Question about NEC VT47 Multimedia Projector
Replacing lamp on nec projector
I have an NEC projector and the lamp needs to be replaced but i dont know where to get one and also I don't know how to replace it i'm not too sure if i have to open it up fully
Go to the link, the NEC has an online store, or you can use their link to find an authorized reseller.
Usually there is just some sort of door on the bottom or side held in place with a screw or two. Refer to your owners manual, or download it from NEC in pdf format.
Posted on Jan 26, 2009
Lamp hour reset NEC MT1060
The NEC MT1060 lamp hours is stored in an EEPROM chip built into the lamp. As soon as you put in a new lamp (MT60LP or MT60LPS), the hours will be reset. If you remove and put back in an old lamp, the unit will see the hours on that lamp. Thus if the lamp has reached 2100 hours, the projector will remain in standby. See page 53 of the manual for the replacement and reset information.
Most of the manuals for the NEC projectors are available here: . The direct link to the manual for the MT1060 is .
I hope this helps.
May 24, 2016 | NEC MT1060 Multimedia Projector
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ... > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58] > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
Nec mt-1065 lamp hours reset
Hello, unfortunately the NEC MT1060 - MT1070 series projectors have EEPROM chips built into the lamp housing which counts the hours that the lamp has been used for so the only way to reset the hours is to change the lamp for a new one, i have not yet found a way to reset the chips even by reprogramming them, i'm afraid the only solution is to replace the lamp with an official NEC unit, but this was obviously their intention.
Oct 25, 2010 | NEC MultiSync MT1065 Multimedia Projector
check the lens cover hood to see that it's on correctly, and that the lamp door is closed. if they are, check the switches. on the hood and the lamp door, there are plastic protrusions that hit the switch activators. if they are broken off or warped, you need to replace the door/hood. if they are there, check the switch itself. replace as necessary.
Nov 17, 2009 | NEC GT6000 Multimedia Projector
NEC VT 480, replaced new lamp ,still low brightness.
if you remove the lamp, inside the lamp housing you will see a refraction (fly-eye) lens. these evenly distribute the lamp light. the one on the other side from the one you see (there are always 2 lenses) is probably burnt and needs replacing (a common problem with lcd projectors). you will have to send it in to nec. in many of their projectors, both lenses are in one assembly.
Sep 11, 2009 | NEC VT595 LCD Projector
Lamp and user's manual for a NEC Multisynch MT Projector
The manual can be downloaded here:
The part number for the replacement lamp is MTLAMP600/800 and it may be ordered from
Mar 02, 2009 | NEC (SPPL1063) Projector Lamp for MT600,...
Lamp error on nec projector
Have you changed the lamp? is so check out
the ballast most likely needs to be replaced
Dec 16, 2008 | NEC VT676 Multimedia Projector
Resetting Lamp Hours Procedure On Nec-MT-1075
Hi - You can download the manual by clicking the link underlined in blue below:
See page E-55:
As in the note replacing the lamp automatically clears the lamp hours.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Sep 05, 2008 | NEC MT1075 Multimedia Projector
Preylahong NEC MT830+need help to reset new lamp
After replacing lamp in MT-830(NEC) press and hold "on" button for 10 seconds to reset lamp hours. If projector has beyond 2100 hours press the "off" button for 10 second.
May 01, 2008 | Office Equipment & Supplies
NEC MT1055 Will not power up
Hi there
This sounds like a faulty Ballast ( lamp's power supply ) It will unfortunately need repair or replacement.
Mar 25, 2008 | NEC MT850, MT1050, MT1055, MT1056...
NEC VT47 Multimedia Projector Logo
214 people viewed this question
Top NEC Office Equipment & Supplies Experts
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
