Question about GE Spacemaker JVM1640SJ Microwave Oven
When door is shut, the fan comes on. When I open the door the fan goes off. All features on the keypad work except the start button.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
One or more of the door switches is bad
Posted on Sep 23, 2014
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave seems to turn on when door latch is opened
What's happening is you are activating one door switch a little before the other, and that is causing your light, fan, and turntable to come on. The plastic parts are not perfectly rigid, so they flex a little when you press the button, and that causes the lag to be more apparent. Even if you press the door open faster and look really close, you may notice the light, fan, and turntable coming on for a split second. That's perfectly normal. The relay on the control board must also be turned on before it will actually be cooking.
Posted on Feb 23, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: 1800 XL JVM1860BD - won't work
It sounds like your controller may be failing. Or it could be an electrical line problem. Any other electrical itmes giving you trouble? Has anyone measured the voltage level of your power line? It should be around 110-125 volts AC. If it's significantly lower or higher, you may have a bad connection in your breaker panel or in the wiring leading to the home.
Posted on Sep 28, 2007
  • 108 Answers
SOURCE: GE XL1800 Micro fan won't shut off after light burned out
The problem appears, at least in part, to the door latch circuitry which cannot be serviced by the owner. If the unit is still in warranty, call GE customer care. If not, replacing the unit is your best bet. I just bought a new GE 1100 watt oven with great features for less than $100 If the door dosen't latch correctly, you could be exposed to dangerous microwave energy.
Ray
Posted on Nov 16, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: stainless steel GE XL 1800 spacemaker works ok
So the fan motor's 21VAC winding is working. That's good.
But either the fan blade is loose on the shaft (a super glue fix) or the fan motor itself had failed.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
The fan motor is shown on the diagram there as reference # 78, part # AP3192806, located behind the control panel and adjacent to the magnetron.
I'm not sure you have to pull the oven from the wall to replace it, but if you do, the oven installation (& removal) instructions are included on the tech sheet inside the unit.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel, and it is very helpful when troubleshooting, testing, and locating components.
You can also download GE owner's manuals and installation instructions here.
If you don't find yours I can send you a copy, or if you need more help, feel free to contact me directly (and please remind me of your full model number from the tag on the unit).
William E. "Ed" Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 25, 2009
KevinWhite
  • 1902 Answers
SOURCE: Our GE Spacemaker JVM1440WD003 suddenly
Hello & Welcome to FixYa
The problem is with the door switch that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Apr 22, 2011
Troubleshooting Ge Microwave that is acting bizarrely
Sounds like the main control board, but further testing should be done to rule out other possible causes. One thing I would do is to check to make sure it is plugged into a grounded outlet that is actually grounded. Bizarre behavior can be caused on some ovens because of a lack of a ground connection.
Oct 13, 2016 | GE Microwave Ovens
My microwave GE model # JVM1440WH04 spacemaker has no heat coming out of it. My husband heated microwave lasagna in it last, everything works except for the heat, any solutions?
Push the microwave door tightly closed. The computer will not start cooking until the door is closed for safety reasons. Some models of microwave will give a warning on the screen if the door is open.
Ensure you have programmed a heat setting, entered a cooking time and pressed the "Start" button on the microwave's keypad. Check that the microwave is not set to "Defrost" mode.
Unplug the microwave and wait for one minute. This measure will reset the microwave's internal computer if it has frozen or scrambled. Plug the microwave back in and try again.
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol
Oct 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Our oven started coming on when the door was shut. It is not cooking but the light and the fan come on. Nothing makes it stop except opening the door. I unplugged it for awhile, but that didn't help...
I have the same problem.
I found that by removing the control panel, then moving the small red-buttoned switches around the door open switch seemed to solve the problem.
We felt the problem was a mechanical problem because closing the door very gently permitted normal operation.
Sep 24, 2009 | Sharp R-1460 Microwave Oven
Microwave not working
HI, this is a faulty control panel. replace asap if possible.
May 29, 2009 | Whirlpool Microwave Ovens
Fan & Turntable start when door is opened.
sounds like there is a switch that is bad. you can go buy a new MW for about 200$ and in yours if there is a major problem then i would just go buy a new one but might be worth a repair man to come check it out
pleas do not poke around in the microwave as it carries a charge of 5000volts and can kill you even if not plugged in DON'T TOUCH THE WIRES WITH BRAIDS ON THE OUT SIDE if you must get inside of the unit
Dec 10, 2008 | Microwave Ovens
Ray
Nov 15, 2008 | GE XL1800 1100 Watts Microwave Oven
Aug 14, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave problem
Is it possible that grease or moisture got into the controls? This can happen when cleaners are sprayed directly on the keypad; when boiling is done on the stovetop without the hood vent fan being on; when the hood vent filter is clogged; or due to restricted airflow in exhaust. The best way to check the airflow is to turn the hood vent fan on and use your hand to feel at the exhaust outlet outside the home. Moisture can cause the keypad or control board to short to some degreee, and produce odd results. It may clear up, but sometimes it requires that the keypad be replaced or that the board be professionaly cleaned. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk We also repair microwave control boards for customers nationwide for $39.95. Feel free to contact me there directly if you have further questions.
Jun 16, 2007 | Samsung SMH7174BC Microwave Oven
Microwave seems to turn on when door latch is opened
Feb 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Stopped working, Display reads all 8's
It sounds like a shorted keypad. This can be due to age/wear or due to moisture. If the unit is sevewral years old or has ben used a lot, then age and wear can be suspected. Moisture is most often due to spraying cleaner directly on the keypad, which allows it to leak into the works. Always spray your cleaner on a soft cloth and then wipe the keypad clean. Moisture can also get in if the microwave is mounted above a stove and a lot of boiling is done without adequate ventilation, usually via the exhaust or hood fan. This fan should be on when cooking on the range top. In some cases, there may be some deposits on the keypad strip where it goes into the connector on the control circuit board. Sometimes that can be cleaned by unplugging then replugging the strip. Could it be that you're not setting the manual according to the instructions in the owner's manual? The manual is olnine at http://downloadcenter.samsung.com/content/UM/200507/20050727140356453_DE68-01945A[GB].pdf I have attached a scren shot from the manual which shows the clock setting procedure. Maybe it's as simple as this.
Oct 14, 2006 | Samsung MW1030WA Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
69 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
