Question about Yamaha R-V501 Receiver
Power up problem on my receiver
I have a Yamaha R-V501 receiver that powers up fine for about 2 seconds but then I hear a click and the receiver shuts itself off. Do I have a fuse issue or is it something more serious?
The polarity on your speakers are reversed
Posted on Nov 01, 2008
SOURCE:
Yamaha RXV-730 6.1 Channel A/V Receiver
the clicking may have been coming from the relay itself, but it doesn't simply mean that the relay is faulty. clicking may also be caused by transformers, indicating that some electronic components have developed SHORT CIRCUIT. try measuring resistance of transistors and diodes near the power unit (unplug/turn the unit OFF of course) check also for the impedance of the output power transformers.
check the amplifier IC for short also.
Feb 29, 2008 | Yamaha RX-V730 Receiver
What is the correct remote for a Yamaha R-V501?
If it is just a reguler stereo reciever any decent universal remote will work on it,
Dec 03, 2012 | Yamaha Audio Players & Recorders
My Yamaha rx-v663 turns on for a few seconds then shuts off within 2-3 seconds. The first time the unit shut off was after it had been on for a while. I turned it on and it worked fine a little later. When...
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it '*****'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Aug 03, 2011 | Yamaha RX-V663 Receiver
My Yamaha RX V461 receiver will not turn on. When pressing the ON/STBY button, I hear the familiar "click" when pressing the button and a second one about 1-2 seconds later that comes from the...
Your receiver probably went into protect mode because you were overloading the output stage with concert blast. In some units, protection consists of fuses that blow; in others protection is provided by thermal shutdown devices.
Mar 04, 2017 | Yamaha RX-V461 AV Receiver
Re: Yamaha RX V670 Receiver Powering Off
I have found there are capacitors failing through the output circuit. Look for 10, 33, 47, etc.. microfarads.In that range. I charge typicaly 150 to $200 with parts on something like this. Larry's Electronics [email protected]
Apr 23, 2010 | Audio Players & Recorders
When push the power button, I can hear a relay click but the unit will not power up. I took the cover off and fuses are good. Can't find anything in the trouble shooting section of the manual. What do you...
When the unit functions correctly, you should hear 2 clicks. The first is the power relay that "starts" the unit. The second is the speaker protection relay that will kick in the speaker connection. If you do not hear the second click, the unit is in protect mode. This means that a problem was detected in the amp section and the unit is prevented from connecting the speakers. This is done to prevent further damage. Typically the output transistors fail and cause this. Expect a parts cost in the $25-$50 range for this repair.
Dan
Sep 30, 2009 | Yamaha RX-V1500 Receiver
Set won't stay on, won't turn on
Sounds like a capacitor on the power supply is bad. Easy fix.
Sep 24, 2009 | Hitachi 50UX57B 50" Rear Projection...
Won't stay powered on
There is a relay right next to the fuses on the inside dg1u it says on the top. I cleaned it and pressed down firmly on it and it seem to have fixed it. It fired up for the first time.. The relay might need to be replaced if this doesnt work for ya.
I found a solution at: http://www.diyforums.net/forums/domestic-electronics/11098-yamaha-rxv795-receiver-shuts-itself-down-after-some-time.html
Dec 23, 2007 | Yamaha RX-V795 Receiver
Yamaha Receiver RX-V630 not working (resets itself immediately)
This maybe an easy one. Have you unhooked all the wires going in to the stereo. "SP wires" means you have wires to the speakers are touching and the stereo is shutting down to avoid overloading. Hope this helps...
Jun 05, 2007 | Yamaha RX-V630 Receiver
Yamaha R-V501 Receiver Logo
112 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
