10, 2007
SOURCE:
Want to silent keypad when typing or dialing
Hi nanro346,
Editing the Normal - Message Profile 1.Touch >Settings > Sound Profile >Normal. •Touch the name field and not the radio button to the right. 2.Touch drop-down menu (upper-right of the screen) and selectMessage. 3.Touch the Message Alert Type field, select one of the following and touchSave: • Melody: the phone rings using the ring melody selected in the Ring tone menu. • Vibration: the phone vibrates 3 times. •Vibration & Melody: the phone vibrates and plays a melody simultaneously. • Mute: the phone is silent and does not play a melody or vibrate. 4.Touch the Message Alert Tone field, touch to select a ringtone and touchSave. 5.Touch the Message Alert Repetition pull-down and select one of the following options and touchSave: • Once: repeats the message alert once. • Periodic: repeats the message alert periodically. 6.Drag the Alert Tone Volume slider to the volume level you desire (range is 1-7). 7.Touch the Vibration Pattern field, then touch to select Vibration 1 - 3. 8.TouchSave to return to the Sound Profiles menu
Apr 29, 2011 | Samsung SGH-A877 Impression Cell Phone
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
How do I turn off the key pad tone on the impression sgh-a877
The Sound Profile only covers call sounds.
Sound Profiles
This menu allows you to specify how you are informed of
incoming calls.
Selecting a Profile
1. Touch ➔ Settings ➔ Sound Profile.
2. Touch the radio button next to the profile name. The
selected profile activates. Choices include:
• Normal
• Silent
• Driving
• Outdoor
Normal Profile
The phone’s profile defaults to Normal. Use the following
procedures to change the profile.
Editing the Normal - Call Profile
1. Touch ➔ Settings ➔ Sound Profile ➔ Normal.
• Touch the name field and not the radio button to the right.
2. Touch drop-down menu (upper-right of the screen) and
select Call.
3. Select the Call Alert Type field and select one of the
following and touch Save:
tone menu.
• Vibration then Melody: the phone vibrates and then starts ringing.
• Vibration & Melody: the phone vibrates and plays a melody
simultaneously.
4. Touch the Voice Call Ringtone field, touch to select a
ringtone and touch Save.
5. Drag the Ringtone Volume slider to the volume level you
6. Touch the Vibration Pattern field, then touch to select
Vibration 1 - 5.
7. Touch Save to return to the Sound Profiles menu.
There is no mention of keyboard tones in the user manual.
Mar 19, 2010 | Samsung SGH-A877 Impression Cell Phone
Motorola Adventure 750 phone-- no speaker sound. Why?
You've probably already tried these, but what the heck; you asked...
1) Check in MENU -> SETTINGS & TOOLS -> SOUND SETTINGS -> CALL SOUNDS -> CALL RINGTONE to make sure that you have actually selected a ringtone instead of the "No Ring" option at the bottom.
2) With the phone open, try the up/down buttons on the left-hand side of the phone (above the Push-To-Talk button) to make sure that your volume isn't set to "All Sounds Off," "Alarm Only," or "Vibrate Only." It has to be at least at "Low" before a ringtone will play.
Hope this helps. If not, you probably need to take it in to a Verizon store for an expert assessment; they'll usually take a look at your phone and install any software updates for free.
Mar 10, 2009 | Motorola Mobility V750 Cellular Phone
No ring, only vibrate
if the ringtones ring from settings or the songs play then it will be surely the settings problem please select ring and vibrate instead of vibrate only and if it doesn't works then go to a near by repair shop and ask them to check and change the buzzer
May 02, 2008 | Nokia 6288 Cellular Phone
6600 ringtone
go to Profile in Menu
select outdoor
options- personalise
set to------
Ringing Tone-  any ringtone u want
Ringing Type- Ringing
Ringing Volume- Full
Message Alert tone- any tone u want
Vibrating Alert- on
keypad Tones-__________
Warning Tones-_____________
Alert For-_________________
Profile Name-_____________
Mar 25, 2008 | Nokia 6600
MotoPebl does not ring!
mine did the same thing. i figured out that my songs were turned down (i dont know how this happened in the first place cuz it worked for the first couple of times then stopped ringing but...)
go to your menu, then multimedia, click sounds, then click whichever ringtone is yours, when it comes up use the volume button on the right of your phone to turn it up.
this worked for me, my phone is up and running now :)
hope this helps!!
Dec 29, 2007 | Motorola Mobility PEBL U6 Cellular Phone
No Ringtones
thats probably because you have that one set for airplain so the only way to fix it is to go to menu , tools., sound , and you shoud see speaker or airplaine option there is a check mark on wich you have you preference settings just change an thats it
Dec 27, 2007 | Motorola Mobility RAZR V3
Ringtone/Ringtone "PLAY" function not working
crazzyyy problem...
i suggest take it back wherever you got it!
Nov 07, 2007 | Motorola Mobility MoroKRZR K1m Cellular...
No sound when phone rings
I called Verizon Wireless and the said, if you go to “My Sounds” or “My Ringtones” select the song that you want to hear and press the play button. While the ringtone is playing press the button on the side of the phone to raise the volume…you should be able to hear the ringtone. Hope this helps!
Jul 29, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola Mobility PEBL U6 Cellular Phone Logo
143 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
