Question about Toys
Air hog hover assault won't fly, will only spin on ground. push the correct buttons. but only spins
I push the fly button and the throttle stick to no avail. it only spins on the ground in circles
4 Suggested Answers
  • 7 Answers
SOURCE: how do i fly my spin master air hog rc helicopter
If its a Reflex twin rotor Heli use the trim wheel on top to counteract the spin and at least stabilize the craft at hover. Then use the right/left froward backward fans to control flight, (right joystick on the controller). These fans are not very powerful so don't expect alot from them other than turning the craft right left and reverse. Seems there is too much down draft from the rotors to effectively move the Heli forward. Not a real good design. The Sharpshooter is easier to fly but uses the batteries in the controller as a charger so they don't last real long.
Posted on Feb 15, 2010
  • 4 Answers
If you trimmed your heli but it still can't work, try using the direction knob to trim it instead. When it goes clockwise push th knob leftwards and hold, and vise versa for anti-clockwise. Or, push and release repeatedly in the direction mentioned till it flies straight. Tested on around 6 air hogs helis and works each time. If you still can't trim you might try it after turning it off or contact the service centre.
Posted on Sep 08, 2010
bayyagg
  • 1672 Answers
SOURCE: my green air hog helicopter
There is a problem on the motor gear, check the underside where you could see a big gear that should spin when you try to lift the helicopter. Check both big gears if they rotate/spins.
Usually the problem is the small gear on the motor shaft that is not aligned to that big gear. Check on it and adjust the small gear of the motor.
Hope that copter flies high.
Thanks for asking FixYa!
Posted on Aug 09, 2011
My 9116 double horse RC helicopter just spins clockwise in circles, on the ground or in the air. I can hover it, but only spinning. What could be wrong?
Air Hogs remote control aircraft are designed to be easy to fly and use, and rarely have flying issues. However, there are the occasional issues that the company can't really predict. Some Air Hogs helicopters, for example, have a hard time flying forward without some assistance. If you're having this problem with your helicopter, this can be annoying, but it is not the end of the world. There is as solution, and it's easier than you might think.For more information:
http://www.playgroundmats.co.uk/ Playground Mats and Playground Flooring Tiles Soft Play Equipment
Jan 10, 2014 | Toys
Harley davidson starter still spins after start
Replace your starter before you damage your fly wheel if it is not too late already.
Jul 07, 2013 | Motorcycles
How to correct trimming problems did what the insteuctions said and keep having the same spinning counterclockwise problem
Just bought the air hogs helicopter with the crane. Had the aircraft constantly spinning clockwise, no matter how much I turned the trim control counter clockwise the aircraft still rotated. I then turned the trim control in the opposite direction until I noticed the aircraft had stopped spinning, and used the rudder control to fine tune forward flight. So, get the aircraft to hover and turn the trim button in the opposite direction until you see that the aircraft spinning slows right down. If you continue to turn the trim control in the same direction the aircraft will increase its spin, so just dial back the trim.
Dec 29, 2012 | Air Hogs Havoc Heli Helicopters
Can you buy replacement blades for air hogs hover assault?
I don't know I have the same problem mine wrecked into a wall and it just cracked and it wont fly and I am looking for one but am not sure either
Dec 26, 2012 | Toys
My green air hog helicopter is spinning on the ground, it won't lift and fly, how do I fix it?
Aug 09, 2011 | Air Hogs Havoc Heli Helicopters
I have an air hogs sharpshooter helicopter and it wont stop spinning when i try to fly it and it only gets about a foot off the ground
it could be that you just need to use the adjustment nob it is next to the right joy stick u can turn it to make the heli fly straight. or one of your blades is not working like it should.
Jan 06, 2011 | Master Heaters Air Hogs Sharp Shooter...
My son's helicopter just spins around and won't lift up anymore. It has been sitting for about a month, but worked fine before that. Any solutions? Could the blades have been bent? They don't look like...
replace batteries with new ones and then you let it spin while you trim it out by pushing rotor button ,for heli that spins clockwise push trim button on left side and a heli that spins counter clockwise push trim button on right side continue pushing the corrective button until spining slows and eventually your sons heli will fly straight again these instructions are in the owners manual
Nov 28, 2010 | Air Hogs Havoc Heli Helicopters
How do i fly my spin master air hog rc helicopter all it does is go in circles
Feb 05, 2010 | Spinmaster Air Hogs RC Reflex Micro...
Helicopter keeps spinning in circles and won't lift.
There is a "trim button" on the controller. Ex: if the helicopter is spinning left, press the "R" trim button repeatedly. Takes a little practice to get it down to flying with out hitting anything. Good luck.
May 17, 2009 | Spinmaster Air Hogs RC Reflex Micro...
Wont fly
I have an Air Hogs havoc cyclone stunt plane. I am not sure if your plane has this, but on my plane's remote there left and right steering trim buttons. Play around with these until your plane flies correctly.
Dec 30, 2008 | Air Hogs Glow In Dark Havoc Stinger Rc ...
Toys Logo
267 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
